Subwoofer Question - Padding inside the enclosure - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-27-2013, 08:29 PM - Thread Starter
entermymatrix's Avatar
Good evening all! Quick question for you guys. I have a JBL Sub Venue 12. The amp died on me so i replaced it with a Yung SD300. when I cut the new hole for the new amp, I had to remove some of the "stuffing" that JBL glued inside the box. I didn't take it out of the sub, i simply dropped it into the bottom of the box so its still in there, just not in the same spot. Is this an issue? I'm not sure as I haven't actually changed the space inside the box right? Thanks guys!
entermymatrix is offline
post #2 of 4 Old 12-27-2013, 09:17 PM
aboroth00's Avatar
Quoted: 16 Post(s)
Should be fine.
aboroth00 is offline
post #3 of 4 Old 12-29-2013, 08:14 PM
head_unit's Avatar
Quoted: 236 Post(s)
Liked: 131
Is there a port on the back? As long as the stuffing is not blocking the port or cone or resting on the amp, it should not be a big deal.
head_unit is offline
post #4 of 4 Old 12-29-2013, 08:26 PM
steve nn's Avatar
Liked: 433
No prob at all seeing the vent is at the top back.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
