Would I benefit from a more powerful sub? - AVS Forum
post #1 of 13 Old 12-29-2013, 12:04 PM - Thread Starter
lrock59040's Avatar
Currently running an SVS PB12-ISD in a 2688 sq ft room (24x14x8). Been debating getting either a VTF-15h or a PB12-plus. Is there any meaningful upgrade to be had by making the switch in that size room or is the pb12-isd sufficient and am I throwing money at a problem that doesn't exist?
lrock59040 is offline
post #2 of 13 Old 12-29-2013, 12:43 PM
BeeMan458's Avatar
Liked: 801
A recommendation, check out the first couple of posts in the ULF thread.
In the case of subwoofers, a problem always exists. The question, can the individual afford to fix the problem?
BeeMan458 is offline
post #3 of 13 Old 12-29-2013, 02:16 PM
steve nn's Avatar
Liked: 426
Have you considered another NSD? Might not be as exciting as getting a whole new sub I admit. If no interest the PLUS is basically two NSD’s in one though.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #4 of 13 Old 12-29-2013, 02:33 PM - Thread Starter
lrock59040's Avatar
Thought about it but this is for our livin room, not a dedicated theater room so not sure if the wife is gonna be real thrilled me shoving another big black box in the room
post #5 of 13 Old 12-29-2013, 03:06 PM
aboroth00's Avatar
Another NSD +1
steve nn likes this.
aboroth00 is offline
post #6 of 13 Old 12-29-2013, 03:23 PM
steve nn's Avatar
Liked: 426
I understand all to well.. Just read your post again and noticed you’re running a older isd and not a NSD. That is a fairly good size room you have going. Do you feel your sub is compressing? (not getting louder) although you’re turning up your sub louder or listening level up higher?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #7 of 13 Old 12-29-2013, 03:53 PM - Thread Starter
lrock59040's Avatar
I haven't noticed any yet but haven't been in my house that long. The old room was 12x14 and seemed plenty for that. Not sure if it means anything in regards to the available power but I have the gain at only 40% or so and audyssey still sets the sub at -10.0. So I would think if it was potentially shot on juice audyssey would set it much higher.
post #8 of 13 Old 12-29-2013, 04:16 PM
Reddig's Avatar
Quoted: 17 Post(s)
Liked: 161
I'd get another SVS sub that matches your current one the closest, if not the same model. You'll smooth out response and fill in modes from the room while gaining headroom. If you can get the waf approval I'd go for it. After I got my second HSU VTF2 MK4 it made a big improvement with smoothing response to each seat and the bass sounds much more full. More headroom too. I'll get a third than fourth eventually.
JBL Pro Cinema
Reddig is online now
post #9 of 13 Old 12-29-2013, 04:19 PM
steve nn's Avatar
Liked: 426
I see. You could boost your trim up a little and see how you like things and how it handles it? You always have the option of boosting or lowering depending on material. Many to most around hear ratchet their bass up a little, some a lot! The ISD comes in at a 25hz tune as apposed to 20hz tune on the newer NSD. You would notice a difference in extension right there along with a little more headroom because subs, drivers (SVS) are always evolving. You should notice a little better SQ also. If you bumped up to the PLUS you would have a 16hz tune option also, and of course much more headroom keeping WAF in mind.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #10 of 13 Old 12-29-2013, 05:12 PM
BeeMan458's Avatar
Liked: 801
Just saying, as big as one thinks a sub is, after placed and listened to a few times, the sub begins to blend with it's surroundings. I was quite surprised by this phenomenon.
Out in the open, we have a single FV15HP and behind the MLP, a love seat, is a second FV15HP and my wife is surprisingly okay with this placement.
post #11 of 13 Old 12-29-2013, 07:18 PM
aboroth00's Avatar
Just think of it as an end table. I know Outlaw makes their sub with a plexiglass top... I wonder why.
post #12 of 13 Old 12-30-2013, 01:47 AM
BeeMan458's Avatar
Liked: 801
post #13 of 13 Old 12-30-2013, 05:48 AM
Bill Fitzmaurice's Avatar
Liked: 1348
Show us your measured in-room response. You want to be sure something is broken before you try to fix it. If it isn't sufficient you're probably better off adding a second identical sub rather than going to one larger one.
henrich3 likes this.
Bill Fitzmaurice is online now
Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Hsu Vtf 15h Subwoofer , Svs Pb12 Plus Black Oak 12 Inch 800 Watt Powered Subwoofer
User Tag List
