How to convert the existing in wall pre wired cables to a coax sub woofer connection ? - AVS Forum | Home Theater Discussions And Reviews
Old 12-30-2013, 07:36 PM - Thread Starter
DGN Venkat's Avatar
I moved to a new house which is pre wired for 6.1 system. The in ceiling speakers installation went well. But I have a 4 wire 16 AWG and 2 wire 2C 22AWG cables available for sub woofer connection. I have aHTR 7065 Yamaha receiver and JBL SP 150 sub woofer. According to the builder the 22AWG 2 wire grey cable is able for Sub woofer sue only and not for security system.
I want to use the co axial input of the sub woofer . Any suggestions on how to use the existing wires to convert to co ax format. Also request suggestions on any connectors that i can buy to convert it.
Wait for the experts comment.
Best,
Venkat
DGN Venkat is offline
Old 12-30-2013, 08:46 PM
Bill Fitzmaurice's Avatar
Liked: 4666
You can't convert wire from standard to coax. You can try using standard wire, but you'll probably have noise issues.
Bill Fitzmaurice is online now
Old 12-30-2013, 08:47 PM - Thread Starter
DGN Venkat's Avatar
Thanks for the quick reply .
