Help with subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-31-2013, 02:18 PM - Thread Starter
PinkWonderGirl's Avatar
I am a newbie and am a bit confused by the subwoofer and where to place it and which direction it is supposed to be facing.
This is what I have:
http://www.bestbuy.com/site/2-1-channel-soundbar-with-wireless-subwoofer/8162081.p?id=1218864519395&skuId=8162081&st=lg%20soundbar&cp=1&lp=2
I am a newbie and keep googling looking for pictures and can't figure it out. Is the narrow front with the speaker supposed to be facing out? The soft side is on the left. Right now I have it sitting next to my couch, but the sound seems uneven no matter where I place it. And, I can't figure out which way it is supposed to be facing.
Can anyone help explain? Should the soft side be facing out or the narrow front?
PinkWonderGirl is offline
post #2 of 8 Old 12-31-2013, 03:10 PM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3324
The narrow front is actually the port, not the speaker.
That being said, it doesn't really matter which way they are facing just as long as you have a few inches of space on either side. The sound frequencies reproduced by subwoofers are omni-directional and radiate equally in all directions from the source.
To find the best spot in the room for your sub, try the sub crawl.
Alan P is offline
post #3 of 8 Old 12-31-2013, 03:30 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
The sub probably has a power light on it like the Polk setup I have in my living room so you may want to turn that away from you if you're going to place the sub within your visual range.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #4 of 8 Old 12-31-2013, 03:32 PM - Thread Starter
Why is only one side soft? Is that the side that emits the sound? I know you said it doesn't matter what direction, but I still don't understand how it doesn't matter which direction it's facing. I tried the sub crawl and it didn't work out really well. I just couldn't figure out where it sounded best, but it could have been that I put it in the wrong direction. Oh well. I am pretty confused about where it should be facing.
post #5 of 8 Old 12-31-2013, 03:38 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
What he is saying is that the output from a sub is Omni-directional so it's not really going to matter what direction it's facing. A sub is not like your soundbar...your soundbar is going to send sound in the direction it's pointing but the sub sends sound out in all directions at once. That soft side is probably where the woofer is. Corner loading is probably a good idea. Find a good corner in your room...probably no more than 30 feet from the soundbar and point that soft side at the corner...give it a little room...maybe a foot and let'er rip.
AVR: Denon X2200W
Prime316 is offline
post #6 of 8 Old 12-31-2013, 03:54 PM - Thread Starter
Is it best to not keep it in the corner on the same wall your TV is on or is it better in an opposite corner? Typically. The problem is I am in a very open floor plan and there is only one REAL corner and that is on the wall the TV is on.
post #7 of 8 Old 12-31-2013, 04:04 PM
Alan P's Avatar
Liked: 3324
The best corner is the one with the strongest bass while doing the sub crawl. wink.gif
Alan P is offline
post #8 of 8 Old 12-31-2013, 04:06 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
I have mine on the same wall that my tv is mounted on....just all the way in the corner to the left of the sound bar. Seems to make it blend better from me. When it thumps, it's like the sound is actually coming from the sound bar.
AVR: Denon X2200W
Prime316 is offline
