New SVS PB-2000 and SB-2000 subwoofers (successors of PB-12NSD and SB12-NSD?) - AVS Forum | Home Theater Discussions And Reviews
Old 01-04-2014, 01:41 AM - Thread Starter
JStockholm's Avatar
Yesterday, a Norwegian SVS distributor released information on two new SVS subs that will be available from Jan 8th, 2014: PB-2000 and SB-2000.
http://www.lsound.no/nyheter/svs2000series_no/
This seems to be the successors of PB12-NSD and SB12-NSD, although it is not written explicitly.
The prices in Norwegian crowns (NOK) are 5.990 NOK ($975) for SB-2000 and 6.990 NOK ($1137) for PB-2000, and these prices include Norwegian VAT (25%) and shipping to home. Please note that SVS subwoofers are significantly more expensive here in Europe than in the US, so I wouldn't take these prices as indicators for the US pricing.
Details (in Norwegian -- use Google Translate if your Norwegian is rusty... ;-) can be read on:
PB-2000: http://www.lsound.no/hoyttalere/subwoofere/svs-pb12-nsd-dsp-black-charcoal-1617.html
SB-2000: http://www.lsound.no/hoyttalere/subwoofere/svs-pb12-nsd-dsp-black-charcoal-1618.html
For convenience, I will paste some translations below:
2000 series from SVS is hereby unveiled!
SVS is back on track with new subwoofers. This time it is a medium compact and super compact 12 "subwoofer series with integrated amplifier and DSP who are ready to give enthusiasts new and exciting film and music experience. The acting appears to be dry, with large and clean definition and authority, while remaining balanced and fast. Subs have very little egenlyd, and this, together with the powerful DSP, makes hardly be transparent and credible.
Extreme performance / price
Both PB-2000 and SB-2000 is equipped with the same 500W DSP amplifier, and the newly developed 12 "long stroke element from SVS. Sledge STA-500D is an energy-economic class D amplifier, which delivers 500 conservative and lavforvrengte watts and can take dynamic peaks up to 1100 watts when necessary. Speaker item with heavy rubber surround and frame in powder-coated aluminum has a number of innovative technical features which mainly involves keeping the element under control and reduce noise, non-linearity and distortion. The item is oversized where high temperatures can be a challenge, and thus will never experience a warm and stressed subwoofer starts playing distorted and instability noise and noise. Another neat touch is the integrated kabellissene to the voice coil, which eliminates the problem of noise and impact noise, which can be a real problem with hard use, even in otherwise expensive and fine subwoofers.
Structures
PB-2000 is about 30% larger than the SB-2000, but the specifications are otherwise quite similar. The exception is mainly the size and cabinet construction. PB-2000 is a bass reflex design with 4 "port while the SB-2000 is a closed construction. Port design of the PB-2000 involves large surface area and rounded flanges, eliminating the annoying whistle sounds and port noise. SB-2000 is closed, but despite this it is nevertheless deeply and with great authority, without the extreme distortion which unfortunately often characterizes small closed structures. Both models are available in black eikefinish, with removable rubber feet and a stylish curved grill. PB-2000 has external dimensions not exceeding 60cm while the SB-2000 is below 40cm. Because of cabinet construction and size, they naturally enough, a little different style of play, but both are they capable to take on all kinds of music and film genres.
Market leading rates
The price is, in known SVS-style, very favorable and reflect in any way the performance you can expect from an affordable subwoofer. The series is aggressively priced compared to how they look and especially how they perform. Prices are respectively 5990, - SB-2000 and 6990 - for PB-2000 including free shipping.
5% pre-order discount up to and including 15 January!
Specifications
SB-2000
16-240 Hz + / - 3 dB (4-5 Hz deeper frequency response in small and medium rooms)
Black Ash (black oak)
Front mounted 12 "element enclosure size: 37.1 (H) x 36.1 (W) x 36.1 (D) cm
Weight: 16kg
New SVS 12 "2000 series element
New Sledge STA-500D DSP amp
500W RMS continuous (1100W dynamic)
Variable variable volume control
Variable continuously variable phase control (0-180)
Variable infinitely variable low pass filter from 50-160 Hz - 12 dB / octave
RoHS-compliant, 100% lead-free and environment-friendly construction
PB-2000
18-150 Hz + / - 3 dB (2-3 Hz deeper frequency response in small and medium rooms)
Front-mounted 4 "bass port with rounded flanges
Case Size: 53.1 (H) x 43.9 (W) x 55.9 (D) cm
Weight: 30kg
Wired 80 Hz 12 dB / octave high pass filter RCA output
Even more details on:
PB-2000: http://translate.google.se/translate?hl=sv&sl=no&tl=en&u=http%3A%2F%2Fwww.lsound.no%2Fhoyttalere%2Fsubwoofere%2Fsvs-pb12-nsd-dsp-black-charcoal-1617.html
SB-2000: http://translate.google.se/translate?hl=sv&sl=no&tl=en&u=http%3A%2F%2Fwww.lsound.no%2Fhoyttalere%2Fsubwoofere%2Fsvs-pb12-nsd-dsp-black-charcoal-1618.html
GIEGAR likes this.
Combo living-room/home theater in old wooden house in Sweden. Pics: http://www.minhembio.com/jobeve Proj.: JVC DLA-X35 - Screen Elite PowerMax Tension 106" - TV: 65" Samsung UE65ES8005 - 7.1 Speakers: B&W 685 S2, HTM61 S2, Cambridge Audio Minx Min11, Sub: SVS SB-2000 - AVR: Denon AVR-X4000 - Player: Mede8er MED600X3D - NAS: Synology DS209 - Gaming: PS4
JStockholm is offline
Old 01-04-2014, 03:02 AM
BBS G35's Avatar
Quoted: 35 Post(s)
Liked: 43
16-240hz !?
The SB13 is "only" rated down to 20hz
BBS G35 is offline
Old 01-04-2014, 04:49 AM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 185
Lumenlab "Community driven video lab".
blake18 is offline
Old 01-04-2014, 05:07 AM - Thread Starter
JStockholm's Avatar
Originally Posted by BBS G35 View Post
16-240hz !?
Exactly my thought! Can it really be possible to squeeze such frequencies out of the small sealed SB-2000 box?! If so, why would anyone buy the much bigger and more expensive PB-2000?
Old 01-04-2014, 06:27 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1799
Previously (Nov./13) discussed in the official SVS thread, starting at this post.
eljaycanuck is offline
Old 01-04-2014, 06:35 AM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1220
^ ^ For the higher output above port tune. When someone gets their hands on these to independently test, we'll see if they have meaningful output at these frequencies.
Thanks for posting this @JStockholm.
JStockholm likes this.
GIEGAR is offline
Old 01-04-2014, 12:28 PM
Quoted: 73 Post(s)
Liked: 112
Will have to see what kind of output we're looking at, but I have faith in SVS putting out yet another couple great products. Although, not sure I like the metal grills; they look great, but I find they tend to fall out more than the more typical MDF/Fabric versions.
rnatalli is offline
Old 01-04-2014, 04:34 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
The PB1000 has a mesh grille.  I have a feeling the 2000 series might be mesh.  Might be a slight cost saving measure to focus more on getting a bit more performance while keeping the price point below 799 shipped.  Just my guess.
bear123 is offline
Old 01-05-2014, 12:39 AM - Thread Starter
JStockholm's Avatar
No need to get feelings involved when you can clearly see on the photos on lsound.no that the 2000 series has metal grills. wink.gif
Old 01-05-2014, 12:54 AM
steve nn's Avatar
Liked: 433
Don’t tell anyone but Ed has a new plan in reference to the grills. A new drill is in the budget I hear.. smile.gif
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 04-02-2014, 12:49 AM
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Any more comments from people comparing the SB-2000 to the SB12-NSD? The SB-2000 is a little pricier. BOTH are still in stock. Curious to know if anyone has been able to compare or has heard both?
Hardware and System engineer. Enjoy theaters, automation, media and the outdoors.
Love the hobby, but always have to remember to keep family first!
"The Escape Pod" - First Theater Build
danielrg is offline
Old 04-02-2014, 06:29 AM
JT78681's Avatar
Quoted: 1376 Post(s)
Liked: 900
Is it just me or do the SVS logos on the woofers look terrible? I mean I know the old PB12's had them too, but they were a little more subtle.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 04-02-2014, 06:31 AM
swargolet's Avatar
Quoted: 58 Post(s)
Liked: 26
Just so you are both aware, there is an ongoing thread about these two new subwoofers that is currently 31 pages long. It can be found here:
http://www.avsforum.com/t/1510324/new-svs-pb2000-and-sb2000-subs/900
Denon X4000 | Paradigm Studio 60s | Paradigm Studio CC-590 | Dual SVS PB-2000s | Sony VPL-HW40es | 110" Seymour Ambient Visionnaire 1.3 | Intel NUC i5 HTPC
swargolet is offline
Old 04-02-2014, 06:34 AM
JT78681's Avatar
Liked: 900
I know I just happened to stumble across this.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer
