Need advice on hooking up subwoofer to receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-05-2014, 05:33 PM - Thread Starter
Tagg7's Avatar
Hi, I just bought a subwoofer to go with my current 5.0 surround setup but I can't quite figure out how to hook everything up. Any help would be much appreciated!
This is a picture of the back of my receiver (VSX-821-K):
And this is the back of the subwoofer I just got (PSW108):
Do I connect the RCA cable on the subwoofer to the 'SURR BACK/FRONT HEIGHT' PRE OUT? I don't really understand what is meant by "Speaker Level Output", but perhaps I need to connect these ports on the subwoofer to the 'B' left/right outputs on the receiver? Note that I currently have speakers hooked up to the front, center, and surround outputs on the receiver.
I've perused the receiver manual and I'm still not sure. Thanks in advance!
Tagg7 is offline
post #2 of 2 Old 01-05-2014, 05:41 PM
eljaycanuck's Avatar
Quoted: 1226 Post(s)
Liked: 1798
You might want to try:
- from SUBWOOFER PRE OUT on the receiver;
- to either...
a) the left or right RCA input on the sub; or
b) using a Y-splitter, to both the left and right RCA inputs on the sub.
The owner's manual for the sub will tell you which way to go about it.
-- Edit --
The owner's manual (connection OPTION #1) says you can use the L or the R input, or both inputs. Your choice.
eljaycanuck is online now
Pioneer Vsx 821 K 5 1 Home Theater Receiver Glossy Black
