New SVS PB2000 and SB2000 subs!!!!!! - Page 48 - AVS Forum | Home Theater Discussions And Reviews
 76Likes
post #1411 of 1682 Old 08-16-2014, 09:19 PM
tezster's Avatar
Quoted: 410 Post(s)
Liked: 281
Originally Posted by jwtallguy View Post
Well a ported will show off a lot more output then their sealed subs, I can tell you when I run my svs in sealed vs ported its an increase of what feels like 3 times the deep bass or room shaking bass, maybe you need a ported also as I dont know your room or listening habits
You're right as far as the output of a ported sub goes compared to the sealed counterparts, I just don't quite have enough space for one... maybe one day when I have a dedicated media/theater room
Originally Posted by discone View Post
Glad to hear it was an improvement for you. I'm sure once it is broke in a little and loosens up the sound will only get better. I hear you on the cats and was glad they switched over to the metal grill. I was set to get the PB-1000 when I seen they were coming out with the PB-2000. I waited and saved a bit more to get it so as not having to worry about a cloth grill.
I watched Taken as my 2nd test movie. While it proved difficult to hear any increased output with Master and Commander compared to my old sub, there was no such concern with Taken. I've always loved the aggressive surround mix of this movie, and the concussive feel of the gunshots even moreso. The SB-2000 far and away sounded louder and more explosive.
tezster is offline
post #1412 of 1682 Old 08-16-2014, 09:31 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Originally Posted by avkiller View Post
Thanks for the advice... Looks like i might be getting dual PB2000's, the only other option to consider is a single pb13-ultra?
The pb13 ultra is clearly a better sub, but it is hard to choose one sub vs duals. If you have in mind that you would possibly get a second ultra later in the future, then I would go that way. The best thing about duals or more is having a great response across all seats. When you just have a single sub, there will be better seats than others when it comes to bass. Take it from me....I went with a single expensive/powerful sub at first and then realized that I needed more subs to get the response good in all seats. My $.02
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #1413 of 1682 Old 08-17-2014, 12:28 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
I was in a similar boat as you...i went from mirage omni s12 (similar to your energy) to one sb12NSD...as i watched a terminator i immediatelly noticed that something was missing...there wasnt so much room shaking bass as iwas used to when the robot was making that noise (i knew that when i went from ported to sealed) but overall bass was more difined and i also found what you said...that the boominess is gone. I purchased a second sb12 nsd three months later. I still dont know what a preffer a sealed or ported...i really like that there is no boominess but on the other hand i miss more room shaking bass in movies...now i am deciding if i would sell one sb12 and get one sb13ultra with one sb12 to flatten response...if i had a place i would go with one pb12+ or pb13 ultra because of the possiblities they offer (sealed or ported). If i could test sb13ultra and if it would get me a little closer to room shaking bass i would keep it if not i would send it back...but i live in europe...if i buy it i will have to have it...room is sealed around 1600cubic feet...or i could go with pb2000 but i am affraid that my room will excite all those low freq and will sound boomy again...so now i am 75% sure to get sb13ultra, just need a little more push over the fence from you guys please help
tommaazz is offline
post #1414 of 1682 Old 08-17-2014, 01:18 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
tommaazz, I went 20-39 PC Plus, PC Ultra 13, SB Ultra 13. Like you I didn't find the ported models offered the best for music. Also have SB12+ so tried that in the HT and not impressed compared to PC Ultra 13 so that only left SB Ultra 13 as an option.
Only in a small room 800 cu feet
fatbottom is offline
post #1415 of 1682 Old 08-17-2014, 01:41 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
Does it deliever enough slam in HT? I will never go dual sb13ultra as is just too expensive in Europe but i might get one and pair it with one of my sb12...is it a good idea? I have audyssey xt32 with subEQ HT so i think it might help a bit...the ultra doing a hard work and sb12 to flatten the response across the room...i watch and listen at around -15 (movies) -10 music...can sb13 ultra shake your room? I am thinking of buying it this week..because when i set my mind on something...i cant let it go till it is mine
tommaazz is offline
post #1416 of 1682 Old 08-17-2014, 01:48 AM
fatbottom's Avatar
Liked: 518
yes it does. I could also add SB12, either stacked on top or other side of the TV. I only have antimode 8033 cinema not individual and combines sub EQ like you.
post #1417 of 1682 Old 08-17-2014, 04:30 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
So could you say that the difference between sb12+ and sb13ultra is night and day especially in movies? Well you are pushing me over the fence and toward a sb13ultra very fast well thank you my wife will strangle me as this could be my third sub in less than a year and ihope it will be last for a long time at the end if i dont like mixing it with sb12 well i can sell the second sb12...one sb12will go to my brother
tommaazz is offline
post #1418 of 1682 Old 08-17-2014, 04:48 AM
fatbottom's Avatar
Liked: 518
Yes SB12+ to SB Ultra 13 is like night and day. You wouldn't think just a 1.5" bigger driver and double power would equate to such a vast improvement.
The SB12+ is in the other room for the 2 channel Hi-Fi. For that it's perfect. I sold the PC Ultra 13 and for a week moved the SB12+ to the home theatre, as I was thinking about single or dual SB2000 or perhaps dual BK XLS 400. But I wasn't impressed. Sure there was bass, superb for music (better than PC Ultra 13) but none of that scary room shaking for movies.
Have antimode 8033cinema, so ran it each time for PC Ultra 13, SB 12+ and SB Ultra 13.
If it can't give room shaking bass in a 800 cu foot room don't know how people are managing in rooms two or three times my size with single or dual 12" subs.
But I was doubting even if SB2000 duals would offer that gut wrenching impact the single PC Ultra 13 offered. I looked for a second SB12+ but they're hard to find. So thought it best to stick to driver I'm used to, just in a smaller package.
Remember it's not about max volume, as I wasn't reaching limits of SB12+ Same idea behind a AVR versus dedicated power I guess. Not impressed with AVR's capability in driving speakers, unlike even a budget 2 channel amplifier ie 60W outclasses most AVR's
The fnish on the Ultra is much better than the SB2000/PB2000 (unless you pay for the gloss finish) that bumps up the price another $100. The wood effect in just vinyl wrap on the Ultra it's real wood veneer. SB2000 gloss isn't that far off SB Ultra 13 money IMO.
SB12 + for movies...meh is that it?
SB Ultra 13...that's more like it.
Now SB Ultra 13 versus PC Ultra 13 is harder to judge. Of course the design of the ported has more headroom but would I need that in a 800 cu foot room? No way. I didn't even bottom out PC Plus 20-39 and that has several dB disadvantage to the PC Ultra 13.
I would like a SB Ultra 13 in the hifi but for 2 channel it's a bit too expensive, I would like the advanced features the Ultra 13 plate amp has, namely variable high pass and slope, and slope on the crossover, room compensation, 2 channel PEQ.
In fact I may look into REW and UMC-1 with two systems with subwoofer PEQ may be now worthwhile
post #1419 of 1682 Old 08-17-2014, 06:09 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
Well i think you just pushed me over so...thank you for draining my bank account i am just waiting for a mail from the shop to see if they can give me some discount...so sb13ultra.and sb12 it is...i doubt i will get it this week probably next...but i will post my impressions.as soon as i get it...
tommaazz is offline
post #1420 of 1682 Old 08-17-2014, 06:18 AM
fatbottom's Avatar
Liked: 518
haha
Have a think whether gloss black or blash ash would suit location, I think gloss black may be a distraction in HT from bias lights, light from screen etc. So went for black ash.
Wouldn't mind dual SB Ultra 13 but I think in a 800cu foot room it may be just a bit over the top. Perhaps if I find one really cheap.
post #1421 of 1682 Old 08-17-2014, 06:25 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
Black ash certainly...i dont like gloss too much...i hope it will rock and i dont regret it...if it will be a little more punch than thats it
tommaazz is offline
post #1422 of 1682 Old 08-17-2014, 06:30 AM
CHASLS2's Avatar
Quoted: 354 Post(s)
Liked: 125
Is there any real differance in my SB12 NSD and the SB2000?
Panny 60VT60 Acurus 200x3
OPPO 83 &103
Pioneer Elite DV 59AVI
Paradigm 490cc B&W 685 S2's
Pioneer Elite SC61 SVS SB13Ultra
2 S-VHS VCR's B&W CM10 S2's
CHASLS2 is offline
post #1423 of 1682 Old 08-17-2014, 06:56 AM
Quoted: 978 Post(s)
Liked: 506
Do you have any idea where you are going to put the subs? I am asking because the sb12 will run out of gas way before the ultra and should be placed closer to the listening position than the ultra. Before you go out and get two different subs, research a little bit on this forum about using two different subs. There is nothing wrong in doing so, but you need to know what you are getting into before you spend a lot of money. If you are out to get the most SPL out of two subs, you might want to go ported.
haha
I agree with the black ash for home theater for sure.
It is always great to have headroom. getting a second sub is always a good idea because the entire point of multiples is for great response. Of course you get a few added db's as well, but there is nothing better than quality bass IMO. There is a guy on this forum named miniht that also has a 800cf room with two JTR S2's! That is awesome! I have one of those subs so I know what it is capable of and couldn't imagine two of them in such a small room.
post #1424 of 1682 Old 08-17-2014, 07:15 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
Hi.i already have 2xsb12 so i was thinking of selling one to my brother and use the one i already have with sb13ultra.if i dont like results i can allways sell sb12. I will have both subs in the front corner...sb12 will be in the left were it will gain a db or two compared to right side. I hope it will work.
tommaazz is offline
post #1425 of 1682 Old 08-17-2014, 07:55 AM
fatbottom's Avatar
Liked: 518
You could always have stereo SB12 from the L/R, with SB Ultra 13 for LFE. Some work around with L/R bass management though, unless your pre has left & right subs and LFE sub pre-outs.
post #1426 of 1682 Old 08-17-2014, 08:41 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
No i will use max sb12 and sb13 or just sb13 depending on the results as this is in living room. I have marantz sr7008 and bx speakers from monitor audio
tommaazz is offline
post #1427 of 1682 Old 08-17-2014, 08:55 AM
daru2707's Avatar
Liked: 0
Hi everyone
Sorry to interrupt - but this is just the topic I need, so I thought I might join in
I already have my "own" thread regarding speaker choice because I'm upgrading now - special thanks to user dsrussell for really good advice and overall engagement
I also learned a lot about subwoofers and which ones to choose ( in theory ) but I'm really struggling, because I'm also torn between an SB-2000, or a PB-1000/PB-2000. The thing is - I can't audition them, because I live in Poland, so I need as many opinions as I can acquire. SVS recommended an SB-1000/2000 for my room size, which is ~1550 cubic feet. They told me though that while I will get very low bass for music that I want, there won't be much rumble and actual punch for movies, as well as music.
So I wonder would a PB-1000/2000 be a total overkill for my room size and would I be unhappy with it? I mean, could boominess, poor performance for music, etc happen? This is huge money for me, so I really want to make a wise choice.
To give a small comparison - I currently have a Microlab Solo 7C set in my room. It's not brilliant, but it was an improvement over my old Creative set. So to sum up, I have 55 Watts per speaker, so a total 110 Watts RMS power. Each speaker has a tweeter and 2 x 6,5" woofers. They are ported too. This is enough to give a small punch in the chest in my room - at loud volume though, and very boomy - which is something I want to avoid, because I like listening to music at moderate levels. So I figured even a sealed, but 12 (!!) inch sub would outperform those Microlabs in pure power ? I need a sub because at moderate listening levels - there is no depth or punch at all in my current setup, not to mention the quality gap between computer speakers and hi-fi gear.
What would you say is most suitable for my room? To excel both in music and movies? Shall I go with SB2000 or risk it with a ported model? Anybody using any of them around my room size ?
daru2707 is offline
post #1428 of 1682 Old 08-17-2014, 09:16 AM
Quoted: 978 Post(s)
Liked: 506
I would go with the pb2000. The only time I will suggest sealed is if there are many of them or the person is chasing the single digits in fq. IMO there is no such thing is overkill when it comes to subs. You can always turn the trim down and it is way better to have head room than not enough. Reading all of the reviews on both the sb and pb subs, the pb was good for music as well.
post #1429 of 1682 Old 08-17-2014, 10:20 AM
cel4145's Avatar
Quoted: 2652 Post(s)
Liked: 2984
You have to answer that question first.
If you have heard very high end subs in your area stores (think subs costing 2 to 3 times MSRP of the SVS), and you know you prefer sealed subs, then go with the SB-2000. Otherwise, the SB-2000 might have a slight edge in SQ which might not even matter to you if you compared them, but the PB-2000 will likely give you better deep extension, making it a bit more fun for movie watching.
If you are a basshead who likes heavy bass, or you know you will be listening to movies at very high volume, then go with the PB-2000. It has significantly more max output than the SB-2000.
If the size of the PB-2000 would severely limit placement options, whereas the SB-2000 would not, then perhaps the SB-2000 is the better choice. Subs perform differently depending on where you place then in the room, and you might get better performance in one location over another. The SB-2000s primarily advantage over the PB-2000 is that it's a compact sealed sub that is significantly easier to place in a room because of its small size and tends to make wives happier
Finally, you might read these reviews of the PB12-NSD and SB12-NSD, the predecessors of the PB-2000 and SB-2000. The SB-2000 will go a touch lower and a bit louder than the SB12, so you might read with that in mind:
http://www.audioholics.com/subwoofer...-nsd-subwoofer
http://www.audioholics.com/subwoofer-reviews/pb12-nsd
dsrussell likes this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #1430 of 1682 Old 08-17-2014, 10:50 AM
dsrussell's Avatar
Quoted: 2223 Post(s)
Liked: 3017
daru: I agree with everything P.I. and cel said. While all subs may reproduce sounds a little differently (doesn't matter if we are talking sealed vs sealed or ported vs ported, or sealed vs ported), I doubt in a blind test one could tell sealed from ported when playing music, but you may indeed hear and feel a difference with LFE in movies. I'll also add that there really isn't a thing called too much subwoofer for my room (except, perhaps, physical size limitations). Since you do not have the luxury of simply returning something that doesn't perform to your expectations and getting a bigger, badder sub to replace it without selling your sub and buying another, go for the sub that will give you the best performance for movies. If you have the room, I'd be leaning toward the PB-2000 of those subs mentioned.
And if it IS too much sub for music in your small room? Just turn down the gain a bit, when playing music.
jprzybilla likes this.
dsrussell is offline
post #1431 of 1682 Old 08-17-2014, 12:54 PM
cel4145's Avatar
Liked: 2984
Yep. And if you ever decide to move your setup to a bigger room, you would be glad you had the PB-2000.
cel4145 is offline
post #1432 of 1682 Old 08-17-2014, 01:40 PM
CHASLS2's Avatar
Quoted: 354 Post(s)
Liked: 125
Is there much of a differance from the SB12NSD and the SB2000?
OPPO 83 &103
CHASLS2 is offline
post #1433 of 1682 Old 08-17-2014, 01:42 PM
cel4145's Avatar
Liked: 2984
The SB12 supposedly has a bit better lower extension and a little more maximum output.
cel4145 is offline
post #1434 of 1682 Old 08-18-2014, 02:17 AM
daru2707's Avatar
Liked: 0
Thank you for replies !
Yes, that's what I thought - since it's a huge purchase and I won't have an option to return it I'm scared of getting disappointed. I also think that it's always way better to tame the beast than not to be able to bring out the beast at all. So a pretty convincing opinion, thanks
daru: I agree with everything P.I. and cel said. I'll also add that there really isn't a thing called too much subwoofer for my room (except, perhaps, physical size limitations). Since you do not have the luxury of simply returning something that doesn't perform to your expectations and getting a bigger, badder sub to replace it without selling your sub and buying another, go for the sub that will give you the best performance for movies. If you have the room, I'd be leaning toward the PB-2000 of those subs mentioned.
Yes I think it is an overall safer bet - so we have 3 opinions driving me towards the PB2000 The only thing I have to figure out is what amp/avr to choose with a sub-out and how to connect all this to make my PC the headquarters of music and movies. But I'll worry about it when I find those golden fronts
I actually never heard a sealed sub. I will because I'm going to audition some REL or Velodyne this week. I guess I am a basshead because I LOVE it ... but not as extreme as some. Well placing might be difficult because what I'm afraid of is this - I have a large long ( wide, not deep ) piano alongside one of my longer walls and that probably won't ever go out because I'm using it a lot and if I wanted to move it to my other, a lot smaller room, it would clump it up totally and probably sound bad. Along the other longer wall there is going to be a couch and there's a rather wide and tall cupboard, which I might get rid of, but not 100%. The point is - I've seen many people place ported subs along the wall, but moved away from the corner. That's also what SVS suggests for best performance/depth. Trouble is with my current furniture if I wanted to move the sub away from the corner ( given the size of the PB2000 which is roughly 2 times bigger than my current PC ) it would get sort of "covered" by either the piano or the cupboard, if you know what I mean. It might need to fit between the furniture, and shorter wall, so it wouldn't fire into open space. Would that be a huge disadvantage? In that case I would have to get rid of the cupboard I'm not using it anyway actually, it just adds atmosphere to the room because it's a pretty old-fashioned apartment. If I got rid of it though, I would have a lot room to dance with the sub.
Second problem - I live in a block of flats - fortunately on the 10th, last floor and my apartment is pretty well-ish isolated from the other 3 on my floor. The walls are thick and I never hear a single thing from the other flats - even though I do when I step out of my front door. So I guess my biggest concern would be the neighbours below me - but there are rubber isolation pads for subwoofers - also I'm changing floors in my apartment and I want to put some isolation into the one in my listening room. Not that I want to shatter my walls ( well ... more like can't ), but I like to crank up the volume from time to time and get a chest massage - would those additions help the PB-2000 to not bother people under me ?
daru2707 is offline
post #1435 of 1682 Old 08-18-2014, 06:29 AM
Quoted: 978 Post(s)
Liked: 506
No problem
Easy as you just said. When you find and avr that you want, just plug the sub out into the input on the amp on your sub. bypass the crossover on your sub (or turn the crossover all the way up) and run room correction on your avr. Done.
Connect your computer via hdmi cable from a good video card.
post #1436 of 1682 Old 08-18-2014, 09:07 PM
cel4145's Avatar
Liked: 2984
I wouldn't worry about getting disappointed with either the SB-2000 or PB-2000. They are both excellent subs
A lot of people think isolation pads won't help in your situation. What they mainly do is prevent cabinet resonance transfer in to the floor, and very good subs like SVS don't have cabinet resonance issues.
The little bit extra low end bass extension from the PB-2000 does mean you would potentially be sending a little bit extra bass output to your neighbors. In that regard, might be better to sacrifice that performance for apartment use.
Corner loading tends to boost low end bass output. That's why SVS doesn't recommend it, although for some bassheads (and for some rooms) it can work better.
For AVRs, I recommend Denon because Audyssey MultiEQ room correction software automagically EQs the sub to help improve the in-room response--most room correction software only EQs the speakers. That's especially a plus when placement options are limited. Also, check out the various streaming features that AVRs have now. You can use a computer as a music server and send the signal over your network. Marantz also uses Audyssey, and higher end Onkyos (but don't get Audyssey 2EQ; it doesn't EQ the sub).
cel4145 is offline
post #1437 of 1682 Old 08-19-2014, 03:20 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
Well i am just getting up from the fall over the fence that you pushed me ...sb13ultra is payed...just have to wait for next week to come when i will receive hopefully what will be a beast of a sub fingers crossed
tommaazz is offline
post #1438 of 1682 Old 08-19-2014, 06:28 AM
Quoted: 978 Post(s)
Liked: 506
Congrats! When you get it, dial it in and enjoy!
tommaazz likes this.
post #1439 of 1682 Old 08-19-2014, 01:39 PM
daru2707's Avatar
Liked: 0
Thanks for the replies again
Another pro argument for the PB-2000 is that today someone at a local store told me that a ported sub should dig deeper and more firmly than a sealed sub at lower volume levels - which would be just perfect for me, for music at least.
As for AVR's - the models I'm going to audition ( with fronts ) and I got highly recommended are Marantz MCR610, Marantz 5005, HK 3770, Yamaha R-N500, Teac 750. They have what I need - apparently good sound quality, easy connection to the PC, sub out, just brilliant.
If they don't include the Audyssey - I should be able to tune the sub to my liking and room environement "manually", right ?
daru2707 is offline
post #1440 of 1682 Old 08-19-2014, 05:40 PM
Quoted: 978 Post(s)
Liked: 506
Even with Auddyssey, I would still manually tune the sub.
Klipsch Rw 12d 12 Subwoofer Each , Svs Pb2000 , Svs Sb2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
