New SVS PB2000 and SB2000 subs!!!!!! - Page 50 - AVS Forum
post #1471 of 1499 Old 08-31-2014, 12:00 PM
MIX_MASTER_ICE's Avatar
Quoted: 66 Post(s)
Originally Posted by tlb48 View Post
i don't have a good corner due to doors and openings would 4' from a wall make a big difference in sound of a pb2000 ?
I'm far from an expert on subs, but from my experience the further away from a wall the output tends to drop. 4' is pretty far away from a wall for a sub. As mentioned, the room itself and the layout plays a big part of the equation.
MIX_MASTER_ICE is offline
post #1472 of 1499 Old 08-31-2014, 12:24 PM
Pain Infliction's Avatar
Quoted: 156 Post(s)
Liked: 198
So the sub is four feet away from all walls near the middle of the room? I was thinking that the OP was saying that the sub was four feet from the other wall and not in the corner.
MY THEATER......The Thompson Theater 11.9 channels
"Is not love not unlike the unlikely not it is unlikened to?"
- Leon Phelps
Pain Infliction is offline
post #1473 of 1499 Old 09-06-2014, 12:31 PM
tlb48's Avatar
i said that wrong, it is on a wall near what would be a corner wall but instead is a 4' opening to another room. also is there a break in period on the pb2000
tlb48 is offline
post #1474 of 1499 Old 09-06-2014, 03:41 PM
DocCasualty's Avatar
Quoted: 37 Post(s)
Liked: 217
If I understand you correctly, I have a somewhat analogous situation. My front right corner is an open doorway to an alcove, which is closed off otherwise by a door to a bedroom that leads from the alcove. I have the PB2000 ~ 1 foot from that doorway on the right half-wall , which divides the room there from an open stairwell going downstairs. I have the sub pointing away from the right wall toward the middle of the room, almost exactly inline with the front speaker plane, with a leather love seat alongside it on its other side. This spot was a good one on my sub-crawl and I'm thankful for that as it's a good spot for aesthetics and function too.
I would consider myself one of the least expert posters on this board about subwoofers but as many say, that particular sub in that particular room and its placement will be the deciding factor whether it works or not. My listening area is the living room portion of a great room, constituting probably one-third of a 30X25+ sq ft room, with vaulted ceilings (multiple peaks up to ~ 12 ft), with an open stairwell, the above noted alcove and a long hallway off the opposite side, adding up to well over 7000 cu ft. Its a complicated room with half-walls, many acute corner angles, wall to wall carpet (wood subflooring) except for the adjacent kitchen with wood flooring, fieldstone fireplace, some drywall walls with art (or not), a wood covered wall and wallpaper and cabinets in the kitchen and dining areas. By "the numbers" this sub should be woefully inadequate by what I've read and learned here and elsewhere, however, I think it sounds fantastic.
It is a very bass responsive room but not "boomy" nor is the sub. I'm finding the LF bass in music to be quite clear and I've been listening obsessively to all kinds of heavy bass music since I got it last week, as well as my usual gamut of A-Z (Alternative to Zydeco) tunes and find it quite musical. The even bigger bonus is that it rumbles the listening area and me with the infra-20 Hz special effects in movies. I just finished watching Das Boot (BD with DTS-HD-Master soundtrack), which has a great SF/X soundtrack to begin with, and those depth charges, bombing runs and wave crashes are concussive and visceral. Same with Saving Private Ryan and Pacific Rim. As I've read posts from others who consider the PB2000 anemic in rooms the size of my smallest bedroom, I can only conclude that their room acoustics are seriously working against them, or they have some expectation from a SW that I could not even begin to understand. In a nutshell, I do believe this big room with all of its complicating factors ends up truly working for me. Apparently I got lucky.
This PB2000 is replacing a Paradigm PDR10 that suddenly developed its own rattle after many years of good service. Frankly, I was pretty happy with it and started off thinking I was going to replace with a budget 12" sub but after a few pieces of sound advice on the budget sub thread, I did a little more research and opted for this excellent SW. I'm not a "basshead" by any stretch but cannot believe I could utilize more than what this sub delivers. My volume listening habits are pretty tame too, so I've yet to test this unit to its extreme either. I'm not even sure why I chose this sub over others at a similar price point, once I decided to up the ante, other than what I was reading about it and SVS, which made sense for me.
So what's my point? My suggestion, as I'm in no position to give advice, is to try it. The return policy on these is insane, which is great for the consumer. If it doesn't work you really have lost nothing. As far as a break-in period, I'm sure there is one. I bought this one as an outlet special. It has a nearly invisible "bubble" in the vinyl rap in a corner that's hidden where I've placed it anyway, so I don't know if it's a return that's been used awhile or a new blemished unit. It keeps sounding better to me FWIW.
BTW, at this point I have just dialed it in myself with my piddly Audyssey 2EQ, which doesn't even equalize a SW. I'm planning on talking to the SVS guys still to see if they have anything to add for further benefit. I don't have any calibrating gear but can tell I get some volume drop somewhere between 45-50 Hz and somewhere between 55-60 Hz just by listening to a low end sweep. Unscientific I know, so maybe I'll get one of those USB mics and try REW one of these days. Walking around the whole great room I can certainly ID nulls, though it's of little relevance as 99.9% of all listening is from my wife's and my recliners, which by ear are nearly identical and where all of the sound is focused. It certainly begins to rattle the room by 10 Hz and appears pretty solid to me by 15 Hz, hence is living up to its reputation of digging deep.
"Dave, this conversation can serve no purpose anymore. Goodbye." - 2001:ASO
DocCasualty is online now
post #1475 of 1499 Old 09-14-2014, 02:18 PM
Gerardo2068's Avatar
Quoted: 30 Post(s)
Hello All,
I'm new to stereo systems but I recently got me a Rotel RA-1570 Integrated amp and a pair of B&W 683 S2 for music only. For 80% of the music I listen the tower loudspeakers are awesome. Love the highs and vocals are great. Bass it's great too specially with live music, jazz and plenty of other genres. I listen to just about everything including modern music like electronic, dance and hip hop. Personally I think I would benefit from some subs. I posted this on other threads but I was told the 683s should be plenty good on bass. I believe music styles plays a roll and they may be right but I fell I need some subs just to bring up the lower end, in a balance way. No overpowering the main satellite speakers at all and cross over smoothly.
The 683s specs says, Frequency response 52Hz - 22kHz ±3dB on reference axis and Frequency range -6dB at 30Hz and 50kHz.
I'm not expert but I'm thinking below 52Hz it's not loud enough. My living room is open to the kitchen and dinning room so may be the room is too big? I have high selling that starts about 10 feet and goes up to about 16 feet. the room is about 19 feet wide and length is about 16 feet to the point where the kitchen and dinner starts but there not wall in between.
So after reading online I decided to buy me one SB-2000 now with plans of getting a second one later. It will get here in a few days so I would like to ask for some information on how I go about setting it up. I will continue to research online but I would like to know what you guys think.
What should I look for? I was planning on putting it right beside the left speaker tower? It's that ok? It's there a starting Hz level I should set the Low Pass Filter to start with?
I heard they got CDs with tracks design to test the setting of crossover but I don't have a CD player at the moment, is there a website where I can buy the tracks online?
What else should I look for? Thanks. Your help it's appreciated.
Gerardo2068 is online now
post #1476 of 1499 Old 09-14-2014, 02:28 PM
fatbottom's Avatar
Quoted: 454 Post(s)
Liked: 200
With those speakers, I'd play with crossover no higher than 60hz. Also you may want to use the high pass filter in the sub, if your integrated has pre-out and main in.
Personally I don't think a sub is required in music system if you have floorstanders. I have collection of standmounts, tower, and subs, home theatre and hifi.
Krell Evolution 900e x 7
Bose Jewel speakers.
Jealous of my speakers?
fatbottom is offline
post #1477 of 1499 Old 09-14-2014, 02:34 PM
cel4145's Avatar
Quoted: 246 Post(s)
Liked: 780
With the Rotel RA-1570, I would try the left/right pre-outs/main-ins. If you run those pre-outs to the SB-2000, and then run the SB-2000 outs back to the main ins, the sub will put a high pass filter at 80hz on the signal sent back to your amp. Then you set the low pass filter dial on the SB-2000 to 80hz. That gives you a higher crossover. You may or may not like that.
You also have a second set of pre-outs up near your analog inputs. Not sure if that's volume controlled or not (should be since labeled "pre-out"). If so, you can run that to the SB-2000 inputs. Then set the low pass filter dial on the SB-2000 to around 50hz and tweak from there. Might like it a bit higher. Or a bit lower. The idea is that you are trying to match the high pass filter with the low end roll of your speakers.
In both cases, you would adjust the gain (volume) on the SB-2000 to match the volume of your speakers.
HT: Energy RC-50, RC-LCR, Veritas VS Surrounds | Dual CHT SS 18.1s | Denon AVR-888 | modified Dayton SA1000 | Antimode 8033C
Desktop: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | HK 3390
Headphone & Portable HE-400 | K612 Pro | HP150 | DX50 | E12
cel4145 is online now
post #1478 of 1499 Old 09-14-2014, 03:06 PM
Quoted: 37 Post(s)
Liked: 217
Try the subwoofer crawl. Worked for me and everybody seems to recommend it. http://www.audioholics.com/home-thea...ofer-placement
I don't know but you can find test sweeps and test tones on YouTube.
Lastly, don't hesitate to contact the guys at SVS for help. Enjoy that new sub!
post #1479 of 1499 Old 09-14-2014, 03:22 PM
Quoted: 30 Post(s)
Thanks!! That was a lot great information and helped me understanding better the goal here. I like the the idea of connecting them to the Pre-out beside the analog plugs and set it as low as I can like 60 or below because I really like how the 683s sound and I'm just trying to bring some of the sound below 50-60Hz up to balance the rest of the system.
post #1480 of 1499 Old 09-17-2014, 04:43 PM
Quoted: 30 Post(s)
Got the SB-2000 on the mail and I set it up.
I mess with it a bit and right now it's about 60hz, the main speakers are rated 52hz-3 and i use my ear and an iPad app slp metter. I do not own a real one but just to have a guide for now. I play sine wave at 60hz and try to match the metter to the same reading and level. Alternate the speakers and sub switch speaker channel on and off.
Now that it's to my liking for now if I play the sub only I can see that it barely play any music at all. Just a bit of the low bass and a bit of thump.
But I feel that even that little bit brings the balance I'm looking for. So the speakers alone will not go deep enogh but the sub just beraly puts out sound but I feel that was that some b&w 801 would have been the best choice of speakers for me but hey are way out of my budget lol
So I'm happy with the sound I'm getting so far. I really like the vocals and highs of the 683 s2 a lot. I will probably adjust the sub some more after many more hours of listening.
post #1481 of 1499 Old 09-17-2014, 10:59 PM
fatbottom's Avatar
Quoted: 454 Post(s)
Liked: 200
"I play sine wave at 60hz"
Wrong tone, you want a wide band pink noise, your AVR has it.
post #1482 of 1499 Old 09-18-2014, 03:49 AM
Quoted: 30 Post(s)
Oh ok I will try that
post #1483 of 1499 Old 09-18-2014, 03:58 AM
fatbottom's Avatar
Quoted: 454 Post(s)
Liked: 200
Also try white noise, I believe that is better suited to subwoofer calibration, in a Hifi.
Generally I just play by ear, I do think sub integration in a hifi is far more complex. In a HT I just bypass subs own crossover, use AV pre-amp test tones and it's spot on. For a Hifi, because I send L/R speakers full range (they're not) and send full range to sub using subs own crossover there is a lot more fiddling going on.
I guess using something like UMIK-1 and REW should help as you can see where the speakers drop off, and where the sub should be set to, as well as levels, and if you have room nodes.
I may pickup UMIK-1, with two main systems and PC system, and another HT it will come in handy.. also whether sub EQ is needed for two systems.
post #1484 of 1499 Old 09-18-2014, 03:15 PM
Quoted: 30 Post(s)
Not experience on this stuff, I'm just going by what I read lol. Not scientific at all but I use an app on my iPad. I placed the iPad on the listening position. I end up bringing the sub low pass filter to 50hz. I played white noise mono because balance would not play to the sub.
This is some screenshots I took. Not sure, but i think my gold was to bring the low frequencies below 60hz up a little. Looking at the graph look like the sub probably was not needed but I like the more complete sound when listening to electronica or bass driven music.
Room with stereo off, Only speakers and white noise, and speakers with sub.
ID:	268578   Click image for larger version
ID:	268586   Click image for larger version
post #1485 of 1499 Old 09-21-2014, 07:37 AM
handyman1's Avatar
Does anybody has a coupon for the PB2000 ???
handyman1 is offline
post #1486 of 1499 Old 09-25-2014, 08:21 AM
Andytrackk's Avatar
Only 1 month after being able to get its drivers license, my Velodyne HGS-10 peacefully passed away while sleeping Tuesday evening. It will be remembered as being loud, and having a crappy amplifier.
Though mourning, I was inspired to order a SVS SB-2000 in replacement yesterday.
I'm so excited that I wrote this ridiculous post.
nashou66 and gman086 like this.
Sony HW50ES projector
Pioneer SC-1523-k
B&W CM5 (front)
B&W CMC2 S2 (center)
B&W 686 (surround)
SVS SB-2000
Andytrackk is online now
post #1487 of 1499 Old 09-25-2014, 08:24 AM
cel4145's Avatar
Quoted: 246 Post(s)
Liked: 780
Will the SB-2000 attend the funeral?
post #1488 of 1499 Old 09-25-2014, 09:30 AM
Quoted: 37 Post(s)
Liked: 217
And I see you've placed the SB-2000 in your signature before the amp had time to go cold on the old warhorse!
I suggest the new SW participates in the funeral for the Velodyne by playing the following lament. Those drum rolls out of the new SB-2000 should quickly heal the pain of your loss.
dsrussell likes this.
post #1489 of 1499 Old 09-25-2014, 09:34 AM
mylan's Avatar
Quoted: 37 Post(s)
Liked: 59
I have an HGS -10 that is about 17 years old and I would love to hear your impressions of the SB-2000 over the Velodyne.
mylan is online now
post #1490 of 1499 Old 09-25-2014, 10:40 AM
Andytrackk's Avatar
Absolutely, I'm very curious myself!
I was very temped by an open-box B&W ASW10CM, but the price of the SB2000 is still so much better (even if it doesn't match my speakers)
Pioneer SC-1523-k
B&W CM5 (front)
B&W 686 (surround)
SVS SB-2000
post #1491 of 1499 Old 09-25-2014, 11:42 AM
cel4145's Avatar
Quoted: 246 Post(s)
Liked: 780
What's wrong with you????
Couldn't you find a copy of "Ode to a Velodyone sub?"
post #1492 of 1499 Old 09-25-2014, 09:47 PM
ohioratrodder's Avatar
Liked: 0
would 2 pb-2000 be enough for a 6500 cubic feet open basement? subs will mainly. used for movies
ohioratrodder is offline
post #1493 of 1499 Old 09-26-2014, 04:03 PM
Quoted: 37 Post(s)
Liked: 217
IMHO, yes, but it probably depends in no small part on your room and its response in the bass region. I recently replaced a much smaller and less powerful SW with a PB-2000 in a >7000 CuFt room and was blown away by the difference. Concussive and visceral was my description. Das Boot, U-571 and the opening sequence to Saving Private Ryan convinced me I had been missing the home cinema LF experience previously, though I I was not unhappy with the bass I previously had. My experience with this SW is that it is tight musically as well.
In addition, your plan for dual PB-2000s should work out great. Though again, your room and placement of these subs are both critical to the final sound product.
I claim no expertise in subwoofers, although I've learned a lot recently in my experience and by reading on the subject here and elsewhere. My Paradigm PDR-10 developed a rattle and that's why I bought a new SW. Recently I opened up the PDR-10, discovered the foam surround had failed, replaced it and now have incorporated both SWs into my setup with excellent results. For me the volume, deep extension and "chest thump" from the PB-2000 was more than adequate on its own set at modest gain, though now I understand the impact of dual SWs for smoothing the frequency response across the bass range and throughout the room. I also learned when my FR produced a frank void at 80Hz, simply by listening to a frequency sweep how critical a role phase plays in multiple SWs is. A quick check revealed that 80Hz equals a 14 foot wavelength and lo an behold, I was looking at the two SWs sitting about that distance apart. I reversed the polarity 180 degrees on the SVS (not an option on the Paradigm) and bam, problem gone.
Hopefully more expert opinions will come forth but if you have some latitude with sub-placement, I can't imagine that combo not being killer in your HT.
post #1494 of 1499 Old 09-27-2014, 04:05 PM
mnc
mnc's Avatar
Quoted: 52 Post(s)
Liked: 67
Still no word on a PC2000???
gman086 likes this.
NHT speakers, Denon 4520, 65VT50
mnc is offline
post #1495 of 1499 Old 10-01-2014, 08:13 AM
Andytrackk's Avatar
Some initial impressions:
The SB-2000 doesn't have the power of the HGS-10, but I think this is almost irrelevant for me. (also, 50% volume on the HGS = 75% on the SB-2000)
The SB-2000 simply fills my 16x14 room better.
The HGS-10 is a bit sharper with quick notes, but the sound itself has a rougher tone. In comparison, the SB-2000 feels smooth and sound fx in movies are more realistic to my ear. The SB-2000 disappears better.
The SB-2000 is better at very low frequencies as well, but I was never impressed with the HGS-10 in this realm.
I still need to play with placement and I just ordered a new receiver so maybe all this will change!
mylan likes this.
Pioneer SC-1523-k
B&W CM5 (front)
B&W 686 (surround)
SVS SB-2000
post #1496 of 1499 Old 10-02-2014, 05:46 PM
mylan's Avatar
Quoted: 37 Post(s)
Liked: 59
Thanks for that assessment Andytrackk, that's about what I figured, an improvement but not a huge one. Probably not enough to make me consider the SB 2000 as a replacement. I probably also should consider the room, it is a dedicated theater room 15x18 but open to a billiards room and open to the upstairs by a stairway that can't be closed off, also carpet over concrete. I had to move my HGS 10 near field behind my seating to get any decent output. I had thought of the SB 13 because I do love the sealed sound but I am not married to a sealed sub and may have to go to a PB 2000 to get any decent output.
mylan is online now
post #1497 of 1499 Old 10-14-2014, 09:22 AM - Thread Starter
nashou66's Avatar
Liked: 53
SVS just announced the PC-2000 !!!!!!
http://www.svsound.com/subwoofers/cy...34459-33861833
I love the Piano Black finish on the top!!!!!
Oh Man !!!!
Name:	Screen Shot 2014-10-14 at 12.21.32 PM.png
ID:	311186   Click image for larger version
Name:	Screen Shot 2014-10-14 at 12.32.13 PM.png
nashou66 is offline
post #1498 of 1499 Old 10-14-2014, 08:35 PM
tyler webb's Avatar
Just ordered a PB-2000 today! Very excited, how long do these subs take to ship and be delivered. I know I will very some by your location. But just looking for some kind of idea(timeframe). Thanks
tyler webb is offline
post #1499 of 1499 Old 10-15-2014, 12:16 AM
dsrussell's Avatar
Quoted: 306 Post(s)
Liked: 378
^^ From Ohio to California it was around 4 days. Congratulations on your purchase!
tyler webb likes this.
dsrussell is offline
post #1500 of 1499 Old 10-19-2014, 05:09 PM
abajetta2's Avatar
Quoted: 14 Post(s)
Liked: 32
Dont know if these have been posted before, but heres some pics of the inside of my soon to be FS: PB-2000...
ID:	320626   Click image for larger version
ID:	320634   Click image for larger version
ID:	320642   Click image for larger version
ID:	320650   Click image for larger version
Power - Denon AVR-E300
L/R
- JBL Studio 530
Center - JBL Studio 520C
Surrounds - JBL ES20
Sub - SVS PB-2000
Display - Samsung UN65H6350
abajetta2 is online now
Klipsch Rw 12d 12 Subwoofer Each , Svs Pb2000 , Svs Sb2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
Gear in this thread - Pb2000 by PriceGrabber.com
