New SVS PB2000 and SB2000 subs!!!!!! - Page 56 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #1651 of 1669 Old 01-02-2016, 11:15 PM
Dom Di Stroia's Avatar
Quoted: 174 Post(s)
Liked: 88
Originally Posted by Dragon Reborn View Post
Would it also be a worthwhile improvement for low frequencies if we listen at moderate volume levels?
No.
A/VR: Sony STR-DE598 (6.1 channels)
L/R + C: 2 x BIC Venturi DV62si + 1 x Boston Acoustics CS 26 II
Subs: BIC RtR RtR-12S + Polk Audio PSW110
Surrounds: 2 x Klipsch Synergy B-20 + 1 x Boston Acoustics CS 26 II
Monitor: LG 24EA53V-P (Panel: LG Display AH-IPS)
Display: Samsung UN-46EH6000F CS01 (Panel: InnoLux S-MVA)
Dom Di Stroia is offline
post #1652 of 1669 Old 01-04-2016, 06:17 AM
Dragon Reborn's Avatar
Thanks, Dom.
Approximately, what volume levels would I need to listen to make this (dual HSU STF-2 to dual SVS PB-2000) a good upgrade?
Dragon Reborn is offline
post #1653 of 1669 Old 01-04-2016, 10:30 AM
Quoted: 174 Post(s)
Liked: 88
Thanks, Dom.
The same volume levels at which the distortion becomes perceptible to the listener.
post #1654 of 1669 Old 01-05-2016, 02:00 PM
Liked: 0
Originally Posted by smjbh5 View Post
I just hooked up my PB-2000 to my yamaha 675 avr. I'm running the avr's calibration thing, YPAO, and set the sub's volume to the 12 o'clock position. The avr then set the level to +5.5db. I have to crank the volume up to at least the 3 o'clock position to get the avr to set the level to a negative number. I have a klipsch sub12 and the volume knob was set to the 12 o'clock position, the avr set the level to -8db. Is there something wrong? Plus I can't really hear/feel any difference between the 2 subs.
Hello,
I' just received my PB 2000 and I have the same issue...
Could you update your thread to say if it was an amp issue ?
Thanks and regards
Cdelefil is offline
post #1655 of 1669 Old 01-14-2016, 04:31 AM
tyler webb's Avatar
Quoted: 92 Post(s)
I think my amp is going out also. When I run Audassy the mic can not heard my sub at the 12 o'clock position. Audassy asks me to level match and I have to turn the sub volume full blast and still can't get it to 75db. The loudest it will register is 68db. Has anyone else had this problem?
tyler webb is offline
post #1656 of 1669 Old 01-14-2016, 04:40 AM
MIX_MASTER_ICE's Avatar
Quoted: 941 Post(s)
Liked: 683
If you have a subwoofer in a lousy spot in your room, you'll have to increase the gain more so than a good location or perhaps a corner to achieve the same dB.
MIX_MASTER_ICE is online now
post #1657 of 1669 Old 01-14-2016, 04:51 AM
tyler webb's Avatar
Quoted: 92 Post(s)
It's In the right rear corner. Use to sound great now very muted
post #1658 of 1669 Old 01-14-2016, 06:33 AM
tyler webb's Avatar
Quoted: 92 Post(s)
Talked to SVS they are sending me a new amp section. Excellent customer service! I would recommend them to anyone!
post #1659 of 1669 Old 01-14-2016, 06:51 AM
hpp8140's Avatar
Quoted: 206 Post(s)
Liked: 65
Sounds like what happened to my SB-1000. At first it hurt my ears, then I couldn't get much output even turned the gain all the way. Returned, since I bought locally, waiting for new shipment.
LN55C630
PN64F8500
Definitive SSA-50
GE Supercinema 3D Array X
Paradigm Millenia CT
hpp8140 is offline
post #1660 of 1669 Old 01-14-2016, 01:21 PM
jwtallguy's Avatar
Quoted: 117 Post(s)
Liked: 52
If you have a rca to headphone jack cable you can check out the amp on the sub very easily.
jwtallguy is offline
post #1661 of 1669 Old 02-18-2016, 07:59 PM
Quoted: 42 Post(s)
Liked: 3
Do the Isolation Feet really work? I got some rattles I need to get rid of
LedBizkit is offline
post #1662 of 1669 Old 04-09-2016, 09:18 AM
missyman's Avatar
Quoted: 26 Post(s)
Liked: 29
Yes they work. I got some for my pb2000s and I have hard wood Floors and I noticed a significant difference.
missyman is online now
post #1663 of 1669 Old 09-09-2016, 10:03 AM
Methodical_1's Avatar
Quoted: 84 Post(s)
Liked: 24
Curious. How?
My HT setup: Panasonic Plasma (TC-P62s2) l Denon X4300H l Monolith 7 Amp l Behringer FBQ3102 EQ l Polk RTi10s l Polk CSI-5 l Polk FXi-30s (x4) l SVS PB-2000 l Denon DCM-280 CD Player l Oppo BD-93 l Denon DP-300F TT l Cassette Deck
Methodical_1 is online now
post #1664 of 1669 Old 09-11-2016, 10:25 AM
Quoted: 84 Post(s)
Liked: 24
With the sledge amps you can run it at 100% volume to match the speakers but never push the avr trim past 0...
Why is it not advisable to run avr trim past 0?
post #1665 of 1669 Old 09-11-2016, 10:27 AM
Ben Tan's Avatar
Quoted: 144 Post(s)
Liked: 106
Most AVRs clip the sub signal above 0db.
Bedroom Theater
Sony KDL55-W900a | Yamaha RX-A2050 | Emotiva XPA-3 Gen 2
SVS Prime Bookshelf L/R | SVS Ultra Center | Dual SVS SB2000
SVS Prime Satellites SL/SBL SR/SBR | SVS Prime Satellites Height Presence L/R
Ben Tan is offline
post #1666 of 1669 Old 09-11-2016, 12:18 PM
Quoted: 84 Post(s)
Liked: 24
Thanks for the response. What do you mean by clip the signal and is there a way to determine which AVR does this?
post #1667 of 1669 Old 09-11-2016, 05:50 PM
Quoted: 174 Post(s)
Liked: 88
https://en.wikipedia.org/wiki/Clipping_(audio)
post #1668 of 1669 Old 09-11-2016, 08:19 PM
Quoted: 84 Post(s)
Liked: 24
Originally Posted by Dom Di Stroia View Post
Dom Di Stroia likes this.
Klipsch Rw 12d 12 Subwoofer Each , Svs Pb2000 , Svs Sb2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
