Dual SVS PB-2000s to replace dual ChaseHT SS-18.1s. Worth it? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 01-10-2014, 08:55 AM
MKtheater's Avatar
Quoted: 1589 Post(s)
Liked: 1116
No, not ringing, you are talking +/- 2.5 dBs and how we listen, 1/6th smoothing the line is flat. I have a little crossover work to do at 80hz but that is it. This is a mighty $229 Sony AVR LFE out!
Marantz 7702 Atmos
MKtheater is offline
Old 01-10-2014, 09:10 AM
steve nn's Avatar
Liked: 433
Originally Posted by MKtheater View Post
Here is my response
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
Old 01-10-2014, 09:30 AM
BeeMan458's Avatar
Liked: 813
Thanks. I should be so lucky to get such a nice graph. Today I put a receiver into play that has XT32/SubEQ HT so I'm holding out hope for an improvement.
Here's the before XT32/SubEQ HT graph; two FV15HPs:
Nothing close to the extension you're getting. Once the receiver is up and running, I'll see what I can do to extend the left side of the graph as I should be getting five Hz more. Still, nothing close to what you're getting.
BeeMan458 is offline
Old 01-10-2014, 09:40 AM
steve nn's Avatar
Liked: 433
Hey Bee.. This is a old quote from Brian/Rythmik. You might see if you can break all the rules and incorporate the BASSIS and see what you can come up with.
The Marchand BASSIS unit and the BFD are really different animals. The BFD is a parametric EQ whereas the BASSIS is an adjustable Linkwitz Transform Circuit. The BASSIS will allow you to lower the low frequency response of a sealed enclosure by adding boost but at the same time you can adjust the Qtc of the entire system.
So I don't think you can really compare the two. Actually, when I get my huge 18" sub built I'll use either the BASSIS unit or a custom built LT circuit strictly for my sub AND a BFD (to tame any peaks).
Brian
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
Old 01-10-2014, 09:45 AM
BeeMan458's Avatar
Liked: 813
I'm way over my head as it is. Getting a new receiver up and running with XT32/SubEQ HT and subwoofers worth a Tinker's Damn is far more than I every dreamed possible.
If I were to try and break any rules, I'd like to do so by adding a PSA XS30. If I did that, I'm told that I'd be messing with the whole time continuum thingy and last I read, that's not good.
(Excuse me, Egon, you said crossing the streams was bad.)
steve nn likes this.
Old 01-10-2014, 12:05 PM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
although CR has successfully integrated two PB ultras, and an xs30...just sayin'
Brian Fineberg is offline
Old 01-10-2014, 12:31 PM
BeeMan458's Avatar
Liked: 813
Thanks. I'll ask him what the process was for his success.
Old 01-10-2014, 01:13 PM
Cowboys's Avatar
Liked: 107
I think the problem is your mic is not calibrated to measure below 20hz. You will find out if your graph will be similar with your Denon 4520.
Cowboys is offline
Old 02-25-2014, 06:38 PM - Thread Starter
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
Today I spent ~5-1/2 hrs. trying out a few combinations of spots for my subs:
1. Front left inside (between left main and CC) and back right corner (in front of the half wall).
2. Front left corner and front left inside.
3. Front left corner and front right inside.
After all that, the best spot for the subs turned out to be....their usual spots: Front left inside and front right inside.
I get the best overall FR there, flat to - but, dammit, never below - 17Hz.
In the FR graph:
- brown is the left seat (Audyssey on)
- red is the middle console (Audyssey on)
- orange is the middle console (Audyssey off)
- black is the right seat (Audyssey on)
eljaycanuck is offline
Old 02-25-2014, 06:42 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5210
Aside from what graph looks the best, what position do the subs sound the best?
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 02-25-2014, 06:47 PM - Thread Starter
Liked: 1800
I didn't actually audition each of the combinations of positions. Basically, after gain-matching the subs, I:
- put them in a position;
- ran the first cycle of Audyssey;
- measured the subs with Audyssey off and then with it on.
All of the positions were roughly equally flat up to crossover. Position 1 offered the worst extension - it was down by 6dB from peak at ~25Hz. Positions 2 and 3 were better, but because they were almost comparable to the "usual spots", I opted to go with it for symmetry because:
- I like symmetry cool.gif ; and
- the system still sounds good set up that way.
Although I'm not in a hurry to do it again any time soon, it was a pretty interesting exercise. smile.gif
Svs Pb2000
