Best performing sub under $700 - AVS Forum
post #1 of 116 Old 01-09-2014, 10:54 PM - Thread Starter
ender006's Avatar
Im looking to get a better overall experience in movies and music. My supercube 4000 just isn't cutting it. I gave it 6 months but im not happy with the performance. Im currently running def tech 8040 towers, 8060 center, and bp surrounds off an older txh01 pioneer elite receiver. Was planning on using the pioneer as a pre amp and pick up a starter emotiva xpa amp. But i want to get rid of the supercube. Room is 23x18 with vaulted ceilings. I was going to pull the trigger on an outlaw LFM-1 EX but thought i would get some feed back this time. Enclosure size doesnt matter but the wife would kill me if i went over $700. Any feedback is much appreciated. Thanks
And I know i shouldn't have got the supercube in the first place. My mistake. Was trying to make the wife happy, but now its my turn.
ender006 is offline
post #2 of 116 Old 01-09-2014, 11:23 PM
BeeMan458's Avatar
Liked: 801
Other than that, it reads like you need a replacement AVR and a new subwoofer system....and maybe some speakers.
How much thought have you put into this upgrade and what are your expectations?
Because of the problems created, I "HATE" sub loaded speakers. My recommendation, sell the Def Techs and start over.
BeeMan458 is offline
post #3 of 116 Old 01-09-2014, 11:43 PM
steve nn's Avatar
Liked: 425
Hi ender.. Do you know how much $hipping is going to run you?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #4 of 116 Old 01-10-2014, 01:00 AM
shadyJ's Avatar
Quoted: 49 Post(s)
Liked: 441
If you can afford the Outlaw, you can afford the Hsu VTF3, which is like an improved version of the Outlaw. Get the VTF3 instead. Shipping will put either over $700 though. If you need to stick under $700 at all costs, go for the SVS PB12-NSD which is being clearenced out at $699 shipped.
spyboy and blake18 like this.
shadyJ is offline
post #5 of 116 Old 01-10-2014, 07:35 AM - Thread Starter
ender006's Avatar
Ive really considered getting rid of the def techs. Im not a fan if the subs in the towers either. I also want to get into separates but one step at a time. I figured if i use my current avr as a pre amp i could go ahead and get the power amp, then upgrade the pre amp after.
Im not too concerned with shipping cost. Maybe i should say $700 ballpark.
I'll take a look at the hsu today and see what i think. Thanks for the recommendation.
ender006 is offline
post #6 of 116 Old 01-10-2014, 08:23 AM
Tripledub's Avatar
Careful...the more you look and read these forums, the more that budget will creep up and up :)
I started with a budget of $300, that was immediately bumped to $500, pushed to $800, and now sits at "around" $1k!
It's so easy to play the "if you spend $500 you might as well consider the ones at $600", "well look at this one for $750" game.
It never ends lol.
Let us know what you end up with and how you like it
Tripledub is online now
post #7 of 116 Old 01-10-2014, 08:37 AM
BeeMan458's Avatar
Liked: 801
Your above is why I recommend not having a budget, find a subwoofer setup that meets your needs and via compromise, work backwards until in good conscience, the individual can't compromise anymore and then look at the price. It's less painful that way. tongue.gif
post #8 of 116 Old 01-10-2014, 09:00 AM
flickhtguru's Avatar
Liked: 105
^^^ That's a good theory. But you have to remember some ppl just don't have the cash or don't understand bass. I know ppl that think their 8" 100watt sub from an HTIB that costs $400 sounds great and they have no idea why anyone would spend $500 or more on just one sub. My family all think I'm nuts I have a total A/V HT setup that cost me about $4700 but new and not on sale its about $8500 worth of equipment. Most of them think even an $800 TV is way too much or even a $400 HTIB.
So I do recommend that ppl have in mind what they hope to accomplish and have a budget in mind but be open to what the outcome will be based on the budget.
Honestly I had a modified HTIB with 2 identical HTIB subs and 7 identical LCR speakers and even tho the subs sucked compared to what I have now. I did get some tactile response, it shook the house and you could feel the bass. A lot of ppl thought that setup was beyond resonable and sounded crazy good. So its all in the eye of the beholder.
Shawn
flickhtguru is offline
post #9 of 116 Old 01-10-2014, 09:09 AM
BeeMan458's Avatar
Liked: 801
That's why I include in my disclaimer: "I'm not the voice of reason."
Not trying to be flip, once going to the dark side, how can one be expected to give rational advice?
Hi, I'm going give you advice that guarantees your sound is going suck.
I have trouble with this point. I'd rather tell them to work backwards so they'll better understand why they need to dig so deep into their pockets.
post #10 of 116 Old 01-10-2014, 09:12 AM
KidHorn's Avatar
Quoted: 62 Post(s)
Liked: 163
The outlaws frequently go on sale for $499 and $599 with free shipping. I think they're the best bang for the buck when on sale.
flickhtguru and Aundudel25 like this.
KidHorn is online now
post #11 of 116 Old 01-10-2014, 09:16 AM
Liked: 105
@ Bee: LOL. I know what your saying. I often recommend ppl starting with a minimum of dual subs in the $500 to $800 each range. But for some that just scares them off. And for others that listen to us and get what is recommended some come back not satisfied. All because they have no idea what good bass is or sounds like. All they new was a junk HTIB sub that they think sounds better but infact its all just distortion and a huge hump in freq resp at 40 to 50 hz.
Actually there is another thread about a person totally not satisfied with an SVS PC12 NSD and the person came from a 12 JBL sub that wan't half the sub of the SVS. But the SVS has flat response and the JBL i think had a huge bump in freq resp at about 40 hz.
Shawn
post #12 of 116 Old 01-10-2014, 09:17 AM
Liked: 105
I totally agree and that's why I have dual Plus's that I bought for $499 each shipped.
Shawn
post #13 of 116 Old 01-10-2014, 09:20 AM
spyboy's Avatar
Liked: 40
I would get one of those SVS PB-12 NSD's for $699 delivered. 5 year warranty, trade up policy, excellent customer service...
If you want the PB-12 NSD I don't they will last very long.
spyboy is offline
post #14 of 116 Old 01-10-2014, 12:11 PM
Nixterdemus's Avatar
Hate to off topic, but why is the SB-12 NSD $150 more than the SB-1000? Face value seems to say 100 watts RMS is basically the only/main difference.
Is there something else save a buck & half a watt that I'm missing?
I think they were 700 bills, but still I'm missing something or 1/3 more power is worth more than I gave credit.
Nixterdemus is offline
post #15 of 116 Old 01-10-2014, 01:52 PM
rnatalli's Avatar
Liked: 77
The SB12-NSD has better build quality than the SB-1000. The driver is cast instead of stamped, the amplifier is 400 watts instead of 300, and the cabinet itself is better.
For $700, I'd probably go with the PB12-NSD being cleared out for $699 shipped. But the VTF-3 MK4 is an excellent choice as well.
rnatalli is offline
post #16 of 116 Old 01-10-2014, 02:14 PM
Thanks. Didn't realize that cast driver was that big a deal.
Why not the SB-2000 / $699.00? I know it's sealed though it slides in under seven bills & it's 500 W.
ETA: Granted the difference twixt the SB-2000 & SB12-NSD probably isn't as large as the SB-1000/SB12-NSD, but it's a new & improved extra 100 watts for fifty clams. 100 more compared to the SB12-NSD outet.
post #17 of 116 Old 01-10-2014, 02:25 PM
BeeMan458's Avatar
Liked: 801
First things first, give up on the idea of saving a buck and a half cause going where you want to go, is going cost.
The sooner you give in on this point, the sooner you can start moving forward with your life again.
post #18 of 116 Old 01-10-2014, 03:09 PM
steve nn's Avatar
Liked: 425
It can be one of the tell tail signs of how it will perform in the lower freqs and smaller enclosure related to spl, but no not a given. There are plenty of beefy drivers that it’s parameters don’t support doing so. In this case the SB-2000 has a edge in extension and output though.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #19 of 116 Old 01-10-2014, 03:15 PM
Reefdvr27's Avatar
Quoted: 133 Post(s)
Liked: 281
Reefdvr27 is online now
post #20 of 116 Old 01-10-2014, 08:39 PM - Thread Starter
ender006's Avatar
Ahhh finally off of work and able to catch up. First off thanks for the advice and feedback. You guys are awesome. I can get the Hsu shipped for $758 which isn't too bad. I also checked out the Svs and it looks like its between those 2 at the moment. What would avs do???
ender006 is offline
post #21 of 116 Old 01-10-2014, 09:10 PM
deepat04's Avatar
Liked: 39
SVS SB2k or PB2K?
deepat04 is offline
post #22 of 116 Old 01-10-2014, 09:29 PM - Thread Starter
ender006's Avatar
I was looking at the SVS PB-12 that shady and spyboy recommended.
ender006 is offline
post #23 of 116 Old 01-11-2014, 07:13 AM
BeeMan458's Avatar
Liked: 801
In the real world, consider a PSA XV15.
post #24 of 116 Old 01-11-2014, 11:37 AM - Thread Starter
ender006's Avatar
Drooling over the jtr lol maybe if i sell my wife's pathfinder? How accurate is the comparison chart on the PSA site? For $100 more the PSA looks like a solid choice. I know i know my budget keeps going up but its sooo hard!
ender006 is offline
post #25 of 116 Old 01-11-2014, 12:01 PM
shadyJ's Avatar
Quoted: 49 Post(s)
Liked: 441
PSA's charts are complete garbage and deliberately misleading. PSA's subs are nowhere near as good as they want you to believe. Here is a thread I made which debunks it. Read through it and you can see how their chart conceals problems with their sub's design.
shadyJ is offline
post #26 of 116 Old 01-11-2014, 01:28 PM
Reefdvr27's Avatar
Quoted: 133 Post(s)
Liked: 281
Had dual XV-15's and loved them. They replaced dual Outlaws that I had and it was no comparison. The best part is that they are hand made in the USA not like the other offerings made in China!
post #27 of 116 Old 01-11-2014, 01:48 PM
jbrown15's Avatar
Quoted: 204 Post(s)
Liked: 702
Well there you have it, an honest opinion from someone whose owned both, and comments from shady who's never heard any PSA subs......lol
My Gear:
JTR Noesis 228HT (LCR)
Axiom Audio QS8 surrounds
Sherbourn PA 7-350
Pioneer VSX-21TXH
JVC RS45
Falcon Screens FVHD105
Dual PSA XS30's (gone but not forgotten)
jbrown15 is offline
post #28 of 116 Old 01-11-2014, 01:53 PM
Tom Vodhanel's Avatar
Quoted: 88 Post(s)
Liked: 685
There are only two elements to the comparison chart on our website.
1)Output data. We use the data complied per the industry standard CEA-2010 measurement protocol. This protocol has been developed based on a decade's worth of research in two extremely important areas. 1)what type of output testing will most closely mimic real world usage. 2)the audibility of harmonic distortion in subwoofer frequencies. If you see anyone suggesting the decade's worth of research is invalid, please ask them to reference the specific AES papers involved and then provide their own EVIDENCE. Hey, the earth is flat....maybe if i say it enough times someone might believe me?..smile.gif The *fact* is....the CEA burst method IS the measurement method that most closely mimics what the subwoofer will reproduce in the real world(music/film).
2)We average the data for the entire 20-63hz measurement spectrum (again, per the CEA-2010 measurement protocol). If anyone wants to focus on a single test frequency as being "most important" that is up to them. I personally feel the entire bandwidth should be weighted equally. After all, who can say 20hz is more important than 50hz? Or vice versa? Are there cool film effects at 20hz? Absolutely. Is music/film going to have more 50hz content than 20hz? By magnitudes.
*All* of our data is calculated using the CEA-2010 measurement + The minor scaling that the reviewer in question has confirmed is correct on one model---the XV15. (adding about 1dB to his XV15 measurements because the driver was actually about 7foot from the mic versus 6 foot for other brands). Is is all simple math, and math we have performed accurately. Is anyone feels that last decade of research (by the likes of Keele, Toole, etc) is invalid and they have a better solution to an industry standard----by all means----present the paper explaining such at your local AES meeting then post a copy here. I'm sure it would be quite interesting. Until then, keep screaming the earth is flat?
Tom V.
Power Sound Audio
Brian Fineberg likes this.
Tom Vodhanel is online now
post #29 of 116 Old 01-11-2014, 02:32 PM
dsrussell's Avatar
Quoted: 56 Post(s)
Liked: 247
Tom V.
Power Sound Audio
Tom. It's been awhile since I purchased the XS30 and was on your website, so I thought I'd take a look at what all the hubbub was about. The only thing I see that raised an eyebrow was your "PSA Value Factor", which Shady pointed out. I tend to agree with him on this point. What I don't agree with is Shady's never ending stalking of PSA in every thread. While his personal grudge may be real or imagined, it is simply not healthy. There is a guy named Eduardo on Amazon that stalks any and all Bose products and lashes out. Again, not that I don't agree with some of Eduardo's points, it's his mindless stalking that is really troublesome.
dsrussell is offline
post #30 of 116 Old 01-11-2014, 02:46 PM
WhskyTangoFoxtrt's Avatar
Liked: 32
Tom V.
Power Sound Audio
Tom: I don't believe I have seen anyone dispute the CEA-2010 standard or its use in your charts.. The hot-button issues, that have raised a few eyebrows, are all in the infamous thread linked above. I do not think you have offered your expertise on the data posted by Luke or Bosso. It would be interesting to get your input.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is online now
Hsu Vtf3 Mk4 , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb2000 , Svs Pb2000
