Rythmik LV12R or PB-12NSD, which one is better if price is not a factor? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-14-2014, 09:30 PM - Thread Starter
PolishDude's Avatar
Quoted: 14 Post(s)
Thinking of picking one of these up and selling the dual Polk PSW505s I picked up, which one is a better sub if you completely disregard the price difference? I noticed the SVS has 100 watts RMS, so will it have higher output than the LV12R? My room is rather big, 13 by 24 by 9 but it is a townhouse so I am sure either one will be enough to piss off neighbors. The seating position will only be about 7 feet from the sub.
PolishDude is offline
post #2 of 12 Old 01-15-2014, 05:23 AM
eljaycanuck's Avatar
Quoted: 1225 Post(s)
Liked: 1794
eljaycanuck is online now
post #3 of 12 Old 01-15-2014, 06:49 AM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Higher amplifier power does necessarily mean that it would play louder.
qguy is offline
post #4 of 12 Old 01-15-2014, 06:57 AM
flickhtguru's Avatar
Liked: 110
Both are good choices. I'd probably go SVS is price isn't a factor but then if price isn't a factor it opens up several other options.... I would say you should be looking at dual subs. So maybe even consider dual PB1000's.
Shawn
flickhtguru is offline
post #5 of 12 Old 01-15-2014, 07:41 AM - Thread Starter
PolishDude's Avatar
Quoted: 14 Post(s)
I know, that is why I ask as I am sure watts alone doesn't mean a better sub
post #6 of 12 Old 01-15-2014, 07:43 AM - Thread Starter
PolishDude's Avatar
Quoted: 14 Post(s)
Well overall it is a factor but I can get an outlet PB12-NSD for the same price as a LV12R so that is why price isn't a factor because it is essentially the same price. If I lived in a house, I would definitely buy dual PB1000s but think they may be overkill for my setup considering I share common walls with other townhouses?
post #7 of 12 Old 01-15-2014, 08:31 AM
Liked: 110
IMO don't worry about overkill. You can just turn the subs down if you need to. To me in your situation you have 2 options: 1 forget about buying a sub OR 2 (my advice) talk to your neighbors and ask them what time of day you can play your sub. Tell them to let you know if its too loud and also invite them over for a movie so they can enjoy and understand what the sound really is. No matter what sub you buy and how many you will annoy neighbors unless the shared wall is thick concrete the bass will travel right thru the wall to your neighbors place.
Shawn
post #8 of 12 Old 01-15-2014, 08:45 AM
steve nn's Avatar
Liked: 433
Those are two subs that never have met as far as I know and what numbers are available regarding the LVR are very limited and vague. If I were choosing between the two though, it would be the PB-2000 in a heartbeat!
Watts/power doesn’t come into the equation except pertaining to the choice of the driver in the enclosure. One driver can take a 1000w to get to 110 dB in a 4cf enclosure while another driver can take as little as 100w in short.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #9 of 12 Old 01-15-2014, 09:20 AM - Thread Starter
PolishDude's Avatar
Quoted: 14 Post(s)
I would think overkill would be feeling the bass versus it shaking the townhouse off it's foundation. I guess I can always buy one and see how I like it and opt for a second one if need be. I have not mounted the baseboards yet, I should see if I can tell what is between the two townhouses.
post #10 of 12 Old 01-16-2014, 12:48 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 183
The PB-12 NSD would stomp the Rythmik.
Lumenlab "Community driven video lab".
blake18 is offline
post #11 of 12 Old 01-20-2014, 04:27 AM
Bond 007's Avatar
Quoted: 2370 Post(s)
Liked: 1906
In what way? Can you be specific?
Licence to Kill
Bond 007 is offline
post #12 of 12 Old 01-20-2014, 05:38 AM
Quoted: 73 Post(s)
Liked: 112
At the same price, I would take the SVS as it has better build quality (cast driver, 400 watt amp, better cabinet, etc.). You also get a 5-year warranty with the SVS.
rnatalli is offline
Rythmik Audio Lv12r , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
