Reaction Audio Subs - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 4428Likes
post #1171 of 6745 Old 10-10-2014, 10:40 AM
rrskda's Avatar
Quoted: 56 Post(s)
Liked: 25
Originally Posted by deepat04 View Post
The area where the subwoofer is screwed into the enclosure looks to have some imperfections in the fit and finish. B-Stock?
I think you're referring to the screws right around the speaker surround, yes? The material of the surround itself actually extends right to where the screws go in, and I discussed this with Jeremy just after I unboxed them. Basically the material can get a little warped around the screws, but it absolutely doesn't affect sound quality. There is some sawdust type stuff around the speaker edge that seems to have gotten stuck perhaps to the paint or some glue, not sure. It's only visible close up and iI never notice it since I just keep the grills on and both drivers are facing a wall. I'll never see it.
rrskda is online now
post #1172 of 6745 Old 10-10-2014, 10:44 AM
FattyMcButterPants's Avatar
Quoted: 875 Post(s)
Liked: 813
Originally Posted by basshead81 View Post
How does the finish on your previously owned XS30's compare?
Jbrown can't technically comment on this for a few more weeks as I believe he still doesn't have his RA speakers.
jbrown15 likes this.
FattyMcButterPants is offline
post #1173 of 6745 Old 10-10-2014, 10:46 AM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
I liked the finish on the XS30's and I still see my old subs all the time!...lol
But they were in my dark theater room, so the finish never really bothered me. If I had then in my living room I would have looked at getting a veneer. I haven't gotten my CX-8 surrounds speakers yet so I can't comment on how the finishes directly compare but will once I have them in hand.
Like I said before, I can see why Tom uses that finish it's perfect for hiding any imperfection, even if it's costly which I'm sure it is....lol
And of course the beauty of a veneer is you can hide imperfections too.
Even with the black industrial finish on my JTR speakers you can still see the seems on the tops of the cabinets, its very hard to get away from that. But its the same thing with FattyMcButterPants comment, the minute you step a foot or two away you can't notice it so why sweat it. And my JTR's weren't cheap speakers!...lol and they're made from very expensive Baltic birch too.
jbrown15 is offline
post #1174 of 6745 Old 10-10-2014, 10:47 AM
jbrown15's Avatar
Liked: 1993
Thanks for reminding me Randy!....lol
jbrown15 is offline
post #1175 of 6745 Old 10-10-2014, 11:25 AM
Quoted: 875 Post(s)
Liked: 813
No problem man No worries though, I am in the same boat as you for the CX-8's, can't wait until they show up!
As to the question of the finish, I suspect much of this will come down to personal preference, so instead of offering up thoughts I figured I would post a picture as I have both finishes stacked on top of each other in my living room as we speak.
Hopefully this is helpful and I am not shunned from society for posting speaker pics in the subwoofer forum, or even worse, posting PSA pics in the Reaction thread!
Name:	CX-10 and XV15se side close up.jpg
ID:	304130   Click image for larger version
Name:	CX-10 and XV15se side.jpg
ID:	304138   Click image for larger version
Name:	CX-10 and XV15se front.jpg
ssjp55 likes this.
post #1176 of 6745 Old 10-10-2014, 11:28 AM
jbrown15's Avatar
Liked: 1993
Wow those are tiny speakers!...lol
jbrown15 is offline
post #1177 of 6745 Old 10-10-2014, 11:52 AM
ssjp55's Avatar
Quoted: 74 Post(s)
Liked: 24
From the pictures it is actually difficult to see very many differences in them. I can tell there is a little texture on the subs, but other than that they both look great!
ssjp55 is offline
post #1178 of 6745 Old 10-10-2014, 12:08 PM
Quoted: 875 Post(s)
Liked: 813
Haha I know right. Even though the post the dimensions online I always find myself surprised when I receive them.
Thanks! The differences are pretty apparent up close and under the right light. I opened all the windows for those pics to get the natural light hitting them, and tried to do a few different angles to help illustrate the differences as best I can. At the end of the day black is black, and from more than two feet away they look more similar than different.
That being said, my preference does go towards the PSA finish because it masks all imperfections, looks flawless no matter how close I get or what light hits it, and is incredible durable. But I can see other people preferring the satin black finish from Reaction, it's really nice too!
post #1179 of 6745 Old 10-10-2014, 12:26 PM
chuckychuck7's Avatar
Quoted: 20 Post(s)
Liked: 34
Originally Posted by edgebsl View Post
Are you referring to the inner, recessed baffle that the driver mounts too?
There may be a little imperfection there, as it is not as usually very visible ( a fraction of an inch around the driver flange?) way inside the recess but other than that I don't see it?
I think the driver flange is maybe 1/4 inch too narrow that after you screw on the driver, the finish of the driver flange is compromised?
Other than that, the finish of the cabinet is fine.
chuckychuck7 is offline
post #1180 of 6745 Old 10-10-2014, 09:27 PM
aznattic's Avatar
Quoted: 12 Post(s)
So i received my subwoofer a few weeks ago. Unfortunately due to long work hours and car issues i had to delay testing the unit. Also my receiver took a dump on me yesterday, so i hooked up my old class A preamp, PS Audio 100C for my Theos. From what i am aware of, this is the first gloss black subwoofer from Reaction Audio and the first one with the external amplifier (PE SA1000). Using 8AWG speaker wire from knukonceptz and didn't mess with the settings just set the crossover and the gains. Performance was quite good (only tested music). The subwoofer does shake the entire house if i want it to at half gains, it does quite well in keeping up with my Theos.
I'll do some more extensive testing once i get my receiver repaired or replaced.
chucky7, deepat04 and Gamecock24 like this.
aznattic is offline
post #1181 of 6745 Old 10-10-2014, 09:55 PM
jbrown15's Avatar
Liked: 1993
Wow, that finish looks awesome!
deepat04 likes this.
jbrown15 is offline
post #1182 of 6745 Old 10-10-2014, 10:44 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5215
^agreed!!
basshead81 is offline
post #1183 of 6745 Old 10-10-2014, 11:57 PM
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
The enclosure looks fine. What I was referring to was the speaker surround, where there is visible imperfection/glue/dust as well as the screws.
Subwoofer finish looks really good. The gloss black is beautiful, what is the increase in price for that finish?
deepat04 is offline
post #1184 of 6745 Old 10-11-2014, 08:06 AM
Gamecock24's Avatar
Quoted: 230 Post(s)
Liked: 102
Piano Black is awesome. Nice SCAR 17 too.
Sent from my iPhone using TheChive - KCCO!
Gamecock24 is offline
post #1185 of 6745 Old 10-11-2014, 12:19 PM
Quoted: 875 Post(s)
Liked: 813
@aznattic
That piano gloss finish is beautiful! Forgive me if this has been mentioned, but what was the up charge for that?
post #1186 of 6745 Old 10-11-2014, 05:12 PM
jbrown15's Avatar
Liked: 1993
@aznattic
Some CX-15T's would look awesome in that finish in your room!...lol
jbrown15 is offline
post #1187 of 6745 Old 10-11-2014, 06:47 PM
Quoted: 875 Post(s)
Liked: 813
Now that I know he can do custom finishes like that I may just have to consider this... What I would really like is a sand texture to match my PSA subs. I'll have to speak with Jeremy because if he can do that I'll either be ordering more CX-10's, or even try those mighty CX-15's you always want me to get.
post #1188 of 6745 Old 10-11-2014, 07:22 PM
jbrown15's Avatar
Liked: 1993
Well you might as well want till I get the pair Jeremy is sending and compare them to my other speakers.
jbrown15 is offline
post #1189 of 6745 Old 10-11-2014, 07:35 PM
Quoted: 875 Post(s)
Liked: 813
Easier said than done... But you are right. Haha.
I'll also be curious about the high end sub offerings, should be awesome!
post #1190 of 6745 Old 10-11-2014, 07:44 PM
jbrown15's Avatar
Liked: 1993
Yeah the new high end subs should be awesome! I'm really thinking about adding at least one to my setup.
jbrown15 is offline
post #1191 of 6745 Old 10-12-2014, 11:54 AM
edgebsl's Avatar
Quoted: 665 Post(s)
Liked: 1209
For most subs, around $300.
For the smaller speakers it would be less.
Jeremy
Reaction Audio Subwoofers
edgebsl is offline
post #1192 of 6745 Old 10-12-2014, 11:58 AM
edgebsl's Avatar
Quoted: 665 Post(s)
Liked: 1209
We can do a textured finish. It may not be an exact match but should be to your liking.
Jeremy
edgebsl is offline
post #1193 of 6745 Old 10-15-2014, 05:48 PM
thisgsx's Avatar
Quoted: 36 Post(s)
Mine had visible imperfection/glue/dust as well as the screws. The warping around the screws makes the subwoofer look poorly mounted. Not to burst anyone's bubble, but I've mounted many subwoofers to enclosures and never have I've seen anything like that. It could be due to the material used, but even so, it looks poor. Especially considering my BPS215 is the one without a grill. A friend was over at the time of delivery and upon unboxing the subwoofer he asked me if I bought subwoofer used.
thisgsx is offline
post #1194 of 6745 Old 10-15-2014, 05:58 PM
ssjp55's Avatar
Quoted: 74 Post(s)
Liked: 24
What are those small black circles in the yellow I drew?
ssjp55 is offline
post #1195 of 6745 Old 10-15-2014, 05:59 PM
Gamecock24's Avatar
Quoted: 230 Post(s)
Liked: 102
I think those are magnets for the grill
post #1196 of 6745 Old 10-15-2014, 06:16 PM
Quoted: 875 Post(s)
Liked: 813
Magnets for the grill.
post #1197 of 6745 Old 10-15-2014, 10:08 PM
ssjp55's Avatar
Quoted: 74 Post(s)
Liked: 24
Thanks! That makes sense!
ssjp55 is offline
post #1198 of 6745 Old 10-15-2014, 10:53 PM
Quoted: 875 Post(s)
Liked: 813
No problem! Can't speak to the subs specifically, but I know the magnets in my CX-10's are VERY strong, even smashed my fingers a few times putting the grills on. Needless to say they won't be in danger of falling accidentally while watching my movies
post #1199 of 6745 Old 10-16-2014, 01:54 PM
edgebsl's Avatar
Quoted: 665 Post(s)
Liked: 1209
I just received your update.
Left you a VM.
Looks like from the pics you sent me there certainly was some moderate shipping damage.
Please feel free to give me a call, even over the weekend and we will discuss how to remedy this as soon as possible.
Thank you very much for bringing this to my attention.
Jeremy
edgebsl is offline
post #1200 of 6745 Old 10-16-2014, 02:04 PM
10dbdown's Avatar
Quoted: 42 Post(s)
Left you a VM.
That's excellent customer service! Now get back to cranking out those speakers
10dbdown is offline
