Which sub in the $3k-$4k price range - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-16-2014, 09:30 PM - Thread Starter
liqour's Avatar
My room is roughly 20'x30' with the ceiling 18' at the peak.
80% music 20% movies
Ive been looking at dual sub setups.
pb13 ultra duals
f25 duals
liqour is offline
post #2 of 11 Old 01-16-2014, 09:32 PM
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Two Seaton sound HP Submersives would really be nice in a room that size.
its phillip likes this.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #3 of 11 Old 01-16-2014, 10:19 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Submersive HP+ with slave
shadyJ is offline
post #4 of 11 Old 01-16-2014, 10:23 PM
raynist's Avatar
Quoted: 1277 Post(s)
Liked: 1209
That is potentially a really large space to fill, maybe 7000-9000 cubic feet depending on the average ceiling height.
Orbit Shifter? May want big ported subs with a room that size.
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
post #5 of 11 Old 01-16-2014, 10:40 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
+1
jbrown15 is offline
post #6 of 11 Old 01-17-2014, 01:40 AM
rhed's Avatar
Quoted: 637 Post(s)
Liked: 478
That's a large room.. You need a lot of subs to fill that room. With that kind of budget, DIY IMO is the only way. You probably can DIY a 18x8 sub system with 4k$. Other DIY'ers will chime in on this one.
rhed is offline
post #7 of 11 Old 01-17-2014, 02:39 AM
kramskoi's Avatar
Liked: 27
pb13 ultra duals
f25 duals
30 feet is a REALLY bad length dimension. Room gain won't start for you until about 18Hz. With an 18' ceiling, you have tremendous volume to fill ... ~8,000 cu. ft. if you take an average between a 9 and 18' ceiling. Pb-13 Ultras are about right, though I think you may end up needing at least four of them. I would figure 1 per 2000 cu. ft. for the best visceral effect, though duals should make a nice presentation as well. Absolutely vented because, and I mean Mark no disrespect in regards to the super Submersive, your space will contribute absolutely nothing with a 30' length. It will all have to come from the subs themselves and that just screams vented in my opinion. Actually, DIY would offer much more potent possibilities as far as tuning and output....$4 - 8k is a lot to spend on subwoofers. If your room dimensions are in fact real then you will need some serious muscle in there.
"Frequency response is NOT efficiency response."
Klipsch RB-35's main
Klipsch RB-35's surround
Acoustech HT-65 center
Cerwin-Vega CV-2800
Subwoofer
B&C 21SW152-4  [21" critical-Q]
kramskoi is offline
post #8 of 11 Old 01-17-2014, 06:16 AM
BeeMan458's Avatar
Liked: 813
^ +1
With the above budget, I'd be looking at four FV15HPs as one or two subs will not fill this room and deal with peaks and nulls in the process.
Disclosure: We have two FV15HPs for a 3300^3 room, openings to adjacent spaces and for room smoothing purposes, I see a third FV15HP in our life. I won't be buying to make it loud as the two subwoofer system, easily achieves reference level play. I'm looking for a smooth response close to single digit, reference level playback.
With your budget, to start, one can buy two FV15HPs, get them dialed in using REW as your guide and as necessary, add to the mix, one subwoofer at a time.
BeeMan458 is offline
post #9 of 11 Old 01-17-2014, 12:04 PM
Dbuudo07's Avatar
Quoted: 218 Post(s)
Liked: 194
Dual JTR Captivators or a JTR Orbit Shifter LF or LFU.. You need ported or horned subs with that size room and your budget. Pressurizing that room with sealed subs is going to cost a lot. I love the Submersives, but I don't think they're the best option for this situation.
David Budo
Dbuudo07 is offline
post #10 of 11 Old 01-17-2014, 12:10 PM
KidHorn's Avatar
Quoted: 1380 Post(s)
Liked: 888
4 FV15HP or 2 captivators would be my choice.
KidHorn is offline
post #11 of 11 Old 01-17-2014, 12:12 PM
Petden's Avatar
Liked: 33
2 of these GJALLARHORN. They would be within your price range and offer extreme extension.
Petden is offline
