SVS SB13 Ultra vs PB12-NSD/PB2000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-19-2014, 02:32 PM - Thread Starter
LowerFE's Avatar
Liked: 41
Hi,
Does anyone know how the SVS SB13 Ultra compare with a PB12-NSD or the new PB2000 for low level movie performance (like -25)? Small size is kinda important because it is in a small room of about 1200 cu ft.
LowerFE is offline
post #2 of 3 Old 01-19-2014, 02:57 PM
warpdrive's Avatar
Liked: 48
in the most general terms, the SB13 has a more capable driver and more power so it will have more output in the mid-upper bass range 50Hz and up. It will generally keep up with the PB12-Plus in the upper bass. But as you near 20Hz, the SB13 will lose out to the PBs near their tuning point.
So it does very well, but for movies where you also want lots of impact in the 20-40Hz range, the PBs are preferable. But *if* you have a small sized room, then your natural room gain will probably complement the sealed rolloff characteristics of the SB13 better and the SB will work very well for movies.
I like the fact that the SVS avoided too much signal manipulation to get strong 20Hz performance, they designed it to play strong and clean and integrate well into smaller home theatre installations, which is great for people that actually need smaller subs
edit: I also meant to add the SB should be pretty impressive for movies given the size of the room. If your room can be closed off (all doors sealed), then you will likely get a bit of pressurization (the impact in your chest) as well
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #3 of 3 Old 01-20-2014, 04:32 PM
Hopinater's Avatar
Quoted: 1779 Post(s)
Liked: 4382
Warpdrive has great information here. Based on the size of your room I would think the SB would work well in your situation.
Subwoofers: dual PSA V3600's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Sony BDP-S5200 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is online now
Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb2000
