Subwoofer recommendation for a 6500 cu ft family room - rock and classical music mostly - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 65 Old 01-27-2014, 06:50 PM
Hopinater's Avatar
Quoted: 1896 Post(s)
Liked: 4674
Yeah I agree, from all I've read the PA 150 is a great sub for under $500 as long as you aren't looking for much output below 30 Hz (IIRC). But for anything above that it's a great sub. Should be good for music and at a good price.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Oppo UDP-203 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #62 of 65 Old 01-28-2014, 04:36 AM
bear123's Avatar
Quoted: 1719 Post(s)
Liked: 2527
Yeah, and I think as a last resort, if OP still does not get the output he needs he can get a second one down the road when the budget allows to gain the extra 6 dB of output.
bear123 is offline
post #63 of 65 Old 01-28-2014, 10:23 AM
derrickdj1's Avatar
Quoted: 895 Post(s)
Liked: 605
I think Bill has seen this thread and is staying away from this 6 db. thing, lol. It is simple to do, get a spl meter and with subs in the room greater than 1/4 wave length, turn one sub and measure at the MLP. Then turn the second sub on and measure. It will not be 6db. I have done this many times.
derrickdj1 is offline
post #64 of 65 Old 01-28-2014, 10:33 AM
nashou66's Avatar
Quoted: 89 Post(s)
Liked: 103
Originally Posted by derrickdj1 View Post
Something that digs deep can also be a great sub for music, just not a $500 sub. For that price range I can't think of a better sub than the PA 150, which does not have great under 20 Hz output. What sub under $500 really has great sub 20 Hz output. I can't think of one, he he.
Nashou
nashou66 is offline
post #65 of 65 Old 01-28-2014, 12:22 PM
bear123's Avatar
Liked: 2527
Oh I don't have the definitive answer here, just regurgitating what I heard.  I believe you though.  However, I do remember seeing someone say they gained 7 or 8 dB adding a second sub.  I figured it was the 6 plus room gain?  I have no first hand experience with this.
bear123 is offline
Hsu Research Stf 2 , Hsu Vtf2 Mk4 , Premier Acoustic Pa 150 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer
