Sub Placement help with a picture! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 01-23-2014, 01:32 PM - Thread Starter
TVMAN1991's Avatar
Liked: 30
So, with this room, it's 15x17ish.
The VTF15Hs are going to be gone and incoming are dual SB13 Ultras. Question is, should they go where the HSUs currently are or should they go more in the corners to the left and right of my L + R channels? These are the only two places I have room for them.
TVMAN1991 is offline
post #2 of 16 Old 01-23-2014, 01:37 PM
spyboy's Avatar
Liked: 47
If I were you I would place the SB13 Ultras in both positions and use the one that sounds best.
spyboy is offline
post #3 of 16 Old 01-23-2014, 01:45 PM
eljaycanuck's Avatar
Quoted: 788 Post(s)
Liked: 1169
eljaycanuck is offline
post #4 of 16 Old 01-23-2014, 01:50 PM
nashou66's Avatar
Quoted: 87 Post(s)
Liked: 102
Nashou
nashou66 is offline
post #5 of 16 Old 01-23-2014, 01:52 PM - Thread Starter
TVMAN1991's Avatar
Liked: 30
Originally Posted by nashou66 View Post
Nashou
Wont fit in the TV stand!!!!
post #6 of 16 Old 01-23-2014, 02:04 PM
Ozzie Isaac's Avatar
Liked: 96
Front corner and opposite rear corner. Symmetry and subs don't usually sound the best.
Ozzie Isaac is offline
post #7 of 16 Old 01-23-2014, 02:13 PM - Thread Starter
TVMAN1991's Avatar
Liked: 30
I don't have room in the back of the room.
post #8 of 16 Old 01-23-2014, 02:22 PM
nashou66's Avatar
Quoted: 87 Post(s)
Liked: 102
Athanasios
nashou66 is offline
post #9 of 16 Old 01-23-2014, 02:38 PM
ahmedreda's Avatar
Quoted: 203 Post(s)
Liked: 110
Try the REW room simulator.. I used it for my room which is rectangular as well and its results were fairly close to those obtained by measuring with the UMIK-1.
ahmedreda is online now
post #10 of 16 Old 01-23-2014, 04:08 PM
Cowboys's Avatar
Liked: 107
Try to use REW and a mic to see what look best. Just curious of why a pair of sb13's over your vtf15h's?
Cowboys is offline
post #11 of 16 Old 01-23-2014, 04:22 PM - Thread Starter
TVMAN1991's Avatar
Liked: 30
WAF LOL
post #12 of 16 Old 01-23-2014, 04:29 PM
qguy's Avatar
Quoted: 72 Post(s)
Liked: 78
When WAF is involved, forget about the best placement and go for symetry, else you could put the MAC where the right sub is and place the sub further to the right, this way you wont have the same nulls in the room.
qguy is offline
post #13 of 16 Old 01-24-2014, 03:32 PM - Thread Starter
TVMAN1991's Avatar
Liked: 30
Is having them where the VTF15s are now going to be bad?
post #14 of 16 Old 01-24-2014, 04:36 PM
qguy's Avatar
Quoted: 72 Post(s)
Liked: 78
If you have a square room, and putting one sub say 5 feet from the left produces a null in the center of the room, putting a second sub 5 feet from the Right would ALSO produce a null in the center of the room.
qguy is offline
post #15 of 16 Old 01-24-2014, 05:39 PM - Thread Starter
TVMAN1991's Avatar
Liked: 30
So, now I'm thinking one in the front right corner and try and accommodate one in the back left corner. Is that better than the current setup? It's not perfectly square either. Where you walk in the room there is a 2x4 entrance. Does that make a difference?
post #16 of 16 Old 01-24-2014, 06:21 PM
qguy's Avatar
Quoted: 72 Post(s)
Liked: 78
Right now were just guessing, measurements OR testing by moving the subs would be the only way to truly determine the correct subs position
qguy is offline
Hsu Vtf 15h Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer
