MFW-15 dying, replacement options? - AVS Forum | Home Theater Discussions And Reviews
Old 01-27-2014, 07:27 PM - Thread Starter
MatthewW's Avatar
Quoted: 20 Post(s)
I got an MFW-15 with the hum thats just getting worse and worse, I know about the caps fix but I also read that it is going to eventually die a slow death anyway even with that fix so I was thinking of just getting sub replaced sooner rather than later. The options I was looking at is the MFW-15 Turbo kit, the SVS PB-2000 or HSU VTF15-H - my budget is up to $1,000 and room size is 2,000 cu ft. Any input or suggestions would be helpful. Thanks in advance!
MatthewW is offline
Old 01-27-2014, 07:30 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
... I was thinking of just getting sub replaced sooner rather than later. The options I was looking at is the MFW-15 Turbo kit, the SVS PB-2000 or HSU VTF15-H - my budget is up to $1,000 and room size is 2,000 cu ft.
HSU VTF-15H.
eljaycanuck is offline
Old 01-27-2014, 07:48 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
From what I gather, the turbo kit will get you some major performance. I don't know about its current availability though. That is probably what I would do, if I couldn't do DIY. You might investigate what you can achieve with $1k in a DIY project. After that, for $1k, I would go with the VTF15h.
shadyJ is offline
Old 02-02-2014, 05:46 AM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 185
Turbo kit without a doubt. if it's not available, just pick up a nice Dayton 15" driver and external amp for your mfw-15.
Lumenlab "Community driven video lab".
blake18 is offline
Old 06-20-2014, 11:12 AM
jkkwaz's Avatar
Quoted: 63 Post(s)
Liked: 32
Hey guys, I've read a million threads on this already, but need your quick help just to make sure I'm on the right track. A good friend has a MFW-15 that just started humming terribly, but he has NO technical ability whatsoever...so I am trying get him a new amp. I am thinking iNuke 1000 or A500. I like the idea of the A500 because I am worried that the 1000 would be too loud with fan noise. Thoughts? Also, am I going to have issues just hooking something like this up without a highpass? Or if I tell him to take it easy on the gain know will he be ok? Thanks for the advice...I'd like to get something ordered up today so I can help him over the weekend.
Also, would the A500 bridge ok to the stock driver? Not sure what the ohm load would be and if the A500 can handle it...
jkkwaz is offline
Old 06-20-2014, 11:44 AM
JT78681's Avatar
Quoted: 1376 Post(s)
Liked: 900
A PSA XV15se would fill that space quite nicely. Put the $100 dollar saved towards some 5 star bass movies and enjoy.
JT78681 is offline
Old 06-24-2014, 06:02 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 185
Originally Posted by eljaycanuck View Post
Quote: ... I was thinking of just getting sub replaced sooner rather than later. The options I was looking at is the MFW-15 Turbo kit, the SVS PB-2000 or HSU VTF15-H - my budget is up to $1,000 and room size is 2,000 cu ft.
HSU VTF-15H.
The Turbo kit would have any of those options for lunch.
blake18 is offline
Old 06-24-2014, 10:27 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
And eljays final decision would eat the turbo for dinner and its cheaper
chalugadp is offline
Old 06-25-2014, 05:20 AM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2513
bear123 is offline
Old 06-25-2014, 05:22 AM
bear123's Avatar
Liked: 2513
The turbo option looks like it might give the sealed UXL-18 a good run for its money, maybe even have the edge around port tune.
bear123 is offline
Old 06-25-2014, 05:47 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
My vote here is the DIYSoundgroup flat packs and either the Dayton or SI18 drivers. For 1000, you could build a few of them. I just happen to have (6) of the Dayton 18's in the classifieds on the cheap.
Gorilla83 is offline
Old 06-25-2014, 06:19 AM
JT78681's Avatar
Liked: 900
Wait a second. Was this a sales pitch?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 06-25-2014, 07:03 AM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 185
Agreed.
blake18 is offline
Old 06-25-2014, 07:06 AM
Gorilla83's Avatar
Quoted: 370 Post(s)
Liked: 513
Shameless, yes haha. Looks like they may be sold at this point though.
Old 06-27-2014, 03:24 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
Why not simply replace the amplifier?
FMW is offline
