ONE HSU VTF 15H OR TWO HSU VTF-2 MK4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-28-2014, 07:54 AM - Thread Starter
ClawAndTalon's Avatar
Quoted: 349 Post(s)
Liked: 232
HSU 15 is 1025 Shipped
(2) HSU VTF-2 MKF4 1200 shipped
Will be paired up with Klipsch RF 82 IIs, RC52 II, and RB51 IIs
Room is 18x17, 3200 cubic feet, and sealed
"Most theories on audio and audio reproduction will be proven wrong only when the laws of physics change."
ClawAndTalon is offline
post #2 of 12 Old 01-28-2014, 08:01 AM
flickhtguru's Avatar
Liked: 110
I definitely think you should consider duals. However I think for around that price range the best bang for buck will be either 2 SVS PB12NSD's for $1299 shipped or 2 SVS SB2000's for $1299 shipped. Your room is small enough that sealed subs will get a good amount of room gain down low.
Shawn
flickhtguru is offline
post #3 of 12 Old 01-28-2014, 08:03 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
However I think for around that price range the best bang for buck will be2 SVS PB12NSD's for $1299 shipped.
+1.
eljaycanuck is offline
post #4 of 12 Old 01-28-2014, 08:06 AM - Thread Starter
Quoted: 349 Post(s)
Liked: 232
ahhh I forgot to check the SVS Outlet page. I'm probably pushing it going to 1200... In any case, I guess what attracts me to HSU are all the customization variations you can do.
But good find, I'll put it on my list.
post #5 of 12 Old 01-28-2014, 08:09 AM - Thread Starter
Quoted: 349 Post(s)
Liked: 232
Originally Posted by eljaycanuck View Post
Great googly moogly. Great call... but...
My wife would kill me. I was thinking the MBM later on for behind the couch and next to my spinning bike, and that might be pushing it (WAF)...
post #6 of 12 Old 01-28-2014, 08:11 AM - Thread Starter
Quoted: 349 Post(s)
Liked: 232
Should I also consider the PSA XV15-Base... I know nothing about PSA, build/sound quality... So it'd be a wild card. but $900 bucks shipped seems too good to be true.
post #7 of 12 Old 01-28-2014, 09:25 AM
Liked: 110
The XV15 is a solid choice but I would go for the one without the bass. The bass might look better but it adds un-needed weight and it takes away from the advantage of a down firing design. A downfiring woofer that fires towards carpet reduces unwanted upper end harmonics.
I still say go for dual subs BUT if you must go for a single I think I'd go with the VTF15-H with your budget OR even consider the PSA XS30.
Shawn
post #8 of 12 Old 01-28-2014, 06:38 PM - Thread Starter
Quoted: 349 Post(s)
Liked: 232
Pardon, but don't you mean the one without the base? I mean if they make one without bass that might not fly. smile.gif
I thought the base helped the bass, but I see whatcha mean... What's PSAs reputation?
post #9 of 12 Old 01-28-2014, 07:11 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
Hi Claw,
I think you'd be happy with any of the above suggestons. PSA hasn't been around too long, but the founders are highly pedigreed and respected. Dr Hsu has also earned his chops. and then some. Both are held in high regards by most here, and either are capable of producing major smile.gif. To pick one over the other is truly splitting hairs.
Myself, I went with a VTF3 mk3, as it was the best they offered at the time... upgraded from an Onkyo HTIB (big step, but I wanted to avoid upgrade-itis... as if that were even possible eek.gif) . The VTF 15 wasn't offered then, and PSA didn't exist. I liked it so much I bought another. biggrin.gif
If I had to do it over... well... with what I know now, it'd be DIY , period. Dual Martysubs have my eye at the moment, but the Nothorns look tempting as well... it is a very slippery slope, and the rabbit hole is deep. Very, very deep.
Joseph
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #10 of 12 Old 01-28-2014, 07:24 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
And as far as wifey is concerned... it's easier to ask for forgiveness than permission. IMO, and YMMV rolleyes.gif
post #11 of 12 Old 01-28-2014, 08:12 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
I'm a little biased but...............Go for the 15H.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #12 of 12 Old 01-28-2014, 10:10 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
+1 VTF15h, it is the top sub at around $1k.
shadyJ is offline
Hsu Vtf 15h Subwoofer , Hsu Vtf2 Mk4 , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb2000 , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb2000 , Xv15 , Xs30
