Please Advice - VTF-15H in a corner behind the TV stand. - AVS Forum | Home Theater Discussions And Reviews
Old 01-31-2014, 02:56 PM - Thread Starter
pb903369's Avatar
Hi,
I am planning to put a 15H behind my TV stand so it can stay out of view if my wife objects to it being by the couch. I will move the TV stand forward a little bit to fit the sub behind it.
That may not be the optimal setup but my room is not good for HT unfortunately, as you can see from the pictures.
Do you see any problems with that setup?
IMG_20140131_164041.jpg 2,349k .jpg file
IMG_20140131_163931.jpg 2,390k .jpg file
ID:	75392   Click image for larger version
pb903369 is offline
Hsu Vtf 15h Subwoofer
