Sub for 3500 sq ft, $600 budget??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 02-01-2014, 03:26 PM - Thread Starter
MIDOC's Avatar
 Hi all,
A newbie here, trying to come up with a sub for my system (80% music, 20% HT).  Budget $300 - $600.  The room volume is about 3500 sq ft.  Seems like there's a million choices (ported, sealed, down-firing, 8",10",12", etc).  Any input would be be greatly appreciated, as I know next to nothing about subs.
System:
Marantz nr 1504  (AVR)
Sib XL (F,C,R)
Sib (rears)
MIDOC is offline
post #2 of 16 Old 02-01-2014, 05:34 PM
Quoted: 73 Post(s)
Liked: 112
If you meant 3500 cubic feet then the Rythmik LV12R would be my choice.
rnatalli is offline
post #3 of 16 Old 02-01-2014, 07:00 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
Agreed.
And if you did indeed mean 3500 square feet, you need a bigger budget smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 16 Old 02-01-2014, 08:07 PM - Thread Starter
MIDOC's Avatar
Sorry, guys!  Yes, I meant 3500 cu ft.  Any thoughts on the Mordaunt-Short Aviano 7? (or 9)?  I found the Aviano 7 for $300 and the 9 for $500.  Would they pair up well with Sib XLs?
MIDOC is offline
post #5 of 16 Old 02-01-2014, 08:29 PM
cel4145's Avatar
Liked: 2987
The Aviano 7 would definitely seem to be too little sub for that size space as 175w 10". I'd stick to 12" ported subs, unless you want to go with the SVS PB-1000, which is a 10" that has output close to budget 12" subs.
cel4145 is offline
post #6 of 16 Old 02-01-2014, 08:33 PM
LowerFE's Avatar
Liked: 41
Budget is a very relative term here. I'm sure you mean "budget" 12'' ID subs, in the $500-$1000 range.
In the usual sense, the PB1000 would have significantly more output than most budget (<$500) 12'' subs.
LowerFE is offline
post #7 of 16 Old 02-01-2014, 08:34 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Best sub at $600 is really a choice between the Hsu VTF2 and Rythmik LV12r. Since music is your biggest priority, you ought to consider the Dayton Titanic 4 kit as well, that may be more appropriate for music in a room like that then the Hsu or Rythmik.
shadyJ is offline
post #8 of 16 Old 02-02-2014, 07:58 AM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2513
+1
bear123 is online now
post #9 of 16 Old 02-02-2014, 09:27 AM - Thread Starter
MIDOC's Avatar
Thanks for all the advice, everyone.  If I had my way, after looking at the options, I'd probably go with the LV12R or the VTF2 (emphasis on IF.....I had my way!)  My better half is less than amused with a 20"+ "black box" in the living room, so I'm looking at smaller options that will clearly be a compromise, and I'll probably be stuck with a 10" driver.
Kef Kube2 is only about 13" in all dimensions? Any thoughts on this unit?  It's clearly undersized for my space, but better than nothing?
Emotiva Ultrasub 10 or 12?  Also much smaller than the LV12R or VTF2, but I don't see it available anymore.  Is it still being sold?
Any other suggestions for a smaller sub, that would ring in <$500 or so?
Thanks again for all the input - much appreciated!!
MIDOC is offline
post #10 of 16 Old 02-02-2014, 09:30 AM
bear123's Avatar
Liked: 2513
You have a large room in which many would state the $600 subs you are considering would already be a compromise for your space.  My advice.....do a cardboard mock up of an orbit shifter and a Rythmik FV15HP so she sees how big they are, and the price, then she will be happy with your reasonably small 12" sub options.  This is YOUR hobby, compromise is essential in a non dedicated home theater room, but she needs to realize that a $600 sub in a room that size is already a compromise of sorts.
In the end, if you lose the battle and you end up being the only one to compromise, the sb2000 might be the least horrible downgrade for your room.
post #11 of 16 Old 02-02-2014, 03:40 PM
Turlen's Avatar
Sorry to semi-thread hijack. I don't see a reason to create a near identical thread.
If one was more in to home theater viewing, would one (HSU vs Rythmik) be better? I have a similar cubic footage situation. Also, any impressions regarding the aesthetics with HSU vs Rythmik? The space I would be using the sub for would be in a generic family rec room area with a big screen TV so it has to be reasonably nice looking.
Lastly, I'm extremely new to home audio speakers/equipment and grew up in a family with a cheap CRT / no home audio equipment. I've spent more than a few hours reading this forum and elsewhere, but can anybody with that perspective in mind tell me is if I spend this type of cash, will I be blown away compared to something cheaper like a Pioneer SP-PK52FS? Or is this a kind of situation where you are spending $$$ to get that next 10% level of improvement...
Thanks for any guidance.
Turlen is offline
post #12 of 16 Old 02-02-2014, 03:43 PM - Thread Starter
MIDOC's Avatar
Thanks for the input.  I'm leaning toward the SB-2000, after checking it out.  The rhythmic unit is also nice, but it's too big for the space I'm in, which is acoustically terrible (long, narrow, and I'm at one end with a wall right behind my head.)  I'd love to go for a nice 15" unit, but I'd probably wake up with it on my head one morning.  Thanks to everyone for the help!!
MIDOC is offline
post #13 of 16 Old 02-02-2014, 07:59 PM
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1564
I like that idea. You wouldn't happen to be a politician, would you? tongue.gif
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #14 of 16 Old 02-03-2014, 05:14 AM
bear123's Avatar
Liked: 2513
Lol...nah....but sometimes i think our other halves don't understand that we ARE compromising, as in this op's case.  It helps to show them what others are doing in such a room size.  I constantly showed my wife pictures of dual rythmiks with giant floorstanding speakers, it helped her to understand that my $800 sub and bookshelf speakers was a compromise.(Still ended up buying her a new chair and a mac book pro, but hey, we do what we have to)
post #15 of 16 Old 02-03-2014, 06:12 AM - Thread Starter
MIDOC's Avatar
Very true, but there's compromise on her end too.  I've got a 300 gallon saltwater aquarium that may be slightly large for our bedroom!  I guess I have to pick my battles!  I guess where I'm at is, I'd have to get something quite large, probably 15", to really "work" in the large space I'm in.  It's only temporary, for a couple of years, and when we move, I'll have an excuse to go out and buy a sub that can dual as a hot tub, if I want.  Thanks for all the help on this, guys!
MIDOC is offline
post #16 of 16 Old 02-06-2014, 11:47 AM
RayGuy's Avatar
Quoted: 733 Post(s)
Liked: 596
Dr. HSU is a big believer in near-field sub placement. Especially in an environment where the sub size does not fit the room size. So, in that scenario, the sub would be at the back of the room instead of the front. I'm not familiar with the Sib speakers, but if you can crossover at 80 HZ or lower, you would normally (there are exceptions) not be able to localize the bass as originating at the back of the room.
This gives you the option of putting the sub behind the coach, as a side table, or in a back corner where it can be hidden by a plant, or artwork, or whatever your imagination can conjure up to increase the WAF.
Just another idea to consider in your search for good bass reproduction while being married! biggrin.gif
RayGuy is offline
Rythmik Audio Lv12r , Rythmik , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb2000 , Hsu Research Vtf 2mk3 , Fv15hp Subwoofer , Svs Sb2000
