SVS PB-2000 Unboxing and Review Now Up (Updated) - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #91 of 104 Old 04-04-2014, 08:54 AM - Thread Starter
Batman61405's Avatar
Quoted: 172 Post(s)
Liked: 137
Originally Posted by hamptons View Post
Hi Batman, I increased the subwoofer trim to +8 db from +3 db on my receiver setting and now I can feel the rumbling!!! But, is +8db too high and will it damage the sub at this high level trim? I watched only about 15 minutes or so on a movie. Will the +8 db make the bass sound boomy? As I did not watch the whole DVD, I could not tell if it sounds boomy. Thanks to all those out there for your advise.
Another suggestion I just though of: just calibrate everything like I did and................JUST CRANK IT UP!!! biggrin.gif:D:D
Polk CS20
Polk Tsi 500's
Polk Tsi 200's
Denon 1713
Samsung 37'' LCD
Panasonic DMP-BDT 210
SVS PB-2000
Auralex Great Gramma/MoPAD
Logitech Harmony One
Batman61405 is offline
post #92 of 104 Old 04-04-2014, 11:53 AM
bear123's Avatar
Quoted: 1804 Post(s)
Liked: 2677
Originally Posted by afterlife2 View Post
Mine is actually -10 (and -9.0 on some Movies/TV shows) on the receiver and 2 1/2 clock postion on my sub. Of course every place is different. Like I said try a bass CD and adjust it to your liking. If you like Jazz , Pop or R&B I can recommend some CD's that I use to get it to my liking. I like mine to sound natural as possible with music and some movies. Enjoy!!!
-10 on a yamaha avr means the sub gain is too high and YPAO is not able to lower the sub volume enough to level match it with your main speakers.
bear123 is offline
post #93 of 104 Old 04-04-2014, 12:41 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
If ypao can not level match it will throw a error code which means out of range. All -10db means is the gain on the amp was set 10db hot so ypao pulled 10db in avr sub trim to achieve a 75db calibration.
basshead81 is offline
post #94 of 104 Old 04-04-2014, 12:47 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
You are never going to damage the sub because it has a aggressive limiter to protect it. That being said as mentioned previously I would decrease the amp gain until audyssey or whatever correction software the avr has sets the avr sub trim -6(any higher and the auto on feature of the sub may not work correctly at lower volumes). This will give you 6db of adjustment without going past 0 in the sub trim. The reason being having a +8 sub trim setting is most likely clipping the signal to sub at higher volumes.
post #95 of 104 Old 04-04-2014, 12:49 PM
bear123's Avatar
Liked: 2677
He might have gotten lucky and landed on exactly -10, but if  not, he may have his speakers set with + trim in the AVR as well.  I would imagine this would possibly introduce clipping just as it would for the sub?  I try not to completely max out the trim adjustment.
bear123 is offline
post #96 of 104 Old 04-04-2014, 05:45 PM
afterlife2's Avatar
Quoted: 163 Post(s)
Liked: 79
I always assume everyone uses audyssey. biggrin.gif So I say run the mic and then adjust to your liking with the preffered Bass CD.
afterlife2 is offline
post #97 of 104 Old 04-04-2014, 05:52 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
Yea that is a good point!! Part of the reason why I think -6 is about the perfect setup from my experience.
post #98 of 104 Old 01-15-2017, 06:09 PM
shareknow's Avatar
Dear all, On SVS site, the description for PB2000 says "Borrowing extensively from the legendary SVS Ultra Subwoofer line", technically what exact are the things it borrows from the ultra subwoofer line. I am in the process of making decision between between PB1000 and PB2000, for my dedicated HT room (My room is 16 feet length x 12 feet wide x 8 feet height and is closed from all sides). What exactly is the difference between PB1000 and PB 2000. I presently own the Ultra towers/ultra center/ultra surrounds. I love my Ultra speakers. Infact everyone who hears them becomes a huge fan. My friend owns a PB1000, he brought it to my house/HT room. I took a 2 hour demo with that. I like the clean/ distortion free sound of the SVS Subwoofers offer. Correct me if i am wrong, i think due the this clean distortion free nature of SVS , even if i put daul PB2000's in my HT room i will get the same clean distortion free sound.One more question i have is that most often reviewers label subwoofers according to room size, does that really matters? Can't we just keep the gain low and fit a large subwoofer in a small room? waiting eagerly for response.
shareknow is offline
post #99 of 104 Old 01-15-2017, 09:07 PM
MIX_MASTER_ICE's Avatar
Quoted: 1375 Post(s)
Liked: 1155
Pb-2000 will have quite a bit more output potential and a little lower extension capability than the PB-1000. The harder you push a subwoofer, the more distortion you can introduce. SVS subs are typically very well behaved and have low distortion numbers, even when pushed very hard.
For your 1500 ft^3 room the PB-1000 should do well. It's a smaller sub, which is more suited to smaller sized rooms. You certainly can run a PB-2000 in your room and it will dig deeper and have more output potential, but if you aren't pushing a PB-1000 to near it's limits, chances are you really don't need the extra headroom a PB-2000 would offer.
If I were in your position and was willing to spend $800 on PB-2000, I would look at dual PB-1000's. You can two of them from OneCall through ebay for $855, using promo code CGAMEDAY10. Dual subs will help smooth the frequency response in the room and give you an additional 3-6dB more output over a single PB-1000. Dual PB-1000's in a smaller sized room such as yours would be great for the money.
MIX_MASTER_ICE is online now
post #100 of 104 Old 01-16-2017, 07:20 AM
AllenA07's Avatar
Quoted: 701 Post(s)
Liked: 571
My room is roughly the same size as yours and I'm running an SVS PC-12 Plus and an PC-13 Ultra in there, so you absolutely can get large subs into small rooms. Right now I would be looking at a few factors if I were you. First off I can't suggest dual subs enough, they will do more for good bass then a single bigger sub (within reason). If you think you can do a PB-2000 now and later a second one, I wouldn't hesitate on pulling the trigger. If you're a little more budget locked, I think I would be looking at doing dual PB-1000's. If it doesn't matter and this is it for you, go ahead and get the bigger sub.
As far as getting distortion free sound, multiple subs will help a lot with that. The additional headroom that you gain with multiple subs will help reduce distortion.
My Theater: The Ugly Theater
AllenA07 is offline
post #101 of 104 Old 01-16-2017, 08:26 AM
shareknow's Avatar
Thanks dear, will a daul PB1000 setup go as deep as a single PB2000
post #102 of 104 Old 01-16-2017, 08:29 AM
shareknow's Avatar
Thanks, by additional headroom you mean that i can setup daul PB1000 setup with a low gain setting ? What exactly is a headroom.
post #103 of 104 Old 01-16-2017, 11:25 AM
Liked: 1155
Two of the same sub won't give you more extension, so the answer would be no. The pb-2000 has the ability to go a little deeper in range than the pb-1000. The amount of content below 20Hz is very little, however.
post #104 of 104 Old 01-16-2017, 01:53 PM
Reckless95's Avatar
Quoted: 222 Post(s)
Liked: 90
The biggest difference will be if multiple subs are spread out properly, they will have nulls and peaks at different frequencies allowing for a flatter FR.
Without measurements it's hard to say what one means. ex. "digs deep and hits hard".
SVS Ultra Bookshelves (Gloss White) / SVS SB13-Ultra / 2x Flex 12's / 2x V.B.S.S's / 2x Dayton 460HO's Marantz SR7008
AKG K712 Pros / SB ZxR
Reckless95 is offline
Svs Pb2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra
