Why aren't two VTF-15Hs filling my room with bass? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 02-05-2014, 10:47 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2901
Originally Posted by in3rtia View Post
I know that peak after ~50hz isn't good and it seems to just be exaggerated by the two subs...
If you divide the speed of sound by the width of your room, you should get the frequency of that peak:
1130 ÷ 21 = 53 Hz
Moving your subwoofer to the quarter points of room width should minimize that peak.
Sanjay
sdurani is offline
Old 02-06-2014, 04:17 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
So it's possible that no matter where I put two 15" subs in my room, I'll never have bass? I don't think I can accept that.
That's not what this is for.
Moving a sub around, playing with phase, etc... doesn't improve the bass in the room as a whole. What it does is move nulls/peaks to a different location within the room. If you get poor bass everywhere in the room, then the problem isn't caused by placement, it's because for whatever reason, your subs are not outputting the bass properly and hence you need to fix that instead of trying to find optimal placement. it could be faulty subs, faulty receiver and/or incorrect settings in your sub and/or receiver.
If you think the issue is the subs are cancelling each other out (I seriously doubt this is happening at anything but a very small set of frequencies), then you can turn off one of the subs and see if things improve. Again, walk around the room and see if things sound better in some spots than others.
Your graphs don't look that bad. They can be improved, but the graphs don't sync with what you're hearing. My hunch is either you're hearing has issues or you're used to the way your old subs sounded.
KidHorn is offline
Old 02-06-2014, 06:20 AM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
Originally Posted by Bassoholic View Post
It's hard to say. Start out with adding a foot or two to both subs and measure to see if graph looks better. If it's worse, then try to reduce the distances by the same amount. Write down the subs distances set by YPAO before adjusting. You might need to try increase one sub and reduce the other distance and remeasure. It takes some trial and experiment. Also, can you overlap the in-phase and alt-phase graphs to make it easier to compare. Please post unsmooth graph.
I have graphs for the subs in their original position in the front of the room, and also with one sub in the rear right corner.
Here are the unsmoothed versions
For this graph, one sub is in it's same spot at the front left of the room, and the other sub is in the rear right side next to the right surround speaker.
Here's both locations, all phase combinations overlayed.
in3rtia is offline
Old 02-06-2014, 09:09 AM
BeeMan458's Avatar
Liked: 813
What I'm seeing is you need better EQ'g capability where you can drag that peak at 52Hz down. It's amazing how much this will positively affect your graph.
What about the quacking problem? Has that been dealt with? Did you give Hsu a call and see what they had to say on the issue?
BeeMan458 is offline
Old 02-06-2014, 09:34 AM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
I was going to try and mess with an eq plugin for rew because I don't feel like buying a receiver with audessy/sub eq.
And by the time I had a minute to myself yesterday, it was past closing time for hsu. Today, I promise.
in3rtia is offline
Old 02-06-2014, 09:38 AM
BeeMan458's Avatar
Liked: 813
The miniDSP and REW have a thing for each other and my understanding, is the least expensive, user friendly appliance one can purchase and expect "excellent", real world results.
Old 02-06-2014, 09:48 AM
Luke Kamp's Avatar
Quoted: 150 Post(s)
Liked: 201
1130 ÷ 21 = 53 Hz
I would give this selective mode cancelling a try. Also gain match the subs using your mic as the gain knobs can differ and you may be driving one harder than the other.
http://www.avsforum.com/t/1282064/two-subs-gain-matching-vs-level-matching
The HSU manual has a troubleshooting guide. You could swap drivers and test, then amps to see if the issue is driver, amp, or enclosure related.
WhskyTangoFoxtrt likes this.
Luke Kamp is offline
Old 02-06-2014, 11:19 AM
mark62's Avatar
Liked: 88
As I mentioned before I would co-locate them to see what is happening when the subs are not fighting each other like the seem to be maybe? the graphs dont necessarily show that but worth a try.
mark62 is offline
Old 02-06-2014, 11:21 AM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
I still want to try that but I spent all last night adjusting and making measurements from their original locations at either side of the room.
in3rtia is offline
Old 02-06-2014, 11:22 AM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
I did level match them before making the measurements.
and I might try a driver swap later, after talking to HSU. I don't exactly know what I'm in for once I take that driver out though rolleyes.gif
in3rtia is offline
Old 02-06-2014, 11:29 AM
BeeMan458's Avatar
Liked: 813
Good luck.
Old 02-06-2014, 11:39 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
OP...... remove those two velvety recliners lying next to the subwoofer in the front right corner. Though they can't stop bass frequencies but may prove a major suck out. See if that helps.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
Old 02-06-2014, 12:45 PM
Bassoholic's Avatar
Luke said gain match
Bassoholic is offline
Old 02-06-2014, 12:53 PM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
My mistake, I used the words interchangeably... I adjusted the knobs on the back of the subs until they measured 75db with a test tone. I originally did do this by putting the subs on the same spot in the middle of my room, marked by tape. Pain in the ass. The knobs were almost exactly in the same spot on each amp to achieve the same volume.
I also did this with them in their corner homes before I started REW measurements.
in3rtia is offline
Old 02-06-2014, 05:37 PM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
What specific content do you use to evaluate how the bass sounds?
Do you use a DVD/Bluray? Which one(s)?
J_Palmer_Cass is offline
Old 02-06-2014, 06:05 PM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
Every bit of media plays through my HTPC via XBMC. My computer upstairs hosts all my movies and music. Movies are mostly Bluray rips, DTS-HD audio, and music is either FLAC or V0.
I found out that the rattling in the one VTF-15H is actually the driver. I took it out, swapped it in the other cabinet, same problem. I got close to it and it sounded like paper kind of rapidly flapping, almost tearing. I hadn't heard that before. I talked to HSU and I'm going to ship it out tomorrow.
I admit that I had no idea what I was looking for, but there were no obvious signs of damage from what I could tell.
in3rtia is offline
Old 02-09-2014, 11:00 AM
jeholloway's Avatar
Quoted: 49 Post(s)
Your room may not be big enough to accommodate the size of some of the more powerful bass frequencies. A bass frequency needs to be fully formed to be heard right. I had a friend with a room like yours and we could never get the lower freq right. Think of frequencies as waves. high freq are small waves, low freq are big waves. If you cannot complete the large waveform because your walls are too close together then you won't get those frequencies in your room.
My guess is you will need room treatments or a bigger room.
jeholloway is offline
Old 02-09-2014, 11:12 AM
jeholloway's Avatar
Quoted: 49 Post(s)
I also found this for you:
wavelength of sub-30 Hz sounds
I am in the process of auditioning a new sub for my room to get as low bass as possible. i measured the frequency response of my 8" mains using a SPL meter and a tone generator, and they have a flat response until 40 Hz and a rapid dropoff after that. i want any new sub i buy to be able to go significantly below that, at least a little below 30 Hz. i am a physics student, and we are learning about wave theory in class...i realized that the wavelength for a 30 Hz sound is over 38 feet long, and my room is only 12'x13'. does this mean that i am losing large parts of sounds at this frequency? is it possible to have extremely low bass in a small room?
Yes, it is possible to have extremely low bass in a small room. What is difficult to achieve is accurate low bass frequency response in a small room. At low frequencies, standing waves between parallel surfaces become a factor and some frequencies become reinforced by in-phase reflections while other frequencies become diminished by out-of-phase reflections. Very low frequencies, with long wavelegths relative to room dimensions, are reinforced because the reflections are only slightly out-of-phase from the original waves. The net result is to increase the loudness of the lower bass overall, but the effect varies by frequency. Therefore, subwoofer placement becomes an important factor and an equalizer is often required to achieve accurate bass frequency response.
Old 02-09-2014, 11:26 AM
Bill Fitzmaurice's Avatar
Liked: 4631
That is the myth of wave propagation, and it's absolutely untrue. If it were true how would headphones or car audio work? rolleyes.gif
The fact of the matter is that the smaller the room the stronger the bass, as cabin gain results in up to a 12dB of increase in SPL per octave lowering of frequency starting where the longest room dimension is 1/2 wavelength...which, BTW, explains how both headphones and auto sound realize very high SPL to very low frequencies from small speakers, extremely small speakers in the case of headphones.
Bill Fitzmaurice is online now
Old 02-09-2014, 03:29 PM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
I think I've noticed that in my room, the lower I go - as in closer to the ground - the better the bass sounds. I'm going to try to play around with placements and do more measurements with the one I have this week and see what I see, or hear. I wanna try stacking these things when I get it back. I look forward to trying that out.
in3rtia is offline
Old 02-09-2014, 08:54 PM
jeholloway's Avatar
Quoted: 49 Post(s)
I hope you are right and I am wrong. I however have had trouble getting deep, beautiful,spacious, timpani sounding bass in small spaces. I have been able to get high SPL and tight bass in small spaces but so many frequencies and textures were missing. In fact the sound was jarring and homogeneous in nature. BTW I have never heard satisfying, startling, explosive bass from headphones. I also have never heard car audio bass that was pipe organ beautiful either.
Old 02-10-2014, 01:26 PM
Liked: 4631
Using how many subs? You can't fix room modes and boundary reflections with just one.
Old 02-10-2014, 11:45 PM
handsaw's Avatar
I have 2 HSU VTF15Hs and I can assure you they can crush that room. I have had mine in 4 different homes and my humble opinion would be the room acoustics are killing you. The first room I had mine in was acoustically solid and they sounded excellent without much tweaking.
My current abode is a basement and I have a similar gnarly spike at about 50 Hz and it sounded like I had little subwoofer. I might have been in the same boat as you questioning the output abilities of the subs if I hadn't had these subs in another room twice the size and had great response. My solution was some sound treatments for the cinder block walls to improve decay times and more importantly a Behringer Ultracurve digital EQ. Look this thing up. It is sonically a winner and the feature set is way over the top for EQing subs. It is stereo so I have a channel for each sub. I simply used the parametric eq function to dial right into the problematic peaks and they are gone. You are way ahead of the game having the software to measure the room response so setting the eq should be a breeze. The great news is that I bought a pristine unit for 99 bucks used on the web and from my experience shopping, you should be able to find a similar deal on one of the usual sites.
Once you kill that peak you will be able to bring the level a bit and you will find your low end.
FYI I have a great Audyssey XT32 receiver and it still couldn't fix the bottom end without this unit.
Just a suggestion.
in3rtia likes this.
handsaw is offline
Old 02-11-2014, 06:51 AM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
Just a suggestion.
That's helpful, thank you. Do you know what model the Behringer was? Was it this?
I would have to learn how to implement the thing because although I have the ability to make measurements, I still don't have the ability to interpret them 100%.
And I definitely don't know how to implement room treatments, especially in a living room that has to look somewhat presentable.
Does anyone have any experience EQing through REW with something like the EQ APO?
If that could save me a little bit of money without the need for more equipment, great.
in3rtia is offline
Old 02-11-2014, 07:15 AM
Liked: 4631
For sub only use the preferred EQ is the Behringer FBD; the REW forum goes into great detail on how to use it with REW. It has the advantage of being able to use all of it's filters within the subwoofer pass band. A processor like the 8024 or 2496 is better for full system processing. It has the advantage of a built in RTA/auto EQ, which works in a similar fashion to Audyssey.
Step 1: Carpet the entire floor.
Step 2: http://www.realtraps.com/articles.htm
in3rtia likes this.
Old 02-11-2014, 07:46 AM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
I haven't measured my mains yet but in your opinion, what would I be better off investing in? The feedback destroyer or the full system processor, considering the pricing is the same?
Thanks, I'll read up.
A quick glance tells me I'd have to sell the subs in order to afford their treatments.
in3rtia is offline
Old 02-11-2014, 08:02 AM
Liked: 4631
To use a full range processor you need a separate pre-amp/amp, and if the processor doesn't have digital input/output (the 8024 does not) there are other issues as well. The FBD is plug and play between the AVR and subs, and it works better as a pure sub processor. I can't comment on that particular FBD model, go to the REW forum on that.
Old 02-11-2014, 08:54 AM
Quoted: 393 Post(s)
Liked: 118
Excuse my ignorance on the subject, but what specific path do you use to get audio from your HTPC to your AVR?
Old 02-11-2014, 11:32 AM - Thread Starter
in3rtia's Avatar
Quoted: 84 Post(s)
Liked: 25
The PC has an AMD Radeon HD 6570 with HDMI out so that's the only cable connecting them.
XBMC is configured to pass unprocessed data 'as is' to the receiver to be played and does not allow other windows sounds to interfere or get added to the mix (WASAPI).
in3rtia is offline
Old 02-11-2014, 11:51 AM
LastButNotLeast's Avatar
Quoted: 1480 Post(s)
Liked: 1070
I do. Actually, that's my post, so thanks.
I don't use xbmc, but I think, as the name implies, you need the APO interface for that particular program to work, but changing that is probably not a problem.
I use five filters plus a house curve.
Michael
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Hsu Vtf 15h Subwoofer
