Small subwoofer for NYC appartment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 02-05-2014, 09:45 AM - Thread Starter
vinz1982's Avatar
Hi,
I am upgrading from a HT in a box and have recently bought a pair of Polk TSX550 and Polk FX A4 for the back surround; those are hooked to a Sony STR1040. I am building my HT piece by piece for budget reasons and haven't yet bought my center channel (Polk TSX250 most likely or CSI A4...). I am using this setup for music (a lot), Movies and occasionally games.
I am now looking for a small subwoofer at a reasonable price of course that will:
- match my setup
- keep my wife happy....
- be relatively small
- ensure my neighbors (below, above and on the same floor) don't call the cops.
other relevant information:
- i won't be able to fit a big sub like the BIC F12...the tower speakers are already space consuming
- i have hardwood floor
- the room is 26 feet wide by 12 long and i am roughly 11 feet from the front speakers
- the front speakers are against the external wall and so will the subwoofer
let me know if you need more info in order to help with an eventual recommendation.
Vince
vinz1982 is offline
post #2 of 20 Old 02-05-2014, 09:53 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
"Reasonable price" is a bit vague, but I'll suggest the SVS SB-1000 or PB-1000, either of which is $499, shipped.
eljaycanuck is offline
post #3 of 20 Old 02-05-2014, 11:02 AM - Thread Starter
vinz1982's Avatar
i was more around 300$... or less :) of course
vinz1982 is offline
post #4 of 20 Old 02-05-2014, 11:05 AM
Liked: 1798
Dayton SUB-1200, available through parts-express.com. It's an inexpensive but well-rated sub.
See also this thread - List of budget subwoofers ($300 and less) - for more ideas.
post #5 of 20 Old 02-05-2014, 11:20 AM
Axxion's Avatar
Liked: 89
4 x orbit shifters
Axxion is offline
post #6 of 20 Old 02-05-2014, 11:22 AM
Liked: 1798
4 x orbit shifters
post #7 of 20 Old 02-05-2014, 11:25 AM
mark62's Avatar
Liked: 88
+1 on the Sub-1200 I would get 2 of them...
http://www.parts-express.com/dayton-audio-sub-1200-12-120-watt-powered-subwoofer--300-629
a review...
http://www.hometheatershack.com/forums/speaker-subwoofer-reviews/71766-dayton-audio-sub-1200-subwoofer-review.html
mark62 is offline
post #8 of 20 Old 02-05-2014, 11:32 AM - Thread Starter
vinz1982's Avatar
this doesn't really solve for my space issue... dayton seems big already... 2 of them (in 2 opposite corners?)
this seems as big as the BIC F12, right?
vinz1982 is offline
post #9 of 20 Old 02-05-2014, 12:04 PM
mark62's Avatar
Liked: 88
F12
21 x 19 x 22 inches (HxWxD)
Dayton Sub-1200
Dimensions: 16-3/4" H x 16-3/16" W x 17-3/4" D.
The dayton 10"
Dimensions: 14-3/4" H x 14-3/16" W x 15-3/4" D
You can just stack the subs, but if you have room placing them in different locations can smooth out the response. I guess as seeing you are in an apartment 1 would be good. I have never lived in an apartment where I could use a sub without upsetting the neighbors.
mark62 is offline
post #10 of 20 Old 02-05-2014, 12:18 PM
Liked: 1798
You're looking for a small, WAF-friendly sub for ~$300, but your room - assuming an 8' ceiling - is ~2,500 cu.ft. in size. If you also want half-decent performance, something's gotta give.
If it's not going to be size, then IMO you should strongly consider bumping the budget to $499 and getting the SVS SB-1000.
It's very compact and offers good performance - see this review for more information - and if you decide you don't like it (or if it doesn't pass WAF), SVS offers free return shipping within 45 days, so the cost of the in-home demo is $0.
post #11 of 20 Old 02-05-2014, 08:41 PM
Gmash's Avatar
Quoted: 144 Post(s)
Liked: 142
Hsu STF-1 (or STF-2 if you raise the budget a little) are good small subs.
Gmash is offline
post #12 of 20 Old 02-05-2014, 10:00 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Outlaw M8 or dayton sub800...neither will do that room any justice but they do fit your size requirement.
Compact
Output
Budget
Pick 2!
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #13 of 20 Old 02-06-2014, 01:10 PM
ClawAndTalon's Avatar
Quoted: 349 Post(s)
Liked: 232
Vinz,
The HSU STF-1 is 300 shipped, and would be a great choice.
"Most theories on audio and audio reproduction will be proven wrong only when the laws of physics change."
ClawAndTalon is offline
post #14 of 20 Old 02-06-2014, 01:54 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Op of you want used sub, I seen some small subs on our local cl. Maybe you might also want to consider used sub.
caloyzki is offline
post #15 of 20 Old 02-06-2014, 06:00 PM
SmittyJS's Avatar
Quoted: 178 Post(s)
Liked: 232
You might want to define your size restriction. Do you require "ultra compact" (say 11" cubed max), or "compact"? I recently did a lot of research on subs in the ultra compact range. I was willing to sacrifice output to avoid having a big ugly box in my living room. However, one problem with size is that small size + relatively high output = high $$$ and small size + low $$$ = low output. Some I considered were Sunfire HRS-8, Earthquake Minime, Nile SW8, Pinnacle Subsonic SW-6.5, Sunfire Atmos, Sunfire True EQ 10 Signature, Mirage MM-6 and Sunfire True Super Junior. The only one you'll sniff for $300 (even used) is the Mirage, and that's only rated to 42Hz, not to mention the company has basically been shut down in the U.S. Besides pipe organ and synths, no instrument I know of goes below 28Hz. Only some of the Sunfires on this list (the models that aren't made anymore) approach that range. So forget the lows of HT, although your low volume level requirements make that seem a low priority to you anyway. But you'll probably have to go up to the "compact" size to fit your price.
SmittyJS is offline
post #16 of 20 Old 02-20-2014, 01:19 PM
mrjenk's Avatar
Hi,
- match my setup
Vince
Vince,
I'm selling a vintage Polk Audio subwoofer (PSW120) that I'm certain would be the perfect fit for your situation. It has served me very well in my former apartment and military barracks. The sub is very compact (13"H x 9.5"W x 19"D). I can gladly answer any questions you may have and provide pictures if you're interested.
mrjenk is offline
post #17 of 20 Old 02-20-2014, 04:08 PM - Thread Starter
vinz1982's Avatar
Originally Posted by mrjenk View Post
Vince,
Hi mrjenk,
if you are in NYC and depending on the price you want to sell this, i might consider. if you are not in NYC, sorry not interested ;)
Vince
vinz1982 is offline
post #18 of 20 Old 02-20-2014, 06:33 PM
mrjenk's Avatar
I'm in Baltimore. Selling price is $125.
Bryan
mrjenk is offline
post #19 of 20 Old 02-20-2014, 08:08 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
Mordaunt Short Aviano 7. Not going to have extension below 30hz, but since you are in an apartment where deep hitting bass could cause problems with neighbors and restricted by the size of the sub, seems like a good option. Fits your budget, too. Let the wife pick the color to make her happy smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #20 of 20 Old 02-20-2014, 09:13 PM - Thread Starter
vinz1982's Avatar
Bryan
Sorry, not interested, but thanks anyway
vinz1982 is offline
Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Dayton Audio Sub 1200 12 120 Watt Powered Subwoofer
