SVS PB12 Plus, where's the love? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 43 Old 02-08-2014, 09:56 AM - Thread Starter
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
This seems to be a neglected subwoofer in terms of popularity.  Upon taking a closer look at it, it seems to have a good spot in the ID market:
Although there are not tons of data out there on it, it seems to be positioned well ahead of all the $1k and under subs, sort of between the VTF15 and Rythmik FV15HP in performance, and not a bad value considering its shipped price of $1399 with the piano black finish.  While the Rythmik offers a little more maximum output, the PB12 plus still offers very competitive overall performance, quality, and value.
It's closest competitor would be the Rythmik, which in piano black is just over $1700 shipped, with probably a few dB of output in some places in exchange for the higher price.
Also the XS30 would be a competitor I suppose in a sealed sub at a lower price without the gloss finish.
Anyway, I just don't see this sub getting talked about much, but it seems like it should be an option for more people.
bear123 is offline
post #2 of 43 Old 02-08-2014, 10:05 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
I think if you can afford $1400 on a subwoofer you probably think why not get the best one availalbe? It's "only" $600 more. Over here the Ultra is £300 more than the plus. Not a massive amount of money.
I went for a SB Ultra 13. Although it doesn't exist a SB Plus 12 would probably be around £1000.
fatbottom is offline
post #3 of 43 Old 02-08-2014, 10:08 AM - Thread Starter
bear123's Avatar
Liked: 2511
Yeah I kind of thought that might be some of it..those with $1400 to drop on a sub might just swing up the the ultra.  But, I would think a lot of people thinking about a $1k sub might swing up to 1400 without considering anything higher.
Maybe we will see an upgrade to their lineup later this year:
PB3000 replace PB12 plus and 13.5" driver
PB4000 replace ultra with 15"!!
A lot of heavy hitters coming out lately, time to swing for the fence.
bear123 is offline
post #4 of 43 Old 02-08-2014, 10:20 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
The PB12 Plus basically gets overshadowed by the FV15HP and the VTF15h. The FV15HP is roughly the same price and is a much more powerful sub. The VTF15h is quite a bit cheaper but offers nearly the same performance. Nonetheless the PB/PC12 Plus looks like a very good sub, maybe the best ported 12" on the market. I can not think of a better ported commercial 12". It has its place in SVS's line up, but maybe it suffers from a kinda of "middle child" neglect. I think SVS's best bang for the buck sub is probably the PC12 Plus.
shadyJ is offline
post #5 of 43 Old 02-08-2014, 01:29 PM
steve nn's Avatar
Liked: 433
+1 I would agree shady. The PC-PLUS is and has been my favorite choice in the SVS line-up for some time and as a all around sub meets the characteristics in a sub I’m looking for. If I was offered a 15HP or the PLUS, I would go with the PC12-PLUS hands down. I understand another not doing so depending on their own criteria.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #6 of 43 Old 02-08-2014, 01:34 PM
BeeMan458's Avatar
Liked: 813
I always considered the Ultra, a over priced, underperformer and considered the PC12-Plus the unloved subwoofer that should get a whole lot more attention.
(although it reads like it, my above is not a knock on SVS or the Ultra)
BeeMan458 is offline
post #7 of 43 Old 02-08-2014, 01:55 PM
AllenA07's Avatar
Quoted: 683 Post(s)
Liked: 554
I was looking for a comparison between the hsu vtf15h and the 12-plus. Really couldn't find much out there. I want a sub that will pressurize the room and I'm not sure the SVS would do that with the smaller driver.
My Theater: The Ugly Theater
AllenA07 is offline
post #8 of 43 Old 02-08-2014, 01:59 PM
BeeMan458's Avatar
Liked: 813
Check out Data-Bass and first couple of posts in the ULF thread.
post #9 of 43 Old 02-08-2014, 03:23 PM
DualMono's Avatar
I have the SVS PB12+ and while it does well with ht, the PB12+ falls short with music, imo. For the cost of the PB12Plus, I would spend the extra $82 bucks and take my chances with the vented Rythmik FV15HP. I would expect more extension/output and better accuracy/musicality.
DualMono is offline
post #10 of 43 Old 02-08-2014, 05:08 PM
Kini62's Avatar
Quoted: 1414 Post(s)
Liked: 1297
The SVS subs are very accurate with a nice built in flat response.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #11 of 43 Old 02-08-2014, 05:16 PM
DualMono's Avatar
A measured "flat" response does not always translate to being a "musical" sub, imo.
DualMono is offline
post #12 of 43 Old 02-08-2014, 06:34 PM
Kini62's Avatar
Liked: 1297
Doesn't hurt. Makes setting it up easier for most folks. You would be hard pressed to find anyone that says SVS subs are not musical.
Def Tech SC8000
Kini62 is offline
post #13 of 43 Old 02-08-2014, 06:45 PM
shadyJ's Avatar
Liked: 1350
There shouldn't even be such a thing as musical or non-musical subs, only accurate or inaccurate subs. No one should ever describe a sub as 'musical'. 'Musical' is worthless as an adjective for a speaker or subwoofer, and is usually only bandied about by audiophiles to excuse a poorly performing piece of equipment.
Tack, AllenA07 and jproy13 like this.
shadyJ is offline
post #14 of 43 Old 02-08-2014, 06:58 PM
Tack's Avatar
Quoted: 2575 Post(s)
Liked: 3471
Because everyone's room and placement is so different, and because of their effect on the sound, a single experience cant be extrapolated into a general statement like "they aren't musical". Doesn't disqualify it either.
A bass curve with a ramp is more "musical" to some. The inclusion of lower frequencies is less "musical" to some too. Dual Mono, it would be interesting to get your impressions of the PB with a 35hz HPF.
Personally, I wish "musical" could be deleted from the adjectives used to describe subs.
Tack is offline
post #15 of 43 Old 02-08-2014, 06:59 PM
Tack's Avatar
Liked: 3471
Tack is offline
post #16 of 43 Old 02-08-2014, 08:05 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
Sorry Bee... but I will respectfully disagree with you. You can say the Ultra is overpriced, I take that (although don't see it that way either....), but certainly NOT an under-performer. Sorry... dude, you are way off on that one. smile.gif The Ultra is SVS's flagship and then some...
| Panasonic TC-P65S2 HD Plasma | Oppo BDP-93 | Paradigm Studio 100's v2 (mains) | Paradigm Studio CC-690 v5 (center) | Paradigm ADP-370 v3 (sides surr.) | Paradigm Studio 20's v2 (sides + back surr.) | SVS PB13-Ultra(x3) | Marantz AV-8801 pre/pro | Emotiva XPA-5 (x2) |
Luis5150 is offline
post #17 of 43 Old 02-08-2014, 09:21 PM - Thread Starter
bear123's Avatar
Liked: 2511
The ultra is priced almost $300 higher than an equivalent(piano black) FV15HP.  The maximum output is about the same, but I am sure other performance parameters are different that may or may not make one sub "better" than the other.  I think both are great subs, but I cannot say that I have analyzed each closely to compare which is possibly the "better".  I believe the Rythmik is a great value considering its output for the price, and its standard finish puts it almost $500 cheaper than the piano ultra.
bear123 is offline
post #18 of 43 Old 02-08-2014, 09:31 PM
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
The ultra series uses very high quality components, that comes at a cost.
deepat04 is offline
post #19 of 43 Old 02-08-2014, 09:37 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
True on all accounts bear, but the Ultra oozes of quality that the Rythmik simply cannot match and as such, it should cost more. And when you take into account shipping cost on the Rythmik is not really that much cheaper.
Luis5150 is offline
post #20 of 43 Old 02-08-2014, 10:37 PM
LowerFE's Avatar
Liked: 41
It's also worth mentioning the quality of the driver the SVS uses in the Ultra. Looking at data bass, from 20-80Hz, the PB13 produces no more than 7% THD no matter how loud it is driven. Sure, SVS clamped the output to achieve that, but it is still one of the loudest subwoofers in the market and manages to hold the record for the highest 20Hz output of all commercial subs tested, with just a single 13.5'' driver being held back by its limiter. It is producing almost 111dB with just 5.1% distortion. For comparison, the FV15HP produces half the 20Hz output with more than 3 times the distortion (108dB at 17.7%), and that's servo controlled to reduce distortion. Most of the other subs are producing around 20% distortion while producing an output far less than the Ultra.
The PB12, from what I've read, uses a 12'' version of the Ultra driver, and it is pretty much a 12'' version of the PB13. A good part of the cost went to the excellent driver of the PB12-Plus. While it might not be the loudest in their price range, the PB12/PB13 probably represents the highest performing subwoofer of their driver size. With that said, the PB13's driver cannot match the 13.5'' driver in the JL F113. Comparing PB13's sealed mode to the F113 reveals 3-4dB less output than the F113, even with a much bigger cabinet.
Luis5150 and salehdidit like this.
LowerFE is offline
post #21 of 43 Old 02-08-2014, 10:52 PM
BeeMan458's Avatar
Liked: 813
And I support your right to have your above opinion. In my opinion, it's okay to have an opinion and it's okay to disagree with another person's opinion. What's important is if you stand by your opinion......which I do. smile.gif
At no time am I knocking the cost of the parts found in an Ultra. Just saying, every one of my comments is not a call to arms. Folks have to come to grips that folks who post in these forums are not always go hold the same opinion, another does.
post #22 of 43 Old 02-08-2014, 11:00 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
Well put BeeMan... smile.gif as usual. And we can disagree and I respect you for it.
Luis5150 is offline
post #23 of 43 Old 02-08-2014, 11:05 PM
BeeMan458's Avatar
Liked: 813
post #24 of 43 Old 02-09-2014, 12:03 AM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 115
LMAO.... That was classic!!!
Luis5150 is offline
post #25 of 43 Old 02-09-2014, 12:44 AM
AllenA07's Avatar
Quoted: 683 Post(s)
Liked: 554
Well... It won my heart. I just got myself the PC12-plus. I'm a little worried going with this over the HSU vtf-15, but the numbers looked solid.
Tack likes this.
AllenA07 is offline
post #26 of 43 Old 02-09-2014, 01:54 AM
Tack's Avatar
Liked: 3471
Agreed. On this forum, newer members need to separate post count from actual knowledge.The Ultra represents a high point in sub design. Whether it's in the budget or not, there's no denying the excellence of the design and the quality of the individual components. Tom V put everything he's learned into this sub and it shows. What other sub has been around this long and is still in the discussion for top sub? Plus, I can think of no other ported sub that can have all the ports plugged and become a legitimate true sealed sub.
It may not be perfect,but it's not just some driver in a box either.
steve nn likes this.
Tack is offline
post #27 of 43 Old 02-09-2014, 03:21 AM
BeeMan458's Avatar
Liked: 813
post #28 of 43 Old 02-09-2014, 07:26 AM
trolly's Avatar
Quoted: 62 Post(s)
Liked: 48
I'm not tolerant of poorly made goods. I've had my PB12-Plus DSP for about 2 years and still admire it....Every part of it is of very high quality including performance.
trolly is offline
post #29 of 43 Old 02-09-2014, 07:46 AM
steve nn's Avatar
Liked: 433
I can’t seem to find the weight of the FV15HP DS1510 driver, anyone know how much it comes in at? just wondering.. I believe the 13 ULTRA driver is 50.5 or 52 pounds I forget.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #30 of 43 Old 02-09-2014, 07:55 AM
warpdrive's Avatar
Liked: 48
The Ultra drivers are so pretty....they should put a window at the top of the enclosure so you can peer at it, they need to make an acrylic version of their sub like Velodyne did.
While the $2K spent on the PB13U may not necessary mean the maximum dB/$ spent, it's nice to know they pulled out the stops in the design and quality of the sub.
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
Svs Pb12 Plus Black Oak 12 Inch 800 Watt Powered Subwoofer , Fv15hp Subwoofer , Hsu Vtf 15h Subwoofer
