will this work(hook-up question) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-12-2014, 03:36 PM - Thread Starter
mercury's Avatar
Liked: 101
unfortunately i did not get my Y splitter today and would like to start to dial these in-
would this work for now??
Panasonic 65" plasma*
Denon 4520*
PSB T45* PSB B15* PSB C60*
Dual PSA XS30* Dual PSA XS15se*
Squeezbox*
Niles ZR-6 6 Source, 6 room Audio Reciever*
mercury is offline
post #2 of 5 Old 02-12-2014, 03:51 PM
BeeMan458's Avatar
Liked: 813
Yes.
Waiting to get your "two" XS30s dialed in has to be killing you.
A suggestion, run your EQ program today and in about two or three weeks, after everything has loosened up (40hr break-in period) re-run your EQ program which will give you an accurate EQ'g as they will have loosened.
Another suggestion, run your subwoofers for "at least" a half-hour before dialing them in as a warming up amplifier does have changing output characteristics. I learned this after a few warm-ups, noticing changing measurements, old vs new and as the amplifier warms up, the measurements return to their old, last saved measurement which is being used as a baseline measurement.
Good luck and congratulations on their arrival and pending installation.
BeeMan458 is offline
post #3 of 5 Old 02-12-2014, 04:08 PM - Thread Starter
mercury's Avatar
Liked: 101
Thanks....I'll keep this threat updated if I run into any problems question. Pumped
Denon 4520*
Squeezbox*
mercury is offline
post #4 of 5 Old 02-12-2014, 04:14 PM
BeeMan458's Avatar
Liked: 813
Stay stoked and rock on.
post #5 of 5 Old 02-12-2014, 04:27 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
Yes.
Randy
ransac is offline
