Best compact subwoofer - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 02-14-2014, 03:18 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
I think due to space contraints (for some reason you have no floor for the sub to rest on) best not to buy a subwoofer.
fatbottom is offline
post #32 of 33 Old 02-14-2014, 03:52 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
Velodyne MicroVee, if you can squeeze it in, the MiniVee.
bear123 is offline
post #33 of 33 Old 02-15-2014, 01:39 PM - Thread Starter
Stigwort's Avatar
Thanks I will check out the Velodyne MicroVee. Based on the placement of the feet, the Definitive Technology SuperCube 2000 also fits.
Stigwort is offline
Cambridge Audio Minx Min 11 Speaker , Mirage Mm 6 Miniature High Performance Subwoofer Black , Pinnacle Speakers Subsonic Dual 2 6 5 Inch 350 Watt Powered Side Firing Subwoofer Black , Pinnacle Speakers Subcompact 300 Watt Powered Subwoofer Black , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs
