AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Subwoofers, Bass, and Transducers (http://www.avsforum.com/forum/113-subwoofers-bass-transducers/)
-   -   Best compact subwoofer (http://www.avsforum.com/forum/113-subwoofers-bass-transducers/1517633-best-compact-subwoofer.html)
Stigwort 02-13-2014 11:08 AM
Hi:
I am looking for a compact subwoofer to sit on a structural/kneewall 9.5" shelf in a 16'x16' walled room. These seem to be my best options (in terms of size and max RMS watts), although I am not sure if the Mirage is being discontinued.
Name
URL
RMS watts
Size
Price
W
H
D
Cambridge Audio Minx X200
URL
200
6-1/2"
$400
8.3"
8.6"
8.7"
Mirage MM-6 miniature*
URL
200
6-1/2"
$300
8"
8"
8"
Pinnacle SUBcompact 6
URL
6-1/2"
$188
9.25”
8”
9-3/8”
Pinnacle SubSonic
URL
200
6-1/2"
$300
9.443"
9.224"
9.479"
Does anyone have any thoughts on which one is "best"? I plan on using it with these Monoprice 5.1 Premium speakers:
http://www.monoprice.com/Product?c_id=109&cp_id=10906&cs_id=1090601&p_id=10565
and listening to movies primarily, but also music. Any advice would be appreciated!
eljaycanuck 02-13-2014 11:16 AM
A "sub" with a 6-1/2" driver and likely less than 100W RMS isn't going to do much subwoofering in a 16' x 16' room. So, IMO, go with any of the ones that fit your budget. They'll all give you roughly the same performance.
-- Edit --
I just checked the subs' power ratings and I stand corrected: The Mirage MM-6 has a 200W RMS amp.
I took a quick look at the other subs' product pages and owner's manuals and I didn't see any mention of RMS in the power ratings:
- Pinnacle SUBcompact6 - 200W
- Pinnacle SubSonic - 350W
- CA Minx x200 - 200W
Stigwort 02-13-2014 11:20 AM
These all claim 200W RMS.....
Stigwort 02-13-2014 12:36 PM
I think they are all 200 rms- click the 200 links in the table above and also see
http://www.audioadvisor.com/Cambridge-Audio-X200-Subwoofer/productinfo/CAMIX200/#.Uv0eJ9so6Ml
eljaycanuck 02-13-2014 12:59 PM
Your links are to Amazon. I went to each company's website and checked the product pages and the owner's manuals.
fatbottom 02-13-2014 01:21 PM
Can't really expect a tiny little sub to fill a room that large, unless you get one of the higher end models like couple of SB2000.
As for speakers..not going to fill a room of that size
Bill Fitzmaurice 02-13-2014 01:32 PM
No matter, what limits the output of a sub isn't watts, it's the displacement of the driver, ie., how much air it can move. A 6.5 can't move enough to make it worthwhile having. In a room your size for HT you need a ten, minimum. Find another place to put it.
fatbottom 02-13-2014 02:05 PM
Forgot having a cheap sub, and cheap $250 HTIB in a room of that size. Good, tiny subs are ones like Carver subwoofer. Certainly a bit more than a couple of hundred dollars. For a room of that size I'd be looking at a PCi at the minimum
Stigwort 02-13-2014 06:53 PM
re "you need a ten, minimum"
What do you think of the Pinnacle SubSonic claim that its "two 6.5-Inch woofers create the equivalent surface area of 1 super powerful 10-Inch woofer"
deepat04 02-13-2014 07:10 PM
Very subjective because not all 10" subs perform equally. So is it equal to a Polk psw10 or svs PB1000?
Svs has a Pb1000 for $450 shipped in their outlet.
Need compact? sb1k or sb12 NSD by SVS
eljaycanuck 02-13-2014 07:13 PM
The two drivers creating the equivalent surface area of:
- a ten-inch sub sounds reasonable;
- a "super powerful" ten-inch sub does not.
Stigwort 02-13-2014 07:20 PM
The sb1k or sb12 are all too large. Fatbottoms suggestion of the Carver XTATM265 is interesting though. It claims to have 1400 watts rms.
eljaycanuck 02-13-2014 07:24 PM
You can get a used one on eBay for only $1,000.
Stigwort 02-13-2014 07:40 PM
Thanks for the ebay tip! So is this the only sub less than 9.5" dimensions (dimensions which basically mean a 6-1/2" driver), that has decent rms? The difference in watts is huge (as is the price!) but it seems to fit the bill. Any other manufacturers anyone knows with such a small unit and decent rms watts for a 16x16 ft room?
I really appreciate all the help so far!
Bill Fitzmaurice 02-13-2014 08:38 PM
What do you think of Pinnacle SubSonic claim that its two 6.5-Inch woofers create the equivalent surface area of 1 super powerful 10-Inch woofer
Aside from the fact that they won't, totaling 250 sq cm versus 350sq cm for a ten, it doesn't matter. Output capability isn't determined by surface area, it's determined by surface area multiplied by excursion, which equals displacement. Not only do 6.5s have less surface area, they also have less excursion. An average pair of 6.5s would displace 250cc total, an average ten 600cc.
Watts don't matter. Displacement does.
cel4145 02-13-2014 08:40 PM
Do you have to use those tiny satellites? With your total budget for speakers and sub, honestly, if I had to choose between your options of using that small sub with those speakers, I would simply get much bigger bookshelf speakers and skip the sub.
Stigwort 02-13-2014 09:24 PM
The company says that on the XTATM265  "the displacement created by the dual drivers is equivalent to one big 12-inch driver."
I will upgrade those later, but the fact that I need to put the subwoofer on a 9.5" wall is not going to change due to the function of the room.
bear123 02-13-2014 09:35 PM
I think the problem here is that the people responding have a pretty good idea what they are talking about.  As such, they understand that a 6.5" speaker in a tiny box is not a subwoofer and can not defy the laws of physics to somehow function as one.  Also, I don't think people are going to recommend something that won't work for you.  If you are unwilling to consider an option that can realistically work, you may have to simply choose what you think looks the best, as it isn't going to perform well regardless.
The smallest, cheapest option for your needs is the SVS SB1000, $449 shipped from the outlet page.  It is 13" on all sides it will perform better than five of the mini speakers you are looking at.
Don't take this the wrong way, you just have to realize that within your space constraints, its not going to work well enough for people to make a recommendation,
Bill Fitzmaurice 02-13-2014 09:37 PM
The company says that ...displacement created by the dual drivers is equivalent to one big 12-inch driver."
How many cc? A good twelve is 900cc.
I agree.
bear123 02-13-2014 09:44 PM
From Sound and visions test of this subwoofer, max output:
20 Hz        NA
25 Hz        76.1 dB
31.5 Hz     89.5 dB
 "There wasn’t enough output at 20 Hz to get a measurement"
And this is a $1200 mini sub.  Imagine how well the $300 subs with 6.5" speaker will perform.
jchong 02-13-2014 09:58 PM
Hi:
Is this the only place you can put the sub? The 9.5" depth is your main limiting factor. Although you've listed the various dimensions of the subs you're considering, don't forget to make extra allowance for the connectors and cables - this could add another 2" - 3" depth required.
If you can, do seriously look for another space which allows you to put in a bigger sub. Don't get too caught up by the claims you've read for those small subs.
bear123 02-13-2014 10:13 PM
Remember, a subwoofer can often be hidden in a room, perhaps in a corner, behind a piece of furniture, etc.
cel4145 02-14-2014 08:20 AM
Yep. The only practical use of these 6.5" subs is with small satellites in a computer desktop setup where one is sitting 2 or 3 feet from the sub. Then it's role is to supply midbass that the tiny speakers don't have, more of a midbass module than a subwoofer. And it won't fill a room with bass. It works because one is sitting so close.
Anyway, here is the only sub I know of that can fit on 9.5" shelf and could do well in that room, but it's way out of your budget range: http://www.paradigm.com/products-current/model=milleniasub/page=overview
Stigwort 02-14-2014 08:23 AM
 SVS SB1000
Unfortunately this is too big. Everyone here is very knowledgeable, and I think the discussion is extremely useful for those looking for compact subwoofers in general (even without my size requirements). I don't think SVS does an (ultra-) compact subwoofer.
Yes, thanks. I am going to use angle connectors to keep this to a minimum.
So for me especially, the XTATM265 is the best so far. Are there any other comparable competing *compact* subwoofers out there? They would probably be high-end retailer only ones like the Sunfire, otherwise I would have stumbled on them in my shopping searches by now.
cel4145 02-14-2014 08:31 AM
Yes. The Paradigm MilleniaSub that I just posted above. It has excellent measured output down to around 30hz.
bear123 02-14-2014 09:06 AM
Without doing a lot of searching it seems these two would offer good bass for music, the sacrifice being of course that they won't have much under 30Hz.  Good output for their sizes though.  BB mentioned the upper bass output of the sunfire seemed a bit low, so might want to consider how low your satellites will go.
cel4145 02-14-2014 09:11 AM
Well, and the Paradigm MilleniaSub is really designed for a shelf placement like the OP has with it's narrow profile. More output than the SVS SB-1000 would have, and I'd bet on the MilleniaSub to have more output than the Sunfire.
fatbottom 02-14-2014 12:29 PM
Why is a 12" sealed box "too large" I have a 12" SB in a 3.5m x 3.5m room and no problem. And in another room similar size a SB Ultra 13.
Just place it on the floor.
You will regret buying XTATM265, 6.5" cannot match output or frequency response of a 12" sealed box. Plus it's several times more expensive, you can buy a second hand SVS SB 12 for £300. It won't be able to fil a room of that size.
A ported sub with 300W amp 12" will have far greater output than that XTATM265 which has 1kW+ It's not about power it's about efficinecy. A SVS PCi would utterly destroy a XTATM265 (granted it's bigger but because it's ported it's "only" 300W) but it would have probably +10dB output or even more at 30hz, and below.
eljaycanuck 02-14-2014 01:21 PM
Why is a 12" sealed box "too large" ...
If you check the OP's original post, he lists a size max for at least one dimension:
I am looking for a compact subwoofer to sit on a structural/kneewall 9.5" shelf ...
bear123 02-14-2014 03:13 PM
I think they are bad at math.  Area= pi*radius squared
Area of two 6.5" woofers = 3.14*3.25*3.25*2=66.325 sq. in.
Area of one 10" = 3.14*5*5 = 78.5 sq in., which is 18% more surface area than dual 6.5"
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
