12x12 room home theatre sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 58 Old 02-14-2014, 09:13 PM - Thread Starter
f430's Avatar
I have a 12x12 room with cathedral ceiling
Yamaha RX-V475 80W x 5.1 with PSB alpha B1's
What's a good awesome sub to fill the room keeping in line with the PSB and Yamaha budget?
BenQ W1070 - DENON AVR-E400 7.1 - SLS Q-Line Gold - Hsu VTF-2 MK4
Watch the progress http://www.avsforum.com/t/1517374/budget-build
f430 is offline
post #2 of 58 Old 02-14-2014, 09:26 PM
eljaycanuck's Avatar
Quoted: 1342 Post(s)
Liked: 1956
eljaycanuck is offline
post #3 of 58 Old 02-14-2014, 11:01 PM
vanut's Avatar
vanut is offline
post #4 of 58 Old 02-15-2014, 07:01 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3000
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #5 of 58 Old 02-15-2014, 07:13 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
I would go with the PB12-NSD. At that price it is a no-brianer over the PB1000. In a 12'x12' I would also be looking at a Reaction BPS 212 Turbo.
shadyJ is offline
post #6 of 58 Old 02-15-2014, 11:57 AM - Thread Starter
f430's Avatar
Originally Posted by eljaycanuck View Post
SVS PB-1000 ($499, shipped).
I asked SVS and they recommended the 1000.
For $100 more is there a chance the 12 can kill the room or be too much?
I don't want to "bigger is better" and over-cam my car if you know what I mean.
f430 is offline
post #7 of 58 Old 02-15-2014, 12:22 PM
bass addict's Avatar
Quoted: 366 Post(s)
Liked: 442
Not a great analogy is all seriousness. Over camming is a lot different than picking up a larger sub. I always say error on the side of caution. There is no downside to a larger sub (barring space and budget constraints). It will provide more headroom, and room to grow should you find yourself wanting more bass down the road.
Achievement Unlocked
Psychotic Episode Averted
bass addict is online now
post #8 of 58 Old 02-15-2014, 12:46 PM
Ozzie Isaac's Avatar
Liked: 102
You can never turn up a small sub up, but you can always turn a big sub down ... my FV15HP runs at -7db most the time, but occasionally I like to go to 0 and let her eat.
Ozzie Isaac is offline
post #9 of 58 Old 02-15-2014, 01:31 PM
CHASLS2's Avatar
Quoted: 573 Post(s)
Liked: 233
My SVS SB12 NSD goes great for my 12x14 bedroom.
Panny 60VT60 Acurus 200x3
OPPO 83 &103
Pioneer Elite DV 59AVI
Paradigm 490cc B&W 685 S2's
Pioneer Elite SC61 SVS SB13Ultra
2 S-VHS VCR's B&W CM10 S2's
CHASLS2 is offline
post #10 of 58 Old 02-15-2014, 02:27 PM
Quoted: 75 Post(s)
Liked: 112
For $100, I would take the 12, but the 1000 is more than enough for that room.
rnatalli is offline
post #11 of 58 Old 02-15-2014, 04:30 PM - Thread Starter
f430's Avatar
Thank you.
Now I have to figure out how to break it to the wife that there's "just one more thing" then I'm done biggrin.gif
f430 is offline
post #12 of 58 Old 02-15-2014, 04:39 PM - Thread Starter
f430's Avatar
That's what SVS says too. I guess I'll get the bigger one just in case I move rooms? Ya'll sure I can turn it down and still make it work OK?
From SVS:
"The NSD will be quite a bit louder than the PB-1000 in that room size to say the least. For $100 more, the NSD is a big step up from the 1000, but in that room size, the 1000 will have more than enough output and then some"
Looking at ordering and keep waffling back and forth...
f430 is offline
post #13 of 58 Old 02-15-2014, 05:07 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4779
I'd agree with the PB12, you can't have too much sub (and yes, you can easily keep it where you want it loudness-wise and it will sound just fine).
lovinthehd is offline
post #14 of 58 Old 02-15-2014, 09:04 PM
cel4145's Avatar
Liked: 3000
Yep. Won't hurt to go up a notch. I agree with everyone else that it definitely seems worth the $100. And once you've got the gain (volume) on the sub configured to integrate into your system, it will work great.
cel4145 is offline
post #15 of 58 Old 02-15-2014, 09:30 PM - Thread Starter
f430's Avatar
Ordered! Got the feet and a cable too.
f430 is offline
post #16 of 58 Old 02-23-2014, 12:29 AM - Thread Starter
f430's Avatar
Well, they cancelled my order because I am in Canada.
And, the Canadian distributor is out of stock.
Oh well.
Has anyone used this sub? BIC America V-1220 12-Inch 430-Watt Down-Firing Powered Subwoofer
http://www.amazon.com/BIC-V-1220-430-Watt-Down-Firing-Subwoofer/dp/B0000Y2WYS/ref=sr_1_3?s=electronics&ie=UTF8&qid=1393143978&sr=1-3&keywords=BIC+America+F12+down+firing
Or this one? BIC America F12 12-Inch 475-Watt Front Firing Powered Subwoofer
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=sr_1_1?s=electronics&ie=UTF8&qid=1393143978&sr=1-1&keywords=BIC+America+F12+down+firing
f430 is offline
post #17 of 58 Old 02-23-2014, 04:37 AM
raynist's Avatar
Quoted: 1526 Post(s)
Liked: 1487
Those subs are big steps down from the pb12
eljaycanuck likes this.
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
post #18 of 58 Old 02-23-2014, 05:57 AM
Liked: 1956
post #19 of 58 Old 02-23-2014, 06:53 AM - Thread Starter
f430's Avatar
I've never had a sub
Is the svs three times as good?
f430 is offline
post #20 of 58 Old 02-23-2014, 07:06 AM
bear123's Avatar
Quoted: 1783 Post(s)
Liked: 2621
35-100Hz output from a sub comes cheap.
Clean, distortion free output flat down to 18 Hz(or lower) costs quality components and money.  I would say yes.
bear123 is online now
post #21 of 58 Old 02-23-2014, 07:27 AM
cel4145's Avatar
Liked: 3000
Many of us think so. Budget subs are major compromises on some aspect of subwoofer design.
cel4145 is offline
post #22 of 58 Old 02-23-2014, 01:35 PM - Thread Starter
f430's Avatar
Ok thank you.
This makes sense. Like when I first got into Rifle's and bought a cheap scope that had all the right specs. After a while you spend $$$ on a scope that's actually good because you figure it out.
Not saying I might start on a starter sub still to stay in budget and save money ... but I do understand some people live with the cheap scope forever, and some need to upgrade. My ears will tell me I guess smile.gif
f430 is offline
post #23 of 58 Old 02-23-2014, 02:04 PM
dsrussell's Avatar
Quoted: 2254 Post(s)
Liked: 3085
Poor BIC. Rarely gets any love. In one of the subwoofer shootouts where they were testing about a dozen subwoofers (large DIY and I.D. subs, including Seaton and JTR), one brought in a BIC F12. How did it do? The F12 finished dead last for movies and second to last for music. Totally overmatched? Obviously. Yet, many of the attendees were surprised that the small BIC performed as well as it did against the brutes that were there.
I own a BIC VT1220 (Christmas gift from my son), and used it for years to help solidify a small stereo setup I have for movie viewing. For decades BIC speakers and subwoofers have been known for solid performance on a tight budget, and it was the BIC that got me interested in subwoofers in the first place. It's inexpensive and gives some surprising punch for its size and price. I now own an SB13-Ultra (for music) and replaced the BIC with an XS30 for movie viewing (the BIC is now pulling duty in my computer room).
The BIC could never get down to where my walls would slam, shake and rattle anything and everything that wasn't securely attached, including myself. But it's not fair to compare a Sub that may cost between $140 to $220 to those that costs $1,150 and $1600. Are either of my new subwoofers 8 plus times better (they certainly are 8 plus times the price)? No, of course not. But there is a price to pay for real subsonic performance, and there is always diminishing returns on your investment to attain that level. It's simply the price of admission to the subsonic realm.
In a room your size (considered small), just about any of the I.D. subwoofers manufactured today (in the $400 and up price range) will do wonders and will outperform the BIC (some by a small margin, some by a large margin). It's up to you to determine what you want to start out with and what you are willing to spend. Just remember that no matter what you buy and no matter the price, there is always something bigger, badder and better out there.
Music area: Magnepan 3.6, McIntosh MC2205 amp & C48 preamp, SVS SB13-Ultra, Oppo BDP 95, dbx 3BX, and assorted equipment.
Movie area: EMP Tek E5Bi (were rebadged to R5Bi), RBH/EMP Tek R55Ti, PSA S3000i, Denon X2000, Oppo BDP 83.
dsrussell is offline
post #24 of 58 Old 02-23-2014, 06:37 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
I too started out with a pair of BIC F-12's. I thought they were great for the $400 I spent for them. And yes, no matter what you have, there is always something bigger and badder out there. If not, check back next week, there ill be.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #25 of 58 Old 02-23-2014, 06:45 PM
cel4145's Avatar
Liked: 3000
Ok thank you.
Exactly.
The other thing is that subs are also like rifles. A good .22 can work great for small game, but you wouldn't want to go up against a bear with it. The bigger the room, the more powerful the sub you need. Now assuming your room doesn't open into other rooms (subs see all the volume of space), then there are more budget level 12" subs that would do OK in overall max SPL in it.
cel4145 is offline
post #26 of 58 Old 02-24-2014, 11:16 AM
ermghoti's Avatar
Quoted: 57 Post(s)
Liked: 84
If you use them in an apartment after midnight, you'll quickly get a knock on the door.
ermghoti is offline
post #27 of 58 Old 02-25-2014, 06:29 PM - Thread Starter
f430's Avatar
Check out these charts f12, then pl-200, then Hsu, and SVS
f430 is offline
post #28 of 58 Old 02-25-2014, 07:43 PM
shadyJ's Avatar
Liked: 1351
I wouldn't group the f12 in there as I think that is an in-room response and not a ground plane response. Any sub's response will get ugly in room.
shadyJ is offline
post #29 of 58 Old 02-26-2014, 06:24 AM - Thread Starter
f430's Avatar
Thank you
I'm learning every day did not know that!
Jason
f430 is offline
post #30 of 58 Old 02-26-2014, 08:47 AM
Greg Ulate's Avatar
Is there a link to a thread that compares all these and shows those charts?
Denon AVR 1709 + B&W 683s floors + B&W HTM62 center + Energy ESW-8HG Sub
Yamaha HTR-6050 + JBL Studio 530 + Studio 520C
Greg Ulate is offline
Yamaha Rx V475 5 1 Channel Network Av Receiver , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Fv15hp Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer
