BIC Pl-200 or HSU vtf1 mk2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-15-2014, 07:43 PM - Thread Starter
Line voltage's Avatar
I think I've narrowed my search down to these two subs. My question is, would you spend the money on the HSU? This is going in a 2000 cubic foot room.
Denon avr-x2000
Monster HTS 5100 MKII
B&W FPM 5 L/R
B&W FPM 6 C
B&W in ceiling 6.5" surround
SVS PB-1000
PS-4
Samsung blu-Ray
Samsung 51" plasma
Line voltage is offline
post #2 of 12 Old 02-16-2014, 08:20 AM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2985
Either sub should have enough bass for a 2000 cubic ft room unless you are an extreme basshead (in which case, you would need a more expensive sub).
I would go for the HSU vtf1 mk2 over the BIC PL-200 for its more linear, deeper bass extension. Another sub you could consider in the same price range is the SVS PB-1000.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 12 Old 02-16-2014, 07:24 PM - Thread Starter
At this point I hope the BIC will do. The rest of the basement is adding up fast and the extra $200 will be needed elsewhere. Thanks for the input.
Denon avr-x2000
B&W FPM 5 L/R
B&W FPM 6 C
SVS PB-1000
PS-4
Samsung blu-Ray
Samsung 51" plasma
post #4 of 12 Old 02-17-2014, 07:09 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Buy the HSU....the extra 200.00 is well worth the quality of bass you will gain over the BIC.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #5 of 12 Old 02-17-2014, 05:03 PM - Thread Starter
I can see this will be like the golf forum where I need a putter and end up with a whole new set of clubs:)
If I go with a down firing sub, does this affect placement?
Denon avr-x2000
B&W FPM 5 L/R
B&W FPM 6 C
SVS PB-1000
PS-4
Samsung blu-Ray
Samsung 51" plasma
post #6 of 12 Old 02-17-2014, 05:06 PM - Thread Starter
Maybe the stf-2 is more up my alley... Is it really the same sub minus the Q control?
Denon avr-x2000
B&W FPM 5 L/R
B&W FPM 6 C
SVS PB-1000
PS-4
Samsung blu-Ray
Samsung 51" plasma
post #7 of 12 Old 02-17-2014, 05:08 PM
torqueit's Avatar
Have you considered the STF-2? Very similar to the VTF 1 tuned for maximum reach. I've got it in a much larger room and it performs well.
torqueit is offline
post #8 of 12 Old 02-17-2014, 05:12 PM
dsrussell's Avatar
Quoted: 2223 Post(s)
Liked: 3018
No. Consider any subwoofer, no matter the orientation or number of drivers as a point source that radiates outward.
Music area: Magnepan 3.6, McIntosh MC2205 amp & C48 preamp, SVS SB13-Ultra, Oppo BDP 95, dbx 3BX, and assorted equipment.
Movie area: EMP Tek E5Bi (were rebadged to R5Bi), RBH/EMP Tek R55Ti, PSA S3000i, Denon X2000, Oppo BDP 83.
dsrussell is offline
post #9 of 12 Old 02-17-2014, 06:01 PM - Thread Starter
Ok. The stf-2 seems like a winner for me. I was hoping to stay in the $300 range. One of the threads I read recommended the BIC at that price point. The HSU subs seem to be great speakers.
Denon avr-x2000
B&W FPM 5 L/R
B&W FPM 6 C
SVS PB-1000
PS-4
Samsung blu-Ray
Samsung 51" plasma
post #10 of 12 Old 02-18-2014, 12:55 PM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
In the PL-200 forum, a number of individuals have upgraded from the F12 and indicated that the PL-200 is better than the F12.
Some individuals have upgraded from the PL-200 to the STF2 and indicated that the STF2 is better. I have a STF2 and my son has a PL200. The STF2 plays lower and is better with music.
wwinkler is offline
post #11 of 12 Old 02-18-2014, 01:19 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
Hsu is a very solid choice if you have to spend less than $500 on a sub.(they have better ones too, but probly amongst the best if choosing a cheaper sub.)
bear123 is offline
post #12 of 12 Old 02-18-2014, 01:24 PM
ClawAndTalon's Avatar
Quoted: 349 Post(s)
Liked: 232
The HSU VTF 1 is far and away the better choice here.
If budget concerns come up, take a look at the HSU STF 2
Also with that room, you might can get away with the SVS SB1000
"Most theories on audio and audio reproduction will be proven wrong only when the laws of physics change."
ClawAndTalon is offline
Bic Pl 200 Acoustech Platinum Series Subwoofer
