Klipsch Synergy Sub-12 or Dayton Audio 1200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-16-2014, 09:40 PM - Thread Starter
BombaytheGreat's Avatar
The Dayton comes highly recommended, but the Klipsch (previously out of my budget range) is on sale.
BombaytheGreat is offline
post #2 of 7 Old 02-16-2014, 11:14 PM
Boomassiv's Avatar
Quoted: 118 Post(s)
Liked: 50
For how much?  The Dayton should be 140-50 shipped.
Boomassiv is offline
post #3 of 7 Old 02-17-2014, 07:42 AM - Thread Starter
199.  see links above.  Is it worth the extra 50?
post #4 of 7 Old 02-17-2014, 07:53 AM
eljaycanuck's Avatar
Quoted: 1225 Post(s)
Liked: 1794
I had a chance to play a bit with a Sub-12 a couple of years ago. It seemed like a pretty decent sub - lots of power, reasonably good extension - although the colleague who bought it complained that it could get boomy. Then again, he had satellite speakers all around and was crossing over to the sub at ~120Hz. An 80Hz crossover should reduce (eliminate?) the possibility of boominess.
All that to say: For only $50 more, I'd take the Sub-12 over the well-rated SUB-1200.
eljaycanuck is offline
post #5 of 7 Old 02-17-2014, 04:57 PM - Thread Starter
Thanks, eljay!
Anyone else have experience with 1 or both subs?
The Klipsch is a little larger (a con for me), but it does have a 2-yr warranty (vs 1-yr for Dayton).
Response is 24-120 Hz for Klipsch and 25-140 Hz for Dayton.
post #6 of 7 Old 02-17-2014, 06:55 PM
Liked: 1794
FWIW:
- The Klipsch's FR rating of 24-120Hz has a variance of +/-3dB (IOW, 24Hz @ -3dB).
- The Dayton's FR rating of 25-140Hz has no variance. It likely doesn't extend below 30Hz @ -3dB.
post #7 of 7 Old 02-18-2014, 07:08 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5201
A friend had a Sub1200 next to a Synergy-Sub10 and the Klipsch sounded a little thicker and deeper. The Dayton is fairly accurate for a 129.00 sub. Either should work well for the money.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Dayton Audio Sub 1200 12 120 Watt Powered Subwoofer , Klipsch Sub 12hg Synergy Series 12 Inch 300 Watt Subwoofer With High Gloss Trim Black
