aura bass shaker setup (4) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-17-2014, 07:10 AM - Thread Starter
nhjeff1's Avatar
I am new the forum and have questions on some setup.
I recently acquired some berkline seats that have four aura bass shakers. I did search on here but can't find a step by step on it.
My gear already setup is a new pioneer vsx-523, onkyo 5.1 speaker setup, 300w plate amplifier see pic.
My understanding is I need to split the sub channel out but what do I pull it into on the plate amp., how do I also wire the shakers so I don't destroy them to the amp? I see the amp has two wires out the back and also inputs marked on front (see pics). I also found this other diagram on here but that's using another rec. As the amp for the shakers. (See pic)
Thank you for the help looking to setup for presidents day movie marathon.
Jeff
nhjeff1 is offline
post #2 of 15 Old 02-17-2014, 08:23 AM
Richard Cohen's Avatar
Quoted: 26 Post(s)
Liked: 37
You want the shakers in a "series parallel" configuration.
http://www.allaboutcircuits.com/vol_1/chpt_7/1.html
That should give you 4 ohms at the plate amp. That grouping then connects to the load side of the plate amp. You connect your split out put of the subwoofer receiver output to the plate amp input using a single RCA plug.
I assume your plate amp is a 4 ohm spec
Home Theater Forum - fun place and nice people
http://www.hometheaterlounge.com/forum.php
Richard Cohen is offline
post #3 of 15 Old 02-17-2014, 08:27 AM - Thread Starter
nhjeff1's Avatar
THANK YOU!!
Sorry very new to this what is the load side the one with all the connections or the two wires out the back.  Also do I need one wire from the split from the receiver?  So one Y to sub then the other from the split to the amp? If so where to connect that or do I need Line in L & R?  So in other words two Y's?  Does the wiring in the handwritten pic in my post work?
nhjeff1 is offline
post #4 of 15 Old 02-17-2014, 08:33 AM
Quoted: 26 Post(s)
Liked: 37
You only need the RCA plug to go into the plug on the plate amp either the left or right input.
The red and black output wires of the plate amp normally is connected to the subwoofer. In your case the bass shakers are replacing
the subwoofer.
The diagram you provided would need two plate amps since they used the left and right receiver amps with each side seeing a series 8 ohm load
post #5 of 15 Old 02-17-2014, 08:42 AM - Thread Starter
nhjeff1's Avatar
ok so use the wires coming out of the back of the amp for the - and + and leaving the connections on the front alone?  Does the shaker wiring look ok but plug into the wires on the back?  Sorry again very new.
nhjeff1 is offline
post #6 of 15 Old 02-17-2014, 08:49 AM
Quoted: 26 Post(s)
Liked: 37
Sorry about the poor sketch
post #7 of 15 Old 02-17-2014, 08:53 AM
Quoted: 26 Post(s)
Liked: 37
The RCA gets plugged into the left IN on the plate amp
post #8 of 15 Old 02-17-2014, 08:53 AM - Thread Starter
nhjeff1's Avatar
AWESOME!!  Thank you!!
One last question..Do In need to splice the wires together between S1 + to S3 - or can I just put two connections into the posts?
nhjeff1 is offline
post #9 of 15 Old 02-17-2014, 08:54 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
Poor sketch? You mean...you weren't trying to show that the AVR and the sub should connect to a box covering the head of a penis?
eljaycanuck is offline
post #10 of 15 Old 02-17-2014, 09:01 AM
Quoted: 26 Post(s)
Liked: 37
So much for my artistic talents!
Two connections to the post will be fine
post #11 of 15 Old 02-17-2014, 09:28 AM
Quoted: 26 Post(s)
Liked: 37
post #12 of 15 Old 02-17-2014, 03:14 PM - Thread Starter
nhjeff1's Avatar
Thank you!! Watched episode 1 and 2 of star wars this a.m.
nhjeff1 is offline
post #13 of 15 Old 02-18-2014, 10:09 AM
Quoted: 26 Post(s)
Liked: 37
Glad it worked out for you
post #14 of 15 Old 02-18-2014, 10:40 AM - Thread Starter
nhjeff1's Avatar
Now I just have to play with settings on my rec. Seems like a little bit of delay with them. Maybe I am just not use to them.
nhjeff1 is offline
post #15 of 15 Old 06-28-2015, 12:09 PM
rmilyard's Avatar
Quoted: 129 Post(s)
I purchased this kit the other day.
http://www.parts-express.com/4-aura-...ndle--300-9006
Be here next weekend for me to install.
rmilyard is offline
