Energy ESW-8 Upgrade? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-17-2014, 10:12 AM - Thread Starter
Bowenac's Avatar
Looking to upgrade this sub. Or try to get better sound out of it. Certain movies or bass lines I can hear the sub like thunder kind of, not sure if it is port noise or if its the actual sub itself. Seems to be the sub, it is down firing and sitting on carpet.
As for settings:
Receiver Settings Denon 1911
speakers set to 80hz
sub set to 120hz
Sub Settings
180
150hz
half volume
I want to feel the bass not hear the sub haha. Here are a couple pics of the sub placement and the size of the room.
For those who can't see the images room is 19x23 with open door way to hallway and kitchen
Sub Placement
Size of the room
Where I sit...
Should this sub be enough to fill this room better. Sometimes it sounds good but others I have to be quick to grab the remote and turn it down because it sounds like crap as I can hear the sub itself...
Any recommendations?
Bowenac is offline
post #2 of 12 Old 02-17-2014, 10:22 AM
eljaycanuck's Avatar
Quoted: 1344 Post(s)
Liked: 1959
How big is your room* (l x w x h; sealed, or open to other spaces)?
(*I can't view your pics here at work, so if your room measurements are in them, I'm not able to see them.)
It sounds like you're driving your sub too hard in a room that's just too big for it.
If you were to replace your sub, what would your budget be?
eljaycanuck is offline
post #3 of 12 Old 02-17-2014, 10:59 AM - Thread Starter
Bowenac's Avatar
Room is 19x23 in the biggest part, its kind of L shaped. So viewing area is 15x19 open doorway to hallway and kitchen.
If I was to upgrade around $1-200 if that is possible.
Bowenac is offline
post #4 of 12 Old 02-17-2014, 11:04 AM
Liked: 1959
That's a pretty big space for any small sub. Given your budget, a couple of options are:
- the Dayton SUB-1200 from parts-express.com (~$150, shipped, but currently listed as out of stock); and
- the Lava LSP12, currently on sale for $170.
Either of those subs should have no trouble giving you clean output at louder volumes than your 60W (continuous) ESW-8. But they are still entry-level subs in a large room, so as long as you don't expect earth-shaking, chest-pounding performance, you'll be alright. smile.gif
post #5 of 12 Old 02-17-2014, 11:11 AM - Thread Starter
Bowenac's Avatar
How would the Dayton SUB-1000 be? $109.00 + $9.95 shipping
http://www.amazon.com/Dayton-Audio-SUB-1000-10-Inch-Subwoofer/dp/B0063NU3AA/ref=sr_1_2?ie=UTF8&qid=1392664056&sr=8-2&keywords=Dayton+Audio+SUB-1200
Or the PSW-10 $81.98 with prime
http://www.amazon.com/Polk-Audio-10-Inch-Monitor-Subwoofer/dp/B0002KVQBA/ref=pd_pgd_B0063NU3AA_B0002KVQBA?pf_rd_p=1674797682&pf_rd_s=cp-merchandising-top&pf_rd_t=201&pf_rd_i=B0063NU3AA&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1Y0BW433K9275TBPBJ2J
I thought about getting the Klipsch Sub-12HG but I think a 12 would be to much. And the sub itself is really huge I would need to move the EC out a lot. It is on sale for $199.
http://www.amazon.com/Klipsch-Sub-12HG-Synergy-300-Watt-Subwoofer/dp/B003VIWK0G/ref=sr_1_1?ie=UTF8&qid=1392664173&sr=8-1&keywords=klipsch+sub+12
I have $250 balance at amazon so something from amazon would be awesome.
Thanks for the help and recommendations.
Bowenac is offline
post #6 of 12 Old 02-17-2014, 11:24 AM
Liked: 1959
Or the PSW-10
A decent but modest sub, good for smaller rooms and lower volumes.
If you're looking to make a lateral move from your current sub, either of those will do just fine.
$199 is a good price for that sub, and it's a decent sub. It's biggest (only?) weakness seems to be that it gets a bit boomy if you're using too high a crossover (i.e., over 80Hz). And, no, a 12" sub would not be too much. cool.gif
If you're looking to move up from your current sub, get the Klipsch (if you're going to go through Amazon) or the LSP12 or SUB-1200 (if you can buy direct).
post #7 of 12 Old 02-17-2014, 11:29 AM
Jack D Ripper's Avatar
Liked: 272
I recommend that you save up for a real subwoofer instead of buying another cheap one.  You might be satisfied with another cheap one, but from what you say you want, it seems to me that you are virtually certain to be dissatisfied with anything in your price range and will be back for more advice, and still have too small of a budget for something good.  And it would mean that the money you spent on the one that dissatisfies you will have been wasted.  I recommend saving up until you have $500, and then get an SVS PB-1000.  If you might be able to get about $50 off for an "Outlet" deal, but there may not be one available when you want to order.
ragingmain likes this.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
post #8 of 12 Old 02-17-2014, 11:34 AM - Thread Starter
Bowenac's Avatar
I'm not sure where you got that... I'm not looking for anything crazy. And def don't want to spend that much. I am just looking for a sub that will fill the room a little more and hopefully not hear the sub itself. I don't see how the Klipsch Sub-12HG is considered a cheap one. I know I would not be dissatisfied with that sub besides the size of it as its huge. I am actually pretty happy with the Energy 8... I just want a little bit more out of it.
Bowenac is offline
post #9 of 12 Old 02-17-2014, 11:43 AM
Liked: 272
From this:
I want to feel the bass not hear the sub haha. ...
The bottom of the line SVS PB-1000 is a great deal for what it is.  It has a much flatter, deeper response than anything else you can get at or below its price point.  It is way above everything that costs less.  It is a bargain for what it is.
If you want to really feel deep bass, you need to spend more than your current budget.
post #10 of 12 Old 02-17-2014, 11:44 AM
Liked: 1959
... I am actually pretty happy with the Energy 8... I just want a little bit more out of it.
Then try the SUB-1200. It's a very well rated sub for it's size and price.
post #11 of 12 Old 02-17-2014, 04:49 PM - Thread Starter
Bowenac's Avatar
Assuming the Dayton Audio SUB-1000 would be better than the PSW10? I'm not sure I want to go with a 12 just because of the size of the enclosure...Unless I move it to the left side of the Entertainment Center. Or I guess I could slide the Entertainment Center to the left and put it on the right. It just seems like all of the 12's are huge. Then again the ESW8 is 12X12X12 lol.
Bowenac is offline
post #12 of 12 Old 02-18-2014, 08:28 AM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 3001
Well, you are budget challenged. If you had more to spend, there could be some 10" subs that might work well for you. As it is, it's easier for a 12" driver to fill your room than a smaller driver, and besides, people here on AVS are more familiar with the larger driver subs because that's the best deal below $200.
Consider the Lava LSP12 on sale for $170. Very good sub for the money.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Denon Avr 1911 Receiver
