Need help replacing my amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-17-2014, 05:35 PM - Thread Starter
iontrap's Avatar
I have a Dayton sub that just had the amp die. What amp can I get to replace the dead one?
http://www.parts-express.com/dayton-audio-10-100-watt-powered-subwoofer--300-632
iontrap is offline
post #2 of 7 Old 02-18-2014, 01:00 PM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
Just look at the PE site for a plate amp that is about the same size (exactly same size is better) and about the same power. A drop in replacement is very straightforward.
If you cannot get an exact size match, you might consider a new subwoofer because cutting-and-pasting to get a new plate amp to fit can be a very big hassle.
wwinkler is offline
post #3 of 7 Old 02-18-2014, 01:06 PM
eljaycanuck's Avatar
Quoted: 1234 Post(s)
Liked: 1807
If you cannot get an exact size match, you might consider a new subwoofer ...
+1. $120 (incl. shipping) will get you into a brand-new, well-rated Dayton SUB-1000.
eljaycanuck is online now
post #4 of 7 Old 02-18-2014, 01:08 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
I wouldn't waste my time it. Perhaps you could convert it to passive sub, won't cost you anything if you have a amp lying around.
fatbottom is offline
post #5 of 7 Old 02-19-2014, 03:05 AM - Thread Starter
iontrap's Avatar
I'm starting to lean this direction.
iontrap is offline
post #6 of 7 Old 02-19-2014, 03:07 AM - Thread Starter
iontrap's Avatar
Is a passive sub one that uses an external amp?
iontrap is offline
post #7 of 7 Old 02-19-2014, 03:18 AM
cegadede's Avatar
Quoted: 21 Post(s)
Yes.
Enviado de meu GT-I9505 usando Tapatalk
cegadede is offline
