Why would I suddenly be getting port chuffing with Klipsch rw12d? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 02-17-2014, 10:34 PM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
I know some people have complained about it with this sub, but I never had any issue whatsoever until recently. My usual test is the THX into to Art of Flight; I used to be able to crank it, but now it sounds terrible and I can only assume that what I'm hearing is "chuffing". I checked out the sub; the cone is not ripped or anything; I re-fixed the port tube; nothing else seems loose. But those low frequencies make a terrible airy vibration type sound when pushed, and it all started about two months ago (I've had this sub for over a year).
Any ideas?
curttard is offline
post #2 of 23 Old 02-18-2014, 03:01 AM
steve nn's Avatar
Liked: 433
Any ideas?
I would pull the driver and take a look if indeed is chuffing?? Some dampening possibly came loose or something?? Anyway it's a good place to start since you say your vent seems still tight. If you do take my advice, make sure the end of the vent is at-least 3-4" away from the wall or batting. You can also always pull the amp instead of the driver which would most likely be easier.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
On-going SW management class
Denon
PS3
steve nn is offline
post #3 of 23 Old 02-18-2014, 08:38 AM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
What does chuffing look like?
This sub has pretty much nothing in the way of dampening from what I remember. Just an empty box with a plastic port tube and the speaker cone.
curttard is offline
post #4 of 23 Old 02-18-2014, 08:44 AM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
My Paradigm Sub was making sort of the same sound. I rotated the speaker 180 deg. And the noise went away. I will assume the speaker was somehow rubbing. It's been a couple of months and it is still working fine.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #5 of 23 Old 02-18-2014, 09:38 AM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Interesting. Will try that for sure. I'm not giving up on this sub. Was very happy with it for a solid year until this suddenly started happening.
I should add that it seems to have started when I tried laying it on its side for the first time. At first I thought it was just some issue with the airflow from the port in that position, but it continued doing it even when I put it back upright, and has done it since. Weird that nothing seems loose or anything, though.
curttard is offline
post #6 of 23 Old 02-18-2014, 11:24 AM
steve nn's Avatar
Liked: 433
Like I said, makes sense to me but can't be sure unless you take a peak!
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #7 of 23 Old 02-18-2014, 04:48 PM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
How I discovered it was the speaker was when it was making the noise, I gently put pressure on the cone with my finger and the noise went away.
post #8 of 23 Old 02-18-2014, 07:42 PM
steve nn's Avatar
Liked: 433
That could be the OP's issue also. I should have mentioned pressing in the speaker gently with his finger-tips to see if he hears a scratching sound first. Could be a VC going out.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #9 of 23 Old 02-18-2014, 11:36 PM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Going to try all of these things this weekend. Really want to fix this. My backup sub doesn't have the issue -- but it's because it doesn't get down that low in the first place.
curttard is offline
post #10 of 23 Old 02-19-2014, 12:34 PM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
post #11 of 23 Old 02-19-2014, 01:40 PM
steve nn's Avatar
Liked: 433
Originally Posted by Skytrooper View Post
Oh yeah,.. "Skytrooper" I should of been more sensitive. wink.gif how bout CV then? No not the amp but coil voice ?
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #12 of 23 Old 02-19-2014, 04:47 PM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
Steve nn
Just joking. I knew what you meant. But one thing I don't like is on many forums, people use abbreviations. I sometimes have trouble understanding them. I'm probably a lot older than most people here.
post #13 of 23 Old 02-19-2014, 06:14 PM
steve nn's Avatar
Liked: 433
Steve nn
Lol.. yeah I was joking too. I know what you mean on the abbreviations though. We take different abbreviations for granted. I still read posts that I don't know what movie they're talking about? I mean it's not like we talk about that certain movie all the time. rolleyes.gif I would agree that using them when noticing they're not the best in communicating is a good practice though.
Klipsch RB-75
Klipsch C-7
Klipsch RB-35
Denon
PS3
steve nn is offline
post #14 of 23 Old 02-19-2014, 07:28 PM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
Steve nn
Maybe someone should start a thread about abbreviations. And remember not forget to remember the OP. ( I know what OP means now ). That Furutech thread really went crazy.
post #15 of 23 Old 02-22-2014, 04:59 PM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
How on earth do I get the driver out? I removed all the screws and it's not falling out when I tip it over. I am afraid to pry the sides because I don't want to rip any of the rubber.
edit: Got it out by knocking the port tube loose and then just reaching up in there and pushing it out -- HARD -- from the inside. If the port tube had been epoxied in, I'd probably have been out of luck.
So even with the speaker held in my hand, it still sounds horrendously "fluttery" and "flappy" on the low stuff. I don't see any signs of the cone or anything being ripped; the whole speaker still looks brand new to me. So with no physical damage to the speaker, why is it suddenly doing this on the exact same audio content that it used to have zero issues with?
curttard is offline
post #16 of 23 Old 02-23-2014, 01:34 AM
cchunter's Avatar
Quoted: 495 Post(s)
Liked: 772
My RW12D use to chuff only in depth mode. I tried punch and it never came back even at reference levels so I ran it in punch until I sold it lol
Denon 4520
Klipsch RF-7II's, RC-64II, RS-62II's
SVS SB13 Ultra
Oppo 203 Sony PS4
Panamax 5300PM
Sony 65XBR850D 4K
cchunter is offline
post #17 of 23 Old 02-23-2014, 09:03 AM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
I believe mine is in depth mode so will definitely try that. I just don't understand how the speaker itself is having this problem when it went over a year playing the same stuff at the same volume with no problem.
curttard is offline
post #18 of 23 Old 02-23-2014, 01:23 PM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Still have the same problem with Punch and Flat modes. Maybe slightly less just because it isn't hitting the low stuff as hard as in Depth mode, but still very audible.
Anyone want to buy a Klipsch RW12d that makes an awful flapping sound anytime the low end is hit?
curttard is offline
post #19 of 23 Old 08-19-2016, 09:21 AM
Quoted: 22 Post(s)
Liked: 0
I have a really bad port chuffing issue with my SW450. Volume knob is just before 12 o clock position and I have it set at -10db in the Denon S910W. I tried taking it out of the corner where it seats and same port noise at loud low frequencies. Opened it and nothing is loose. Tightened all the screws and nothing. Dynamic EQ is off and everything was calibrated with Audyssey. After calibrating I measure the speaker levels at 0db and all where at or close to 75dB while the sub is somewhere around 60dB. Still when playing some scenes in Star Wars The Force Awakens or 10 Cloverfield Lane I get this fart sound that's louder than the bass itself. It doesn't happen all the time but. Only with some deep bass.
Is this something Klipsch subs do? Any way to fix this without having to turn the volume all the way down? The area is around 15' by 35' with 8' ceilings. I know something larger is recommended but, I had a Pioneer SW8MK2 before and it didn't do this.
HELP!!!
Lando_pr is offline
post #20 of 23 Old 08-19-2016, 09:33 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
HELP!!!
Too big of room for that sub SW450...the Pioneer is probably tuned high enough it does not even try to play those really deep frequencies. Time to step up to a Internet Direct sub in the 500-1000.00 range.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #21 of 23 Old 08-19-2016, 04:54 PM
Quoted: 22 Post(s)
Liked: 0
At least it doesn't seem like the sub has gone bad. Especially after just about 5 movies in it from new. I have a new Sub 12 laying around. Might give it a try to see if it works better. Or maybe I should sell both and buy a better one? What size and power would I need?
Lando_pr is offline
post #22 of 23 Old 08-19-2016, 05:22 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
In a room that size imo you need to look at a PSA 15v or HSU VTF3.5. If that is too much then a SVS PB2000 or Rythmik LVx12 minimum!!
post #23 of 23 Old 08-23-2016, 03:03 PM
Quoted: 22 Post(s)
Liked: 0
Thanks for the help!
Lando_pr is offline
Klipsch Rw 12d 12 Subwoofer Each
