SVS SB-1000 vs Dayton T1003K Kit - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-18-2014, 04:06 PM - Thread Starter
abbeyology's Avatar
I'm in the market for a subwoofer for home theater and some music. Currently, I'm debating between the SVS SB-1000 vs Dayton T1003K Kit, but I'm open to other suggestions.$500 is my absolute maximum budget. This will complete my 5.1 system with Klipsch RF-3 fronts, RC-3 center, and SS-1 surrounds.
Even though I will be using this mostly for home theater, I'm leaning towards a compact sealed sub because my SO has made it clear that she would like it to be as small as possible. Also, I live in an apartment and don't want the neighbors to kill me, so I am concerned with clear bass over loud bass.
I've heard great things about the SB-1000, but I've also seen a lot of people say that kits are a much better value. I have no problem with assembling the sub, or even ordering parts separately, as long as I can buy a pre-cut cabinet. And, if I can spend less than $500, that's great too.
Any advice?
abbeyology is offline
post #2 of 5 Old 02-18-2014, 04:14 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
I'd go for the SVS. Bigger driver,. 5 year warranty prebuilt, cooler running digital amp, and not worried about getting perfect seal.
fatbottom is offline
post #3 of 5 Old 02-18-2014, 04:59 PM
tlee82's Avatar
I looked at DIY before purchasing PB12-NSD. I didn't mind putting the cabinet together, but rather the equalizer part. After reading the DIY, you can't just throw a driver and cabinet together.
tlee82 is offline
post #4 of 5 Old 02-18-2014, 11:53 PM - Thread Starter
abbeyology's Avatar
Yeah. I like the idea of a project, but it's probably better going for a sure thing since this will be my only sub. I'd rather experiment with DIY on cheaper projects. I was only checking because I've seen people claim that the DIY subs are waaaaayyyyyyy better for the price.
post #5 of 5 Old 02-19-2014, 03:30 AM
fatbottom's Avatar
Liked: 518
I'd only go down DIY
a) You have plans for a subwoofer that works perfectly, ie a specific driver, amplifier, with set box dimensions and cut outs- that way you don't need to research into science of subwoofer
b) You're good at woodwork and finishing.
trog69 likes this.
Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer
