best budget sub for room size - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 02-18-2014, 08:15 PM - Thread Starter
reverb it's Avatar
I have read a few sub reviews and being a newbie to the whole audiophile thing I am having difficulty determining the best budget sub for my room.  Perhaps budget and audiophile is a oxymoron.  It is a basement room 18x25x7 about 3,200 cu ft. and the flooring is carbonized stranded bamboo..  I will be using a Yamaha RX-V675 receiver if that matters.
I have found favorable reviews for the following Emptek ES10i, HSU STF-2 and BIC Accoustech, but am not able to figure out how to determine which may be the better choice for my room.
Any insight on choosing or recommendations would be appreciated.  Thank you
reverb it is offline
post #2 of 27 Old 02-18-2014, 08:20 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
The STF-2 would probably be the best option among those you listed.
That being said for that size room I would be looking at the PSA XV15, SVS PB-2000, or HSU VTF-3. Those options should handle that room size fairly well.
basshead81 is offline
post #3 of 27 Old 02-19-2014, 06:19 AM
flickhtguru's Avatar
Liked: 111
I agree with basshead........ Now if price is a huge factor and for most ppl it is, I would look at the SVS PB1000. That is the best sub @ $500 and under; its $499 shipped.
FWIW I have a room that is 20' X 15' X 8' so 2400 cubic feet, but with a 4' wide floor to ceiling opening to rest of house and I have 2 Outlaw Audio LFM-1 Plus subs and I love them and they do great in that room but I would never want less.
Shawn
flickhtguru is offline
post #4 of 27 Old 02-19-2014, 09:12 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
The new Reaction subs look like they could be very good for budget subs. From the $400 to $500 mark I would be a lot more interested in those sub than the usual BIC, SVS, or Hsu subs.
shadyJ is offline
post #5 of 27 Old 02-19-2014, 09:15 AM
Liked: 111
I agree with the Reaction Audio subs the only reason I didn't mention it was cuz of it being so new and not many reviews out their yet. But some ppl will just have to buy them and test them out like guinea pigs.
Shawn
post #6 of 27 Old 02-19-2014, 09:24 AM
shadyJ's Avatar
Liked: 1351
If the base response is halfway decent, they could have a killer sub there. It could possibly blow away the usual candidates at four and five hundred. I wouldn't put much stock in new reviews though, unless they have something known to directly compare the sub against. EVERYONE who gets one of these big subs for the first time praises them to the heavens. "Amazing quality, like a concert!", "super deep bass, it was like an earthquake in my living room!", and so on. None of that means anything. I want hard data.
shadyJ is offline
post #7 of 27 Old 02-19-2014, 10:22 AM - Thread Starter
reverb it's Avatar
I appreciate the response. A few more details in my consideration. Price is a large consideration so the $400 and under is preferred a couple bucks more if it makes a big difference can be considered.
Also I am looking for something that win perform well for both movies and music.
For the room if I am filling up the main 2/3 to 3/4 with good sound that works well. The TV is located in a side 3rd of the room with the opposite side open with a couple of zone 2 small speakers.
Not sure if any of this is a factor? ?
Thanks again for all responses and feedback
post #8 of 27 Old 02-19-2014, 10:30 AM
BeeMan458's Avatar
Liked: 813
What ever you choose, be prepared to place the sub directly to your side or directly behind your main seating position to get the most out of what ever sub you choose to buy.
Another suggestion would be to check out the budget minded thread. There's a boatload of excellent information, tests and recommendations to be found there.
Another thread that you'll find budget minded insight, "best home theater subwoofer on market for under $500."
Hope the above helps move you forward.
BeeMan458 is offline
post #9 of 27 Old 02-19-2014, 10:53 AM
Liked: 111
If $400 is the most you can go I would try the Reaction Audio BPS 212 and place it as close to the seating area as possible.
One thing to keep in mind a sub doesn't care what part of the room you use. It will try to fill the entire open area with bass, so that is why ppl with really large rooms or open concept homes have to buy big powerful expensive subs. 2 subs is always preferred over 1, 2 subs helps to even the frequency response across the entire listening area. You have a pretty big area so the only way you will get decent bass with 1 $400 sub is to place it nearfield (within 4ft of main listening position (MLP)). I would suggest either right beside or behind the couch and if that's out of the question put the sub in a corner.
Shawn
post #10 of 27 Old 02-19-2014, 07:55 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
I think a BPS12 would come up short in the deep bass due to lack of room gain. However there is not much in that price range that will have a ton of deep bass output <30hz. I see it being a spitting image of a Epik Legend.
post #11 of 27 Old 02-19-2014, 08:01 PM
shadyJ's Avatar
Liked: 1351
I don't think its like the Legend. The Legend and Empire used relatively low xmax but high sensitivity drivers. They could get really loud in mid and especially upper bass, but they couldn't dig deep very easily. The driver Reaction is using do not quite resemble that kind of driver, they look to be more in line with conventional subwoofer drivers. Of course, we can't know for sure until they get tested.
shadyJ is offline
post #12 of 27 Old 02-19-2014, 09:36 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
Exactly...which suprises me that you of all people would recomend a sub that has not been tested. Lol
post #13 of 27 Old 02-20-2014, 07:29 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Not many? Are their any user testimonials out yet? I haven't been able to find any.
The Reaction Audio subs certainly sound good on paper, reverb it. But realize you'll be taking one for the team in trying it out for everyone else smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #14 of 27 Old 02-20-2014, 07:34 AM
cel4145's Avatar
Liked: 3002
I agree. There's a reason why the BPS 212 is rated "24-200 Hz +/-3.5 dB" instead of the more standard +/-3db among ID sub vendors (or better, if you look at how HSU likes to rate stuff). Something there about the frequency response is being made to look better.
They just want someone else to buy it. LOL
cel4145 is offline
post #15 of 27 Old 02-20-2014, 08:12 AM
shadyJ's Avatar
Liked: 1351
I haven't wholly recommended it without any reservations. I have always put that caveat that it might not pan out as well as it looks on paper.
A .5 dB difference is hardly anything. Anyway, it should act like a typical sealed sub for the most part:
Originally Posted by edgebsl View Post
Our measurements state on the website 24-200 HZ +/- 3.5 db. The response is fairly flat to about 30 hz with a nice taper down to about the 20 hz area that works well with room gain.
We went with a pretty standard sealed sub response profile using a little eq to get deep response, but not excessively so.
I don't like posting response graphs until some of the third party measurements come in. The reason being, I have seen folks that have posted outdoor graphs, close mic'd graphs and even in room graphs of their own only to see 3rd party reviews come in with measurements that vary. And even if those graphs vary a small amount, even a few db there seems to end up being confusion over "which graph is the right one"?
Sure, I could post more graphs and even provide 1/8 space SPL predicted numbers on the site and I may sell more subs.
But I know that I will build a better reputation rating things conservatively. And that is what we are attempting to do.
shadyJ is offline
post #16 of 27 Old 02-20-2014, 08:13 AM
Liked: 111
I hear ya BUT there was a time when someone had to take one for the team and purchase the first subs from SVS, Hsu, and Rythmik. Someone has to be the first buyer. And I know the +/- 3.5 db thing is a little weird. But after Jim Wilson and Josh Ricci test and review these subs we will have a much better idea on how these subs hang with the BIG ID brands.
Shawn
post #17 of 27 Old 02-20-2014, 08:18 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
There is a reason why Reaction already improved the BPS12 with the turbo model. From what I see is the base BPS has fairly low xmax 12" drivers with only 200watts in a smallish sealed enclosure. I would not expect huge output from that sub. The turbo looks to be much better but I would think 300watts is still not enough power to dish out stellar low bass out of a sealed sub. If it had 20mm xmax one way drivers with 600watts on tap I could see it being a winner, but then the price goes up. No sub company is going to magically pop up and star pumping out at high performing subs at substantially lower prices then the rest of the ID companies.
Price
Performance
Quality
Pick 2!!
post #18 of 27 Old 02-20-2014, 08:19 AM
kesando's Avatar
Liked: 31
Another option from a pure output standpoint is the Premier Acoustics PA 150. Plenty of clean mid and upper bass output though output under 25-30hz falls off a bit
kesando is offline
post #19 of 27 Old 02-20-2014, 08:22 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
A bit is a understatement. The PA 150 drops 25db from 20-80hz.
post #20 of 27 Old 02-20-2014, 08:25 AM
cel4145's Avatar
Liked: 3002
I think that should be one of the sub enthusiasts that are strongly recommending the Reaction Audio subs to new site members without "telling" them they will be taking one for the team (lol).
Meanwhile, this has nothing to do with SVS, HSU, or Rythmik. There have been plenty of instances in home audio equipment where some new manufacturer's products didn't end up as good as expected, and even with new models in existing product lines. So there is always risk involved in a situation like this. Some people don't mind purchasing new, untested products from new manufacturers, and that's fine. It's just the right thing to do to make people aware and then let them make their own decision.
BTW: I have told a couple of people to "look into" the new Reaction Audio subs. But's that different from encouraging them to buy without letting them know that the subs are untested.
cel4145 is offline
post #21 of 27 Old 02-20-2014, 10:52 AM - Thread Starter
reverb it's Avatar
I truly appreciate the responses and discussion. After some further research and consideration I am considering choosing between the hsu stf and the svs pb1000. I have found my listening preference to be nice clean sound that has depth. It appears the hsu is around $350 and the svs @ $500. My question is the system $150 better? I prefer to not be a pioneer with the reaction.
Thanks all
post #22 of 27 Old 02-20-2014, 11:16 AM
Liked: 111
Price
Performance
Quality
Pick 2!!
I agree with what you are saying. All I am saying is it is nice to now have a cheaper ID sub option. Im guessing this sub will be cleaner sounding than the $300 subs like the PL-200 and such. I agree there is no way that BPS 212 is going to compete with a PSA XS30 but I don't think that's this subs point either.
Shawn
post #23 of 27 Old 02-20-2014, 11:23 AM
Liked: 111
Thanks all
That is a fair response. I would definitely say the $150 extra is well worth it. The PB1000 is a great sub and at normal prices it is the best sub for $500. It has a flat feq resp down to 19hz and is very accurate.
Shawn
post #24 of 27 Old 02-20-2014, 12:19 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
Good point I agree!!
post #25 of 27 Old 02-20-2014, 01:31 PM - Thread Starter
reverb it's Avatar
Is it ever possible to get a svs pb-1000 for less than $500?. That seems to be "the street" price or is pricing flat? Thanks
post #26 of 27 Old 02-20-2014, 02:15 PM
bear123's Avatar
Quoted: 1804 Post(s)
Liked: 2677
Keep an eye on outlet section, you might find for $449.
bear123 is offline
post #27 of 27 Old 02-20-2014, 02:41 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6513
There is a pair for sale in the audio gear section for 800.00 only a couple months old. Might want to contact him amd see if you can work a deal.
Hsu Research Stf 2 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb2000 , Hsu Vtf3 Mk4 , Xv15 , Yamaha Rx V675 7 2 Channel Network Av Receiver
