PC12-Plus for $600 or FV15 for $850? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-19-2014, 08:53 PM - Thread Starter
neveralone777's Avatar
Quoted: 46 Post(s)
I have two used subwoofers I am looking at. The PC12-Plus for $600 or the FV15 for $850. I am moving soon and don't have my room locked in yet. However most of the houses we have looked at have vaulted ceilings and open to the kitchen and dining area. I don't think I would call the rooms very large but would classify them as large. I am purchasing a pair of Ascend Acoustics sierra towers as soon as I move in. In about a year I would purchase a second of whatever sub I end up with.
Any thoughts on these? Even a suggestion for another used sub to keep an eye out for would be great. I have decided I want to buy what I can used and feel like I should maybe jump on one of these deals. I would love to find some used sierra towers but they don't come up often.
Thanks for any help.
neveralone777 is offline
post #2 of 6 Old 02-19-2014, 09:28 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
If the PC-12+ has a sledge amp I would go for that one. If the FV15 is the HP model then go this route.
basshead81 is offline
post #3 of 6 Old 02-19-2014, 09:47 PM - Thread Starter
Quoted: 46 Post(s)
These are both the weaker versions. The SVS has the 525 BASH amp and the Rythmik is not the HP model.
post #4 of 6 Old 02-19-2014, 09:54 PM
tvuong's Avatar
Quoted: 1789 Post(s)
Liked: 1083
^^ Just want to let you know since you are adding a second one in the future that Rythmik had discontinued the FV15 and only now have the HP version.
tvuong is online now
post #5 of 6 Old 02-19-2014, 09:58 PM - Thread Starter
Quoted: 46 Post(s)
I saw this also. I would try to find another rythmik or just blend with the HP version.
post #6 of 6 Old 02-20-2014, 06:19 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
You could blend with the HP...or I am sure Brian would sell you a amp/driver to upgrade it in the future if need be.
Fv15hp Subwoofer , Svs Pb12 Plus Black Oak 12 Inch 800 Watt Powered Subwoofer
