Completely lost when looking for new sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 46 Old 02-20-2014, 06:31 PM - Thread Starter
Opentoe's Avatar
Quoted: 89 Post(s)
My main speakers are PSB speakers. I have the T5 series. They sound great, but my current Klipsch sub has been really weak and I don't even know why I bought it in the first place. I want to accommodate what I have now with a Subwoofer that isn't too much, but not too little either. Unfortunately there are so many models and makes it is so confusing. I will be hooking the Subwoofer up to my Denon X4000 receiver which has around 125 watts output per channel. I only want to get one 12" Subwoofer. I don't really like a lot of low sounds, but do want my movies to sound better. Then comes the price. I've seen models going for $300 and then models going for $2000 and up. My price range is about $700-$1000. I figured I could get a decent 12" Subwoofer in that price range. Can someone point me in the right direction on which model(s) I should be looking to get? Of course some of my friends just say "Sunfire" but just because of their name and price tag doesn't mean I have to get one. I'm really looking for a decent, high quality sub that will work technically with my Denon receiver too. I wouldn't mind buying it online, but would like to get it local if I could so it doesn't have to flopped around in a truck when shipped to me. Gets flopped around anyway coming from the manufacturer enough. I really appreciate any feedback on this. Time to dump this Klipsch!
Opentoe is offline
post #2 of 46 Old 02-20-2014, 06:35 PM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
... I only want to get one 12" Subwoofer. I don't really like a lot of low sounds, but do want my movies to sound better. ... My price range is about $700-$1000. I figured I could get a decent 12" Subwoofer in that price range. Can someone point me in the right direction on which model(s) I should be looking to get?
1. How low are the "low sounds" you don't like? And if you don't like them, why get a subwoofer?
2. You can get a lot more than "a decent 12" Subwoofer" for $700-$1,000.
That said, get something like the HSU VTF-3 MK4 (currently on sale for $659 + $99 shipping) and run it in open-port mode for maximum output (and reduced extension).
blake18 likes this.
eljaycanuck is offline
post #3 of 46 Old 02-20-2014, 06:54 PM - Thread Starter
Opentoe's Avatar
Quoted: 89 Post(s)
I never heard of HSU but will check them out.
My ears are very sensitive. I have exceptional hearing, which I mean I can hear really good. I'm just able to hear things other people can't. It is a curse, trust me. I hear every little tick, static, knock, how ever you want to say whatever they are, I hear them. When I'm driving I have to use ear protectors. So I think not liking the "lows" is just because my ears are sensitive but once in a while I do want to turn on the media player and play some of my MP3's while I clean the house, etc and I'd need a good subwoofer to get the sound I want. I was told to get a PSB Subwoofer since all my other speakers are PSB. I forgot what the word is, but its called something where you'd want to keep all the sounds similar I think...but with a subwoofer I wouldn't think it would matter. I guess it is time to do some subwoofer research!
Opentoe is offline
post #4 of 46 Old 02-20-2014, 06:58 PM
Liked: 1962
The word might be "timbre-matching" but that usually refers to your front three speakers (most definitely) and your surrounds (recommended, but not as critical as the front three). You are correct that the sub does not need to be matched to the speakers.
Thank you for explaining what you mean about not liking lows. And I can see why you might want a sub with good sound but not necessarily tremendous output or extension.
HSU is a well-regarded brand. Some others are SVS (svsound.com), PSA (powersoundaudio.com), Rythmik (rythmikaudio.com). There are several more as well.
In your price range, and although it's quite a different type of sub from the VTF-3 MK4, the Rythmik F15 might be another good option for you. (It would be just over $1K, including shipping.)
Hopinater likes this.
post #5 of 46 Old 02-20-2014, 07:06 PM - Thread Starter
Opentoe's Avatar
Quoted: 89 Post(s)
Thanks for the suggestions. My friend told me to check out the Velodyne Impact 12" sub. I was expecting a huge price tag and it's only $499 MSRP. You think something like that is a little low on the quality scale I'm looking to get? That F15 looks like a monster! That may be a little too much/big for me. I'm not against paying for it, but of course want the best for my dollar.
I guess I shouldn't even take a ride to Best Buy. Do they even carry nice quality Subwoofers?
Thanks again.
Opentoe is offline
post #6 of 46 Old 02-20-2014, 07:31 PM
Liked: 1962
It's a modestly-powered sub. For the same money ($499, including shipping), you might want to consider the well-rated SVS SB-1000. (Here's a good review of the SB-1000 and its sibling, the PB-1000.) SVS offers free return shipping within 45 days, so if you don't like the sub, return it and the in-home demo costs you $0.
It sounds as though your needs are modest - nothing overly powerful, just some good, clean sound - so IMO you really don't need to spend a lot of money. The SB-1000 - or if you want to go a little higher up the chain, its bigger sibling, the SB-2000 ($699, shipped) - would likely suit your needs quite well. (Here's a review of the SB-2000.)
They do carry some decent subs, but you won't get the same value-for-dollar as you will with an Internet-direct (I.D.) sub.
post #7 of 46 Old 02-20-2014, 08:18 PM
Hopinater's Avatar
Quoted: 2290 Post(s)
Liked: 5700
I agree with everything Eljay has said. I think your money would be best spent looking at the sealed SVS subs that he mentions above (SB-1000 and SB-2000). I will also reinforce what the says  about the free shipping and free in home trial so really you don't even have to take a risk.
Subwoofers: dual PSA V3601's with a PSA XV15se nearfield
Speakers: PSA MTM-210T L/R - PSA MTM-210 Center- PSA 110sr Surrounds
Denon X4200 - Oppo UDP-203 - Panamax M4300 - Direct TV - Apple TV - Xbox360
Hopinater is offline
post #8 of 46 Old 02-20-2014, 08:57 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
basshead81 is offline
post #9 of 46 Old 02-20-2014, 10:36 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
I'd go for the VTF3. It lets you tune the sub's sound to your taste. You can taper down the lows by a slight amount from the Q control or more drastically by using open ported mode. You can also knock the lows down further by plugging a port and set the tuning control to two ports open, that is called overdamped mode. There are a lot of different ways of controlling the deep bass frequencies on the VTF3.
blake18 likes this.
shadyJ is offline
post #10 of 46 Old 02-21-2014, 08:22 AM
flickhtguru's Avatar
Liked: 111
Ok OP it sounds like your needs are modest, BUT no one asked what size your room is. So what is the total cubic footage of the room and any area open to the room where the sub is? Once we know that we can more accurately give you advice for a sub.
Shawn
flickhtguru is offline
post #11 of 46 Old 02-21-2014, 08:37 AM
wpbpete's Avatar
Quoted: 113 Post(s)
Liked: 99
+1 Totally agree, considering your hearing sensitivity, the versatility of the HSU may be huge factor. Where as most subs don't offer this kind of versatility, with the HSU you'll be able to almost infinitely customize it to your particular need.
wpbpete is offline
post #12 of 46 Old 02-21-2014, 09:08 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Could be, too, with any bass sensitivity that bad, thumpy bass from budget subs would bother you more than a good, tight sounding accurate sub. So I think you are on the right track.
In this regard, the various Internet direct subwoofer vendors mentioned in this thread will definitely exceed what you could buy locally from a retail store by a significant SQ improvement.
Originally Posted by basshead81 View Post
+1
This would be my suggestion, too. My belief is that the best sealed subs in this budget range can give you a little better SQ experience over the best ported subs, whereas the ported subs would give you more max output and perhaps deeper extension. So unless your room is unusually large, I'd go with these two suggestions or a Rythmik sealed sub, but you would have to spend more for one of theirs.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #13 of 46 Old 02-21-2014, 09:10 AM
bear123's Avatar
Quoted: 1804 Post(s)
Liked: 2679
My advice to you would be to purchase both an SVS PB-2000 and SB2000, demo them both in house for the 45 day trial period.  Keep the one you are happy with and send the other back.
bear123 is offline
post #14 of 46 Old 02-21-2014, 09:34 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
Or you can buy a sealed sub and not have to mess with all that stuff. wink.gif
post #15 of 46 Old 02-21-2014, 09:38 AM
cel4145's Avatar
Liked: 3002
And the OP can let Audyssey XT32 in the Denon X4000 smooth out the frequency response, and those other features should not be necessary. Well, unless one wants to get into buying calibration mics and learn REW to further refine the in-room response, assuming XT32 doesn't seem to manage it.
cel4145 is offline
post #16 of 46 Old 02-21-2014, 10:13 AM
shadyJ's Avatar
Liked: 1351
The point is it lets the user determine the performance, and it's nice to have it available whenever you want it. A sealed sub will get you one type of response which you are stuck with. A VTF3 lets you determine almost exactly how much deep bass output you want.
shadyJ is offline
post #17 of 46 Old 02-21-2014, 10:55 AM
cel4145's Avatar
Liked: 3002
That's not accurate. It allows you some flexibility. Personally, I think if those kinds of adjustments are important, better to choose between sealed and ported and get a Rythmik sub with it's fully functional PEQ amp feature.
cel4145 is offline
post #18 of 46 Old 02-21-2014, 11:12 AM
shadyJ's Avatar
Liked: 1351
You get a lot of freedom in determining the low end of the VTFs. Between the Q control, and two ports, one port, sealed, and overdamped, that is a lot of flexibility to set the deep bass output. You would need to step up to the FV15HP to find that kind of control on a Rythmik sub. Rythmik gives you a lot of choices to filter deep bass electronically, but physically altering the tuning point is a much more potent tool in allowing and subtracting headroom.
shadyJ is offline
post #19 of 46 Old 02-21-2014, 11:15 AM
cel4145's Avatar
Liked: 3002
You can think what you want, but I think the PEQ controls that come on all the Rythmik models, other than the LV12R (I don't think it has it), are a more robust solution because it's a PEQ--it lets you choose the center frequency. The VTF does not have a full PEQ control.
cel4145 is offline
post #20 of 46 Old 02-21-2014, 12:37 PM
shadyJ's Avatar
Liked: 1351
PEQs are nice but they do not change the actual headroom a sub has, except to limit it. They are really meant for taking out peaks, but since the OP has a AVR-X4000, that isn't going to be a concern. I agree that typically a PEQ is probably a bit more useful than a Q control, but not for the OP's purposes. Variable tuning is a much more powerful feature for controlling a sub's response than either.
shadyJ is offline
post #21 of 46 Old 02-21-2014, 02:06 PM
cel4145's Avatar
Liked: 3002
cel4145 is offline
post #22 of 46 Old 02-21-2014, 02:21 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
what about damping control? I think that would be much more useful then trying to changing a subs tune...extension is not going to effect the OP's hearing sensitivity, but imo being able to dampen the bass output to not sound as "thick" will.
post #23 of 46 Old 02-21-2014, 03:16 PM
shadyJ's Avatar
Liked: 1351
An adjustable Q is a Damping control.
shadyJ is offline
post #24 of 46 Old 02-21-2014, 03:47 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
So the hsu or rythmik could work well for the op.
post #25 of 46 Old 02-21-2014, 05:44 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
If I understand what the OP is saying about his sensitive hearing, all subs have his solution included. That would be the gain/volume control. I have a similar situation with my hearing and I don't believe he has an issue with low freqs themselves, but with the rattles they produce throughout the listening area. Some are impossible to isolate and others are impractical to eliminate. Turning down the volume would help with some, others are stimulated at various frequencies at moderate volume,s especially when those freqs are sustained more then a few cycles. If this is the case, he would have to deploy a complex solution by deemphasizing some bands and raising the low end. To do this may result in an awful sounding system. He needs to get a best-fit sub, spend time isolating noise makers and eliminating them, then learn to ignore the rest of them. My solution was to turn up the volume until it drowned out environmental noise (including my wife).
Randy
ransac is offline
post #26 of 46 Old 02-21-2014, 05:53 PM
cel4145's Avatar
Liked: 3002
I like to throw in a few bass heavy music tracks in Audacity, and then run the low pass filter to eliminate everything above ~120hz. Or use bass sweeps downloaded from the web. But then again, if I had a wife, I might want to leave the high frequencies in (lol).
cel4145 is offline
post #27 of 46 Old 02-21-2014, 06:47 PM
shadyJ's Avatar
Liked: 1351
An easier way of doing that is get Nevi's EQ for winamp.. You can just draw your desired response shape into the FR screen and get whatever filter you want instantly. It's a 250 band EQ and it is real handy, one of the best plug-ins for winamp.
shadyJ is offline
post #28 of 46 Old 02-21-2014, 06:56 PM
cel4145's Avatar
Liked: 3002
You are a winamp user? I didn't think there were many of those around anymore. I would have guessed you to be a Foobar or iTunes user.
cel4145 is offline
post #29 of 46 Old 02-21-2014, 07:07 PM
shadyJ's Avatar
Liked: 1351
I like Winamp, it's simple, it loads fast, and its very customizable. I like the milkdrop visualizer too. I also like that EQ plug in by Nevi, I'm not sure if something like that exists for foobar but I hear good things about foobar. iTunes is horrendous though, that is a nightmare I do not care to relive.
shadyJ is offline
post #30 of 46 Old 02-21-2014, 07:09 PM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
Denon Avr X4000 7 2 Channel Home Theater Receiver , Hsu Vtf3 Mk4 , Rythmik Audio F15 Subwoofer , Svs Sb2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer
