Sealed Subs or Ported Subs (Dual XS15 vs Dual XV15) For my Room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-23-2014, 02:56 PM - Thread Starter
The Deluxe's Avatar
Hello guys! Long time lurker here that finally got the guts to do his first post. I'll get the straight to the point, I'm split between either getting dual XS-15s or dual XV-15s for my room. Would sealed subs work better in a small room like mine (about 1200 cubic ft)? It says the XS-15 would go down 26hz but would it go lower in room like mine? I mainly watch movies so I like my bass to vibrate the seats but I don't want boomy sound. I had a BIC PL-200 so I feel like I was missing a lot of lower stuff (well at least from what I've read here). Any input would be appreciated smile.gif
The Deluxe is offline
post #2 of 10 Old 02-23-2014, 03:09 PM
Gov
Gov's Avatar
Quoted: 119 Post(s)
Liked: 184
Sealed would prolly work well for you. I would consider a single XS30 too
Welcome!
Main HT Room: Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV3, Sony BDP-S5100, Speakers: Ascend Acoustics Sierra Towers, Sierra Horizon and HTM-200SE, Dual Power Sound Audio XV15 Subwoofers
Basement HT Room: Panny TC-P58V10 (Black Level Restored!), Denon AVR-E300, Comcast X1 STB, Sony BDP-S590, Speakers: Ascend Acoustics CBM-170SE (L/R), Ascend Acoustics CMT-340SE-C, Wave Crest HVL-1 (Surr) and Dual Power Sound Audio XV15 Subwoofers
Gov is offline
post #3 of 10 Old 02-23-2014, 03:09 PM
newc33's Avatar
Quoted: 957 Post(s)
Liked: 1234
Is your room sealed?
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is offline
post #4 of 10 Old 02-23-2014, 03:12 PM
newc33's Avatar
Quoted: 957 Post(s)
Liked: 1234
If it is I would opt for dual xs15s personally that way u have more freedoms of movement for freq smoothing
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #5 of 10 Old 02-23-2014, 03:25 PM
Jack D Ripper's Avatar
Liked: 272
In general, with comparable subwoofers, with a properly-made vented one, you will get deeper, flatter bass, until it starts dropping off, and then it will drop off faster than a sealed subwoofer will.  You also tend to get higher output before the drop-off.  With these, from looking at the manufacturer's claims, I personally would go with the vented versions.
Kini62 likes this.
God willing, we will prevail in peace and freedom from fear and in true health through the purity and essence of our natural fluids. God bless you all.
Jack D Ripper is offline
post #6 of 10 Old 02-23-2014, 03:38 PM
Bill Fitzmaurice's Avatar
Liked: 5684
With a longest room dimension of about 20 feet sealed is OK, larger than that ported is better.
Bill Fitzmaurice is offline
post #7 of 10 Old 02-23-2014, 05:35 PM - Thread Starter
The Deluxe's Avatar
Thank you guys for the input and greeting smile.gif looks like I'm leaning more toward sealed now
post #8 of 10 Old 02-24-2014, 10:55 AM
KidHorn's Avatar
Quoted: 1491 Post(s)
Liked: 981
I would get the ported. In the future, you may want to use it in a larger room.
KidHorn is offline
post #9 of 10 Old 02-25-2014, 06:57 AM
basshead81's Avatar
Quoted: 238 Post(s)
Liked: 6518
You have to be careful when comparing the +/-3db Frequency Response of a sealed subwoofer. That rating simply tells you how low a sub will go while maintaining a flat response with out any boundry reinforcement. Place that sub in a small sealed room where 12db of room gain can lift the low end, then you have a sub that may reach +/-3db down to 12-14hz.
Ported subs generally follow thier base response because of the steep roll off below the tune. Room gain can still affect them but normally excessive room gain of a ported subwoofer will cause an big Peak in the response between 20-40hz. Also extension may increase slightly but normally never more then 5hz.
basshead81 is offline
post #10 of 10 Old 02-25-2014, 08:13 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3517
Exactly. The f3 of a Psa xs30 is 23hz (according to tom)
In my room I get extension down to 10hz +\- 2.5.
When I had a xv15 in my room which has 18hz as it's tune. I was getting extension down to only 15hz.
Ymmv
Brian Fineberg is offline
Xv15 , Xs30
