Possible problem with SVS PB12-NSD just delivered. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 54 Old 03-03-2014, 03:40 PM - Thread Starter
Acousticality's Avatar
Originally Posted by basshead81 View Post
All that will do is cause audyssey to pull the sub trim back even further and you will gain nothing. AVR correction softwsre shoots for a 75db calibration no matter where the sub amp gain is set. The correct way to get more bass is do what I posted in my previous post. smile.gif
Yea Im new to this, and even I think what the other guy said makes no sense.
Acousticality is offline
post #32 of 54 Old 03-03-2014, 04:10 PM
cel4145's Avatar
Quoted: 2659 Post(s)
Liked: 2991
Well, and when you are on an Internet forum asking for info about subwoofers, the guy with username "basshead" is usually a good one to trust smile.gif
Acousticality likes this.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #33 of 54 Old 03-03-2014, 07:18 PM - Thread Starter
So I'm thinking I still might have a problem, after watching numerous blu-rays last night and more TV today the sub just has NO POWER. It sounds like its inside a box with sound proof walls.
Here are my speaker settings, which i believe are the factory defaults?
post #34 of 54 Old 03-03-2014, 07:19 PM - Thread Starter
I also can't find where the "large/small speakers" selector is.
post #35 of 54 Old 03-03-2014, 07:25 PM - Thread Starter
Also for Speaker Impedance, it only allows me to select 4 ohm, or 6 ohm. Even though my speakers are 8 ohm speakers.
Why is this?
post #36 of 54 Old 03-03-2014, 07:26 PM
cel4145's Avatar
Liked: 2991
I know older Denons, so I'm no fluent of the dialect of your receiver, but I'm 99% positive it should not be on full band for your mains. Start by setting all your speakers to 80hz for crossovers, including the front mains. Right now your speakers are definitely doing too much work. Finally, on Denons, I know the LFE is supposed to be on 120hz, although that is not a big difference. That's for the .1 in 5.1 or 7.1.
I'm not sure what the Double Bass is, but you should look that up and let us know (unless someone else here knows what it means). I don't think you need that turned on.
cel4145 is offline
post #37 of 54 Old 03-03-2014, 07:26 PM
cel4145's Avatar
Liked: 2991
Why is this?
Maybe your speakers are 8 ohm rated, but dip down lower and the receiver has measured that???
cel4145 is offline
post #38 of 54 Old 03-03-2014, 07:27 PM - Thread Starter
No there isnt even an 8ohm selection. Only 6 and 4ohm.
post #39 of 54 Old 03-03-2014, 07:43 PM
cel4145's Avatar
Liked: 2991
See what your manual says. Maybe the 6 ohm setting is for 8 ohm and 6 ohm rated speakers.
cel4145 is offline
post #40 of 54 Old 03-03-2014, 07:59 PM
syphon's Avatar
That's your problem. Change the full band setting. Shuffle through and see if they can be set as small. Raise your other speaker settings to 80 hz and turn off double bass. Oh, and put the LPF to 120 hz.
syphon is offline
post #41 of 54 Old 03-03-2014, 08:47 PM - Thread Starter
I don't know what all these things are, I would like to understand what I am changing before I change it...What does changing the Hz of the speakers do? What does Double bass do? What is LPF?
post #42 of 54 Old 03-03-2014, 08:59 PM
cel4145's Avatar
Liked: 2991
The Dolby recommendation is to set the crossover at 80hz for speakers in an HT setup for integrating a sub. Below 80hz is the frequency at which the receiver will chose to send the audio to the sub.
Double bass is probably defined in your manual. Did you look it up?
The LFE channel is the .1 in 5.1 or 7.1. The standard recommendation for that is to set it to 120 hz.
cel4145 is offline
post #43 of 54 Old 03-03-2014, 09:02 PM
jcwhammie's Avatar
Quoted: 45 Post(s)
Liked: 47
Changing the hz is the crossover. Set the fronts to 40, 50, 60, etc until the low frequency sounds best. If you set it to 80 or 90 you should hear/feel more from your sub. Once you do this, the double bass will be disabled. Double bass is sending the low frequency to the fronts and sub.
Lpf=low pass filter. Since the .1 in 5.1 sends out lfe 120hz and down, you should try setting it at 120 so you aren't missing any low frequency.
TV: Panasonic 60GT50/ Receiver: Yamaha RX-A2020/ Bluray: PS3 Slim/ Fronts: Focal Chorus 726V/ Center: Focal Chorus cc700V
Surrounds: Focal Chorus 705V
Subs: (4) sealed SI HT 18" powered by Inuke NU6000dsp
jcwhammie is online now
post #44 of 54 Old 03-03-2014, 09:06 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5234
Double bass means the main speakers are playing full range + the subwoofer is on.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #45 of 54 Old 03-03-2014, 09:07 PM - Thread Starter
So why would I want to turn that off? It seems like that would be a good thing.
post #46 of 54 Old 03-03-2014, 09:16 PM - Thread Starter
This is what it says now:
post #47 of 54 Old 03-03-2014, 09:26 PM
cel4145's Avatar
Liked: 2991
cel4145 is offline
post #48 of 54 Old 03-03-2014, 09:33 PM
jcwhammie's Avatar
Quoted: 45 Post(s)
Liked: 47
Maybe or maybe not. If I were you I would have it off. That sub is very capable of taking everything below 80hz without issue. It would also likely make your rti8s sound cleaner since they wouldn't be distorting trying to play the low frequency. It will take some of the load off your avr too. I used to have my settings similar to yours before I started reading these forums. I now feel like I'm getting the most out of my equipment. YMMV
post #49 of 54 Old 03-03-2014, 09:42 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5234
Because full range signals will be sent to the main speakers...meaning some movies could be calling upon your main speakers to play frequencies they are not designed to play. Running them full range for music is one thing, trying to get you rti's to play sub-30hz content is another. Dolby recomends 80hz as Cel mentioned...I cross my RTI-A7's @ 40hz because they are capable of 114db down to that frequency so they have plenty of headroom. Also I am driving them with a seperate power amp so my AVR is only driving a CSIA6 center and FXI-A6 surrounds.
post #50 of 54 Old 03-04-2014, 02:41 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 519
I would use 80hz but not THX as that would apply re-eq to the center.
fatbottom is offline
post #51 of 54 Old 03-04-2014, 06:46 AM
cel4145's Avatar
Liked: 2991
I would go with what you have configured. You'll need to spend a good bit of time reading and learning. Quick answers in the forum like this aren't going to help you figure out how to fine tune your setup beyond that, and the settings you have now should be FAR better than what you had to begin with.
cel4145 is offline
post #52 of 54 Old 03-04-2014, 04:48 PM - Thread Starter
THX logo is default for 80Hz
post #53 of 54 Old 03-09-2014, 02:34 PM - Thread Starter
OMG. So I just pulled my receiver out and reconnected the LFE cable, and reconnected the LFE cable in the back of the subwoofer. I don't know what I did, but WOW! Shaking the apartment now.
post #54 of 54 Old 03-09-2014, 02:48 PM
cel4145's Avatar
Liked: 2991
That's awesome! Must have just been a bad connection. I should have thought to have suggested that first. It's happened to me in diagnosing audio equipment problems.
Probably getting about as good a bass as out of your headphones now, huh? smile.gif
cel4145 is offline
Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Onkyo Tx Sr805 7 1 Channel Home Theater Receiver Silver , Polk Audio Rti8 High Output Floorstanding Loudspeaker Single Black , Polk Audio Csi5 High Performance Center Channel Speaker , Polk Audio Monitor 40 Am4025 A 2 Way Bookshelf Speakers Pair Black , Polk Audio Fxi A6 Surround Speakers Pair Black , Polk Audio Psw505 12 Inch Powered Subwoofer Single Black
