STF-2 Vs. NX-BAS-500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-04-2014, 11:09 PM - Thread Starter
paulks's Avatar
Here is CEA-2010 measurement of STF-2 (from Hsu website) and NX-BAS-500 (from Sound and Vision review)
         STF-2        NX-BAS-500
Hz     Max SPL    Max SPL
20     94.2           96.2
25     107.1         105.5
31.5  112.7          114
40     114            116.1
50     116.9          116.8
63      118.6         116.5
U-low Ave 20-31.5
STF-2 104.7db NX-BAS-500 108db
Low Ave 40-63
STF-2 116.5db NX-BAS-500 116.5db
Based on measurement above, do you think that they are similar performance-wise?
paulks is offline
post #2 of 7 Old 03-05-2014, 09:34 AM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Did you check to see if the measurements are taken at the same distance? If not, the SPL figures would have to be adjusted.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 7 Old 03-05-2014, 09:56 AM - Thread Starter
paulks's Avatar
Hsu website says 1m ground plane measurement. Brent in S&V says he peformed CEA-2010A output measurement at 3m and added +9.5db to scale the measurement to 1m reporting standard mandated by CEA-2010.
paulks is offline
post #4 of 7 Old 05-08-2014, 11:44 AM
goldark's Avatar
Quoted: 210 Post(s)
Liked: 41
I, too, am wondering what is the better regarded sub.
goldark is offline
post #5 of 7 Old 05-08-2014, 11:59 AM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2513
Once you drop below $500, I don't think you will find a better quality sub than Hsu's lower offerings.  They would be my pick if I had to limit my budget to under $500.
bear123 is offline
post #6 of 7 Old 05-09-2014, 06:35 PM
Quoted: 73 Post(s)
Liked: 112
I feel the same way; I've tried some other sub $500 subs, and HSU makes a better sub IMO. If the OP can push his budget to $499, the SVS PB-1000 is definitely an upgrade.
rnatalli is offline
post #7 of 7 Old 05-11-2014, 05:53 PM
gonzo64's Avatar
does the svs subs ever go on sale........
gonzo64 is offline
Hsu Research Stf 2 , Nixeus Nx 500 Fusion Xs Network Media Player
