Velodyne DS-10 false marketing and horrible cutomer service. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 47 Old 03-10-2014, 10:30 PM - Thread Starter
hk2000's Avatar
I'm posting this just to make sure everyone is aware of it. I purchased Velodyne DS-10 subwoofer about a year ago and I'm yet to have it setup correctly. Velodyne clearly claims in the manual and literature that the subwoofer includes 3 optimization options.
The following is straight from Velodyne product page:
You can modify the bass optimization further using the Auto-EQ function with your TV, remote control and microphone. The DS-10 manual helps you in this process. A microphone and mini XLR mic cable are included.
In reality, there is no way to setup "Auto EQ" because there is no CD. I spent hours on the phone with their customer support with no resolution, The guy finally tried to walk me through a simple "Self EQ" which I already knew about and which doesn't really do any thing other than a basic calibration with no consideration for integrating the sub with the rest of the system. The manual mentions a CD for this process, but Velodyne turned around and claimed that "no, this was never the case" and that it does not come with a CD. Any one who knows anything about audio would realize immediately that there is no way to run the Auto EQ without test tones playing through the system. I tried using my own test tones, sweeps, white noise, pink noise and several other methods using a tone generator but every time the Auto EQ fails and reverts back to Manual. Manual setup maybe more complete and even better, but is too complex for me and I'm not sure I can do it correctly.
In my Opinion, Velodyne is deceiving consumers and is doing themselves a huge disservice.
hk2000 is offline
post #2 of 47 Old 03-10-2014, 10:44 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #3 of 47 Old 03-11-2014, 08:56 AM
jchong's Avatar
Liked: 32
hk2000 are you sure you need a CD?
I thought you'd just need to plug in the mic and hit the EQ button on the remote.
eljr likes this.
jchong is offline
post #4 of 47 Old 03-11-2014, 09:58 AM
Quoted: 360 Post(s)
Liked: 437
That's what I'd assume. Similar to my SMS1 EQ's. They have their own built in test tone. Plug in the mic and go.
It doesn't seem like the OP is interested in help though; just blasting Velodyne.
post #5 of 47 Old 03-11-2014, 01:52 PM
warpdrive's Avatar
Liked: 48
The DS10 has audio output which provides the test tones. I'm not sure why the OPis going on about regarding a CD.
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #6 of 47 Old 03-11-2014, 02:58 PM
cvinfig's Avatar
Quoted: 134 Post(s)
Liked: 84
I'm a nerd and had to look it up. From page 38 (page 41 of the PDF file) of the DS-10 manual:
Running Auto-EQ Optimization – Stepping Up in Power
The next level up in the Digital Servo EQ optimization methods is Auto-EQ optimization. To perform Auto-EQ optimization:
1) Set up the microphone as in the Self-EQ instructions above.
2) Connect your subwoofer to your TV video input as described above in the make Video Connection between TV and Subwoofer section.
3) Make sure the subwoofer and your audio system are both on.
4) Place the Digital Servo Sweep Tone CD into your disc player and press play.
5) Once the sweep tone starts to play, adjust the receiver or processor output level to about the level of a normal-loudness conversation at the mic.
cvinfig is online now
post #7 of 47 Old 03-11-2014, 03:16 PM
Quoted: 360 Post(s)
Liked: 437
OK, that's cleared up. I'm still curious why he waited till a year later to whine about it.
post #8 of 47 Old 03-11-2014, 07:05 PM - Thread Starter
hk2000's Avatar
Not complaining just stating something that I thought I would find on a "Velodyne Owners Thread" but didn't.
That would initiate the Self EQ which is the first of 3 optimization methods listed.
I don't think there is help- Velodyne's own "tech support" couldn't help and ended up suggesting I use the Self EQ or the Manual EQ ( which I ended up doing). I'm not blasting Velodyne, I've always regarded their subs to be the best, but that does not make them infallible. I posted an issue on one of their sub-woofers that is currently available for sale on their site, Anyone considering it deserves to know this.
Actually, I contacted Velodyne when I got it, wondering why I can't find the CD in the box. After many calls and a lot of back and forth with several people in their customer service, they realized that the Manual was wrong and that this sub does not come with a CD and that hey would fix it on the product page to let buyers know that it does not come with a CD. So now there is a disclaimer on the page stating that, but the fact remains that Auto EQ will not work as described in the Manual ( it relies on a non existent CD). At the time I just went with the Self EQ, but it never sounded right to me, just because I did not post it here does not make the issue less significant.
That is interesting, I didn't think of that, but you'd think Velodyne's Support would suggest it. Thanks for pointing out though, I'll try it this week-end.
hk2000 is offline
post #9 of 47 Old 03-14-2014, 09:10 AM
eljr's Avatar
Quoted: 1050 Post(s)
Liked: 8025
I think it fair to vent.
eljr is offline
post #10 of 47 Old 03-14-2014, 10:28 AM
Quoted: 360 Post(s)
Liked: 437
Um, a year later? It's generally easier to come on here, state your concern, and ask for advice. He wasn't interested in finding a solution, just ragging on a company.
I bet if it would have been stated differently and in a more positive way; the answer would have presented itself quickly, and with no drama. wink.gif
post #11 of 47 Old 03-14-2014, 11:43 PM - Thread Starter
hk2000's Avatar
And if it didn't occur to me to ask for help on AVS forum at the time, that makes it an illegitimate issue? I don't get it, what's your issue? If you have a solution, great, otherwise, ignore my post. I'm not really expecting a resolution here. Again I just wanted to make the issue known for anyone considering the purchase of this sub. If you have a vested interest in Velodyne (employee, dealer...etc) then you should state the fact and come from that angle, otherwise you just sound like a fan-boy.
hk2000 is offline
post #12 of 47 Old 03-15-2014, 05:36 AM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Use the EQ output to feed the L & R receiver inputs. Seems like the EQ output in the DS-10 contains the test sweeps. Read item G.
No need for a sweep CD if that is the case!
J_Palmer_Cass is offline
post #13 of 47 Old 03-15-2014, 06:42 AM
eljr's Avatar
Liked: 8025
ABSOLUTELY
Did you ever try to get a call back from Velodyne? I am going on 4 months myself.
and you would be very wrong as customer service does not know their products except superficially.
If fact, your post is provoking as heck.
eljr is offline
post #14 of 47 Old 03-15-2014, 06:58 AM
Quoted: 393 Post(s)
Liked: 118
The cut sheet for the DS-10 says that a video EQ and an audio EQ cable are supplied with the unit. Did anyone think about why the cables came with the DS-10?
Funny that the owners manual never told you what to do with the audio EQ cable and referred you to the sweep CD instead of the EQ sweep output connections.
post #15 of 47 Old 03-15-2014, 07:03 AM
eljr's Avatar
Liked: 8025
Mine simply does not work although it did when I first set teh EQ. I moved it to a second sytem and reran it with Velodyne on the phone as I had other issues as well) and it did not work at all (EQ).
It seems to make some of the test sounds but does not hear them yet the microphone works as it picks up my voice just fine.
eljr is offline
post #16 of 47 Old 03-15-2014, 07:07 AM
Quoted: 393 Post(s)
Liked: 118
So you ran the receiver's LFE / R & L audio output cable(s) into the DS-10 LFE / R & L inputs as well as the DS-10 audio EQ and video EQ cables into your receiver, and the auto EQ does not work?
If that is the case, then your unit must be defective.
post #17 of 47 Old 03-15-2014, 07:15 AM
eljr's Avatar
Liked: 8025
Yeah, plus you have to tun it on, turn it off and turn it back on to get it to play. Although sometimes it starts after turning it on just once.
It does not go into standby mode. Other inconsistencies as well.
Strange really.
eljr is offline
post #18 of 47 Old 03-15-2014, 07:20 AM
Quoted: 393 Post(s)
Liked: 118
Strange really.
Do they have a warranty service center near you?
If not I would try to get Velodyne to send you a new DS-10 "amplifier" covered under the 2 year warranty. I would not send the entire subwoofer back for service due to shipping damage that could occur.
post #19 of 47 Old 03-15-2014, 07:23 AM
eljr's Avatar
Liked: 8025
Above
This is what it produces when running the self EQ.
Below, this is what it ran the the first time I self EQ for another system, worked fine, the only issue back then was that it did not go into standby and it needed two tries to start.
eljr is offline
post #20 of 47 Old 03-15-2014, 07:26 AM
Quoted: 393 Post(s)
Liked: 118
How about auto EQ? The EQ output does not work for self EQ from what I gather, although I may be wrong.
What happens when you hit the NEXT button on the screen?
post #21 of 47 Old 03-15-2014, 07:28 AM
eljr's Avatar
Liked: 8025
I have a real problem with taking on the liability of taking out the amp (which I have no clue how to do nor care to learn or invest the time) and exchanging it for another as this has been a problem from day one.
I bought new, I want new.
eljr is offline
post #22 of 47 Old 03-15-2014, 07:32 AM
Quoted: 393 Post(s)
Liked: 118
You own the subwoofer, so the liabilities are all owned by you. Follow up with Velodyne as a warranty repair.
If the subwoofer gets damaged during shipping, it is all on your dime.. Hope that you saved the original shipping package!
You don't want to deal with something like this:
http://www.avsforum.com/t/1515215/im-still-fixing-sunfire-subs-etc#post_24482902
post #23 of 47 Old 03-15-2014, 07:36 AM
eljr's Avatar
Liked: 8025
Don't recall. As I said, I had Velodyne on the phone the entire time so they caused or missed the problem.
Seems to me all that needs to be done is for them to make a phone appointment with me (which they keep this time) and run through any tests or resets with me acting as their robot hands. If they tehn are not able to fix the sub it should be exchanged for a new one with an apology and some sort of gift certificate for futue purchase.
Really simple stuff.
Instead I am here bitching with no resolution. Is it a strategy by Velodyne to say I have had it too long to make good? That is what I have been thinking for a while now.
eljr is offline
post #24 of 47 Old 03-15-2014, 08:21 AM
Quoted: 393 Post(s)
Liked: 118
The customer service rep can not see what is on your TV screen. Being a "robot" will not help you. It is no wonder why a lot of companies charge you for "personal service" after 60 days.
If you don't recall what happens when you hit the next icon, then you do not know what you are doing. You should print out the manual and follow the directions. It is up to you to spend the time and learn the setup procedure.
Your first picture shows the beginning of the setup procedure, except it says the EQ mode is manual. Did you perform a manual EQ? You said self EQ, and that is the wrong screen for self EQ (and auto EQ for that matter).
The mike seems to be working because the Mic? does not show on your screen.
post #25 of 47 Old 03-15-2014, 08:54 AM
Quoted: 360 Post(s)
Liked: 437
You caught me. I'm a Velodyne employee who has come on here to defend the company against the monumental losses we're going to take this year on our subwoofer products because you posted about our poor CS. rolleyes.gif
Most of the time, people with next to no posts who come on here and bash a product or company without any concern for an initial resolution are trolls. Just sayin.
post #26 of 47 Old 03-15-2014, 09:13 AM
eljr's Avatar
Liked: 8025
Skype makes it very easy to see but that is not the point. Let them just exchange it then. You get a new unit, it does not work properly you exchange it immediately.
Obviously I printed out the 65 pages of generic (somethings apply some don't) the owners manual and followed it. That is why it worked fine when I set the EQ the first time. Following the same steps with Velodyne on the phone it did not work the second time. I don't recall what it said after "next" because I last did this a month ago. Do you recall each step of a program you have looked at a month ago?
Velodyne was privy to the same pic, they saw it as a rousing success.
and I should not need to know what I am doing. I have no desire to learn the workings of a subwoofer. I want to listen to music. A quick set up guide should be all I need. (of course their is none)
I got a brand new OPPO at the same time, it was more complicated than this but it was no problem at all.
I also got a brand new sub from another company, same thing, a few minutes with CS and a look at the manual it I never thought twice about it.
How about the power button needing two tries? Normal stuff?
What about no standby mode?
What if the entire thing works great but the customer service people just don't know the product intimately enough to run through a simple test set up? Bring it back to factory setting and start a new. (we did at my request)
You can say whatever you want but I expect an on button to work, a quick start manual included, an owners manual that is either product specific or explains what part of the manual applies to each model it covers, a customer service department that gets back to you, takes ownership of problems and knows the products intimately, a remote function that always responds to the commands and not to have to take apart and send back pieces of a brand new purchase. It's not a damned DYI.
eljr is offline
post #27 of 47 Old 03-15-2014, 09:20 AM
eljr's Avatar
Liked: 8025
BS
Most times people with next to no posts post because they have had no success with an issue from a manufacturer and are at a loss for what to do next.
In fact, they generally don't want to be posting but find themselves compelled to because of a poorly run company or poor product.
eljr is offline
post #28 of 47 Old 03-15-2014, 09:24 AM
Quoted: 360 Post(s)
Liked: 437
BS
If you truly believe this I have some swampland in FL to sell you. cool.gif If he started his phone call to Velodyne the same way he started this post, I can see why he got little help. wink.gif
Maybe you two can get together and start a Velodyne anonymous group. tongue.gif
I do hope he gets it figured out and can enjoy the sub the way it was intended. smile.gif
post #29 of 47 Old 03-15-2014, 09:38 AM
Quoted: 393 Post(s)
Liked: 118
Yes, I can remember how to use all of my equipment / programs years after I set things up. By the way, how long have you owned that discontinued subwoofer?
You should request an RMA for repair of the subwoofer. Below are the terms of your warranty. You have to pay for shipping and insurance and you are also 100% liable for shipping damage. Like I said, I would swap out the amplifier under warranty if Velodyne permits that.
http://velodyne.com/warranty-subwoofers
post #30 of 47 Old 03-15-2014, 09:46 AM
Quoted: 393 Post(s)
Liked: 118
BS
The OP has a point. The owners manual is defective and is a bit misleading, and customer service is not familiar with this particular product.
Velodyne
