Damn Tax Man! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 99 Old 03-20-2014, 06:16 PM
Farley1's Avatar
Liked: 165
Originally Posted by Cinemafreak1 View Post
Well I bought a SVS PB2000 Outlet Special for 749, so tax covered.  No issues with it such as scratches or dents.  Since its a return/upgrade it was in stock and will ship tomorrow.  Giddy already.  Will get it hooked up asap once I get it.
Question, do i need to break it in....keep volume down for now and crank it later?
Also, where should I buy a cable, MonoPrice?
Thanks to all for the previous posts!
Michael
P.S.  Now I want to upgrade my Paradigm Mini Monitor v6s and center.  Slippery Slope this hobby.
You do not need to wait for it to break in.
Monoprice is fine for a cable.
Samsung KS8000 65", Sony UBP-x800
Denon AVR-X1000
SVS PB-2000
Front-Center-Surround, Pioneer: FS52-C22-FS51
Farley1 is offline
post #92 of 99 Old 03-20-2014, 06:27 PM
discone's Avatar
Quoted: 207 Post(s)
Liked: 209
Michael
If it is a return it may have already been broke in. Just get it dialed in and enjoy, but don't forget to let us know how you like it. Most of us who own that sub find setting the gain at 2:00 gives better sound. YMMV,
Monoprice has great prices on cables. Make sure you get one that is shielded to help avoid any electrical interference.
Living Room
Panasonic: TC-P65ZT60, Sony: PS3, Marantz: SR5008, Center: PC2000, Front & Surround's: PM1000, Sub: SVS PC13-Ultra, Harmony Smart Remote
Bedroom
Panasonic: TC-P46S1, Panasonic: HTIB SA-BT200
discone is offline
post #93 of 99 Old 03-25-2014, 06:28 PM - Thread Starter
Cinemafreak1's Avatar
Got sub and ran audyssey:
Speaker config: front large, center small, woofer yes
Channel level: fl +1, fr+1, c-8.5, sw-4.0
Crossover: c @ 40 and blank for front.
Weird right?
Did manual st up and switched front to small. My other manual settings are:
Sub woofer mode: LFE
Cross over front: 90
Crossover center:90
LFE:90
Is the more like it?
Cinemafreak1 is offline
post #94 of 99 Old 03-26-2014, 03:08 AM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 714
If you speaker settings have plus numbers they should not be set to Large.
derrickdj1 is offline
post #95 of 99 Old 03-26-2014, 06:08 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 274
it would be the unusual system and room where a system with a good sub should not engage bass management (set speakers to "small") but the sensitivity of the mains is not very likely to be the deciding factor, as far as I can see. Either a speaker can play at the desired level with the existing amp without audible distortion or not. Since AFAIK nobody knows exactly how the gain structure of any particular receiver is structured (ie at what SPL, for a given calibration, you risk audible amp distortion) knowing the calibration number for a particular speaker tells us nothing specific. Doubly true, of course if we don't know the desired playback levels of the individual in question. Since I never exceed -10 dB from reference, for example, I would remain as clean at +10 calibrations as somebody who listens at reference would with calibrations at zero,.
JHAz is offline
post #96 of 99 Old 03-26-2014, 07:54 AM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 714
The point on not running the speakers as Large is related to the fact that most tower speaker can't really produce the low bass as good as a capable subwoofer. Also, running the speakers as Large may cause some cancellation as far as bass in the room. This actually can lead to less bass. Also, running LFE+main is not recommended. My towers are 250/1000 watts RMS/peak and my subs are more capable of producing the low bass. My towers have two 10 in. woofer and a sensitivity over 100. Auddyssey also recommend that speaker should be set to small to enable full bass management.
post #97 of 99 Old 03-26-2014, 12:28 PM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 274
that's pretty much what I said, and not what the post I quoted said - trim levels (which are ultimately abut speaker sensitivity+room size+listening distance) don't actually figure into the question directly.
JHAz is offline
post #98 of 99 Old 03-26-2014, 05:14 PM - Thread Starter
OK, so set Volume dial on Sub to 2 o'clock and all others to the SVS manual guidelines.  Speakers including center are small and change LFE to 120 and Speakers to 80 was set to 90.  Sounds better for sure.  Was thinking of getting SPL Meter as I am not sure the Speaker and Sub levels are what they should be.  Center is -8.5 and sub is -4.0 while speakers are +1.  SPL Meter worth it or not?  just leave the settings?  I guess the Paradigm cc390 is pretty big cmpared to the mini monitor left and right speakers.  Almost feel like the cc390 and PB 2000 sub might be too much for the mini monitors.  Or am I just looking for an excuse to upgrade?
post #99 of 99 Old 03-26-2014, 05:31 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Your center probably has a higher sensitivity than your other speakers which is why its at -8.5db. No problem having a negative trim as long as its not -12.
A RadioShack SPL Meter is nice to have, it can also be used for measuring your sub's frequency response.
Mrkazador is offline
Svs Pb2000 , Xv15 , Hsu Vtf3 Mk4 , Outlaw Audio Lfm 1 Ex
