Buying a New Subwoofer - Need Suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 03-19-2014, 05:58 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
Hey guys. I figured I'd post this thread as it caters better to this particular topic.
I am trying to determine which subwoofer to purchase. My max budget is under $1,000. The room that this will be utilized in is 20x13. It is an open floor plan into the breakfast area and kitchen.
Here are the subs I'm considering that are within my price range:
Power Sound Audio
~ XV15: $799
SVS
~ PB-1000: $499
~ PB-2000: $799
~ Dual PB-1000: $949
Let me know what you guys think of any of these options or if you'd have any other suggestions!
Thanks!!
KHarmo88 is offline
post #2 of 28 Old 03-19-2014, 06:00 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
If it is for home theater, or a combination of home theater and music, i would suggest:
PSA XV15
SVS PB2000
HSU VTF3.4
These would be your best bang for your buck under $800.
Music only I would add several sealed options to that.
bear123 is offline
post #3 of 28 Old 03-19-2014, 06:05 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
PSA XV15
SVS PB2000
HSU VTF3.4
Thanks for you response bear. The primary use will be for home theater. It will be used for music as well. It's probably 90% home theater and 10% music.
EDIT: what are the main specs I need to focus on when comparing units?
KHarmo88 is offline
post #4 of 28 Old 03-19-2014, 07:53 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
Okay updated my options. Still open to suggestions.
KHarmo88 is offline
post #5 of 28 Old 03-19-2014, 08:54 PM
STL D's Avatar
Quoted: 264 Post(s)
Liked: 254
I would take the def tech subs off your list. You will be happy with the svs, PSA, or hsu.
STL D is online now
post #6 of 28 Old 03-19-2014, 09:05 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
So do you guys think I should take klipsch off as well?
Also, for the size of the room and the openness, would it make more sense to go single or double subs?
KHarmo88 is offline
post #7 of 28 Old 03-19-2014, 09:50 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Scratch the deftech and klipsch...
emerson1 likes this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #8 of 28 Old 03-19-2014, 09:51 PM
JFred's Avatar
Go with the best you can afford now. I think the PB-2000 is the way to go.
Forget about the Klipsch subwoofers, there is no comparison here.
Fred
o Emotiva XPA-2 Gen2
o Denon AVR-3313CI
o Oppo BDP-105
o Klipsch RF-7
o Klipsch RC-62II
o Klipsch RB-61
o SVS PB-1000
o SVS PB-2000
o Samsung 40" LCD
o Fat, big, old PS3
o 13 Inch MacBook Air w/ Audirvana
My blu-ray collection My weather website
JFred is offline
post #9 of 28 Old 03-19-2014, 09:59 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
Okay. Def tech and klipsch have been removed.
Now it's down to the PSA XV15, the PB-2000, or the dual PB-1000.
Just out of curiosity, if I can get my wife to cave and give me a $1,500 budget, what are my options?
KHarmo88 is offline
post #10 of 28 Old 03-19-2014, 10:03 PM
bear123's Avatar
Liked: 2511
Duals of either the PB2000, XV15, or VTF3.4 would be drastic upgrades from dual PB1000
bear123 is offline
post #11 of 28 Old 03-19-2014, 10:09 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
If I can't go over $1,000, would it be better to do the single PB2000 or the dual PB1000?
KHarmo88 is offline
post #12 of 28 Old 03-19-2014, 10:13 PM
bear123's Avatar
Liked: 2511
Thats a tough call.  Either way you go on that route, you will upgrade to dual PB2000's within a year with their upgrade policy anyway.
bear123 is offline
post #13 of 28 Old 03-19-2014, 10:26 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
I missed that. Where can I read into that?
Also, I hope this isn't a stupid question, as I said before, I'm still learning this stuff. Can the SVS subs be hooked up wireless or do I need to run wire to them?
KHarmo88 is offline
post #14 of 28 Old 03-19-2014, 10:29 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
All subs can be hooked up wireless.
post #15 of 28 Old 03-19-2014, 10:35 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
Easy enough haha. I saw the wireless accessory on there website.
KHarmo88 is offline
post #16 of 28 Old 03-19-2014, 10:50 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Look at the outlaw audio or rocket fish wireless adapters.
post #17 of 28 Old 03-20-2014, 08:53 AM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
Okay so I'm leaning toward SVS. However, I have another comparison request:
Single PB12-Plus $1,399
Vs
Dual PB-2000 $1,499
KHarmo88 is offline
post #18 of 28 Old 03-20-2014, 09:09 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Dual PB-2000 will have better performance, but you do not get the variable tuning and extra amp features that the Plus has. It all comes down on what is more important to you. Dual subs will help smooth room modes which can require less eq from your avr room correction software to achieve a flat response...and that will equal more headroom. If you never see getting another Plus down the road then go dual PB.
post #19 of 28 Old 03-20-2014, 09:16 AM
Farley1's Avatar
Liked: 160
A $1,500 budget is just begging for dual PB-2000 (or XV15).
Dual PB-2000 is $1,499 shipped from SVS.
Pretty much everybody that does something like that seems quite happy.
Good question. I have no idea. But I asked myself the same question and looked into it quite a bit. The most popular answer seemed to be: Get a PB-2000. Then, later on, you can upgrade to a second if you want. Or get the dual PB1000 with the potential to upgrade to dual PB2000 within a year. But if you are going to end up with two PB2000, it probably makes more sense to start with one, and then just get the second one, because
SVS has a 1 year upgrade policy. For one year from the purchase of your sub, you can exchange it for a higher model and the entire purchase price of the first one will be applied towards the second. So say you spend $1,000 on a pair of PB1000...for a year after that you could pay $500 to up them to a pair of PB2000. The catch is that you have to pay return shipping on the less/older sub. This is why my personal recommendation would be to just get a single PB2000 with the intention of maybe, possibly, getting a second one later. That way you don't end up paying to ship/return two of the 1000s
Vs
Dual PB-2000 $1,499
I'm asking myself the same question right now. My PB-2000 just arrived a few days ago but I know I want to either get a second one or upgrade to a 12-Plus.
Speaking of which, is there a particular reason you selected PB12-Plus and not PC12-Plus? The PC is only $1,199 and performs just like the PB12-Plus, only it is $200 less expensive and only weighs 75 lbs. 16.5" diameter by about 40" tall.
Samsung PN60F5300, Sony PS3
Denon AVR-X1000
SVS PB-2000
Front-Center-Surround, Pioneer: FS52-C22-FS51
Farley1 is offline
post #20 of 28 Old 03-20-2014, 09:39 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
there are differences between the PB and PC+. the PB has about 1.5db more output and less THD from 20hz and below.
Farley1 likes this.
post #21 of 28 Old 03-20-2014, 12:50 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
To be honest, I just wasn't a fan of the look of the PC. I'm more of the block look to the sub.
I think I am leaning toward the PB-2000, I just can't decide if I want to spend the extra for dual.
KHarmo88 is offline
post #22 of 28 Old 03-20-2014, 12:53 PM
Farley1's Avatar
Liked: 160
Good to know.
It would also be nice if the SVS website had more detailed information like that. For example, in the FAQ:
What are the differences between the ported cabinet and ported cylinder subwoofers?
Within each family (i.e., NSD, Plus, Ultra) the ported cabinet and ported cylinder subwoofers offer the same overall level of performance. While taller, the ported cylinder models have a smaller footprint than their ported cabinet counterparts, and are a popular choice where floor space is limited, but there are no height restrictions.
Which is not inaccurate, I suppose, as that is the same overall level of performance. But still...would be nice to have details listed there.
Denon AVR-X1000
SVS PB-2000
Farley1 is offline
post #23 of 28 Old 03-20-2014, 01:34 PM
emerson1's Avatar
Quoted: 36 Post(s)
If you have the funds go for it!
I told you this site was helpful! (SuperBowlNachos)
emerson1 is offline
post #24 of 28 Old 03-20-2014, 01:40 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
Hey man! I apologize I never got back to you! This site is great. However, it's bad in the sense that I wasn't planning on spending as much as I was haha.
Kind of unrelated to the sub, can you give me some info on my receiver choice and the speakers I chose? I feel as if I'm getting hassled about the speakers. Speakercraft is the only option to me from the contractor through my homebuilder and I thought the AIM7 MT Three's were a good choice.
KHarmo88 is offline
post #25 of 28 Old 03-20-2014, 02:12 PM
emerson1's Avatar
Quoted: 36 Post(s)
It's common. My budget for my speakers was $400. $1,300 later I am glad I got talked up and I am still wishing I had got with a better sub.
More than likely they offer those because they get them wholesale and sell them to you for retail.
http://www.avsforum.com/f/89/speakers
emerson1 is offline
post #26 of 28 Old 03-20-2014, 02:28 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
So what is it about them that are bad? I seemed to find a lot of good reviews. Are there any by speakercraft that would be better?
KHarmo88 is offline
post #27 of 28 Old 03-20-2014, 02:43 PM
emerson1's Avatar
Quoted: 36 Post(s)
emerson1 is offline
post #28 of 28 Old 03-20-2014, 03:49 PM - Thread Starter
KHarmo88's Avatar
Quoted: 24 Post(s)
I'll do you one better. I contacted the contractor today and he stated he really liked Speaker Craft, but he could also get Klipsch, PSB, Boston Acostic, and other brands. He said I'd have to figure out what I like and he'd price them. You seem knowledgable, any suggestions?
KHarmo88 is offline
