Best Sub for under $1500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 61 Old 03-23-2014, 01:04 AM - Thread Starter
brutal0101's Avatar
Best Sub in terms of sound quality and output. I currently have the Outlaw LFM-1 EX.
saginawjuggalo likes this.
brutal0101 is offline
post #2 of 61 Old 03-23-2014, 04:15 AM
Avgass's Avatar
Liked: 35
My vote goes for the FV15HP or F25 if it's excluding shipping
Avgass is offline
post #3 of 61 Old 03-23-2014, 06:02 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
+1, FV15HP would be my pick at 1.5k.
shadyJ is offline
post #4 of 61 Old 03-24-2014, 09:29 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5240
+2
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #5 of 61 Old 03-25-2014, 12:42 AM - Thread Starter
brutal0101's Avatar
How about around $2000 and how does the F25 sound compared to the FV15HP? I want deep, clean, and hard hitting bass.
post #6 of 61 Old 03-25-2014, 12:48 AM
shadyJ's Avatar
Liked: 1350
If you want deep bass, the FV15HP would be better than the F25. At $2k you can also look at the SVS PC13 Ultra and PB13 Ultra, in certain respects they do handle deep bass a bit better, but not entirely.
shadyJ is offline
post #7 of 61 Old 03-25-2014, 01:05 AM
Avgass's Avatar
Liked: 35
The FV15HP is such an amazing value cos it is a direct competitor to the SVS PB13 which holds it's own for considerably less money. They are both quality products and each has it's own strengths and no obvious weaknesses. Neither is clearly better than the other. If you have more than $1,500 I say get an FV15HP and put the extra in the bank towards saving for a second, unless you have enough to get a JTR Captivator, Seaton Submersive or PSA Triax.
I happen to like sealed subs so find the F25 appealing, but you don't get as much output for your dollar. What you do get is deep bass output below the tuning frequency of a comparable ported sub and in the case of the F25 more bass higher up the frequency range. You also get less group delay in the lower frequencies although the audibility of this is hotly debated.
If you have a smaller room and lean towards music I would get the F25. For a larger room or a room open to other spaces and movie use the FV15HP might be the go, although either one will probably get the job done.
If you want advice specific to your situation we really need to know the size and shape of your room, whether it's open to other spaces, intended sub location, listening habits, what else is in your system, LP etc.
My 2c
Phil
Avgass is offline
post #8 of 61 Old 03-25-2014, 02:01 AM
deepat04's Avatar
Quoted: 94 Post(s)
Liked: 94
My 2c
Phil
+1
The FV15HP with a gloss black finish shipped is $1700 and will give you similar performance to the 2k SVS Ultra. SVS does have Rythmik beat with their free return shipping if you decide to go in a different during your in home trial. Also SVS will provide you with a longer warranty period.
What are you wanting to achieve? Room size? Listening habits?
For 2k dual HSU VTF15 subwoofers should also be considered
deepat04 is offline
post #9 of 61 Old 03-25-2014, 03:00 AM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Originally Posted by deepat04 View Post
+1
Depends where you live, in Canada the PB13 Ultra is about $2200 after shipping and taxes in either black oak or PB, the Rythmik FV15HP in PB is $2400 after shipping, taxes and currency conversion or $2150ish if its the black oak or black matte finish.
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
JustABrah is offline
post #10 of 61 Old 03-25-2014, 03:15 AM
shadyJ's Avatar
Liked: 1350
That's why if you are in Canada and want a high performance sub, it makes more sense to give Funk Audio a call. It's a better value because no import fees.
shadyJ is offline
post #11 of 61 Old 03-25-2014, 03:54 AM
JustABrah's Avatar
Quoted: 99 Post(s)
Liked: 78
Yeah, funk seems to make solid subs. How you think their 18.0C holds up to the SVS SB13 Ultra or the Rythmik F15HP?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
post #12 of 61 Old 03-25-2014, 04:35 AM
shadyJ's Avatar
Liked: 1350
I think you can expect similar or maybe just a bit less deep bass but a lot more upper bass output.
shadyJ is offline
post #13 of 61 Old 03-25-2014, 08:14 AM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2513
Due to your location making the prices basically equal, my vote would have to be for the PB13 Ultra. For output that you can really feel on movies, the 16-30 Hz region rules.  And like the Rythmik, the Utlra pounds exceptionally hard in this area.
bear123 is offline
post #14 of 61 Old 03-25-2014, 08:23 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5240
a 2k Budget,
a single sub I would be looking at the Captivator 2400 passive powered with a Inuke 3000dsp. This would easily outperform everything mentioned so far in this thread. I am not sure why this option gets over looked so much around here.
dual subs I would be looking at VTF-15's.
post #15 of 61 Old 03-25-2014, 12:54 PM
Xipper's Avatar
Another option could be the Reaction subs, you could get 2 x BPS215 for close to $1500 with shipping included...and that is 4 x 15" drives split across 2 sealed enclosures.  I am having the same discussion/research myself, and the Reaction subs are a lot of sub for the $...just hoping for someone else to buy one and review it for the class ;)
Xipper is offline
post #16 of 61 Old 03-25-2014, 03:52 PM
Avgass's Avatar
Liked: 35
Originally Posted by Xipper View Post
Another option could be the Reaction subs, you could get 2 x BPS215 for close to $1500 with shipping included...and that is 4 x 15" drives split across 2 sealed enclosures.  I am having the same discussion/research myself, and the Reaction subs are a lot of sub for the $...just hoping for someone else to buy one and review it for the class wink.gif
Might pay to skip these until there is some more feedback on them and the company is a bit more established. The stamped basket drivers do not inspire any confidence in me that these should be compared to the likes of the Rythmik and SVS options.
deepat04 likes this.
Avgass is offline
post #17 of 61 Old 03-25-2014, 04:21 PM
Bill Fitzmaurice's Avatar
Liked: 4655
Stamped frames can work just fine. That's what the Tempest 15 used, as does the Dayton DVC 385-88, which is actually an updated version of the Tempest. Stamped won't work well with more than 15mm xmax, but with a 2x15 15 mm is quite sufficient.
WhskyTangoFoxtrt likes this.
Bill Fitzmaurice is offline
post #18 of 61 Old 03-25-2014, 10:01 PM - Thread Starter
brutal0101's Avatar
Yeah how about dual VTF15 vs one FV15HP? Money is no object to me in terms of home theater as long as I hear and feel the results. In other words there has to be a considerable improvement. Output wise I believe one FV15HP would be just about enough but it is the sound quality that I am concerned about even more. I often turn off my Outlaw LFM-1 EX because some songs sound better without it. In other words it doesn't sound clean enough to me. I have a huge living room that runs into my kitchen and it is not sealed from anywhere. I listen to Rap, Rock, Pop and EDM. 75 Music / 25 HT. I want strong chest thump, and frequencies deep enough to shake my couch.
post #19 of 61 Old 03-25-2014, 10:10 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5240
If money is no object then Captivators or Submersives are what you need to lay your benjamins on...they will have better sound quality and output over the other options. The reason why you hear about the VTF-15 or FV15HP is because they fall into more folks budgets, but there are better options.
post #20 of 61 Old 03-25-2014, 10:10 PM
Avgass's Avatar
Liked: 35
I think if money is no object and you want to have great sound quality then get two Rythmiks as a minimum. They have a circa 4dB advantage throughout most of the frequency range over the VTF15, even more of an advantage down low and are a definite step up in terms of sound quality but they should be given the higher price.
If money is really no object get a pair of JTR caps, Seaton Submersives or PSA Triaxs
Avgass is offline
post #21 of 61 Old 03-25-2014, 10:32 PM
bear123's Avatar
Liked: 2513
Strong chest thump is mid and upper bass.
Shaking your couch will be lower frequencies, 16-30 Hz.
bear123 is offline
post #22 of 61 Old 03-25-2014, 11:47 PM - Thread Starter
brutal0101's Avatar
I am aware of that that's why I mentioned them both separately. I want a sub that can do both.
Is one Captivator 2400 better than Two FV15HP?
I think one FV15HP would be enough reading it's SPL chart because I don't want the cops to break into my house and arrest me.
I never considered JTR or Seaton subs in the past because their build quality in the pictures make them seem like boomy noisy concert speakers. It is hard to believe they will produce better sound quality than Rythmik or HSU based on the way they look.
post #23 of 61 Old 03-26-2014, 12:04 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5240
you should do some more research(I do not mean that in a negative way) smile.gif...they are some of the highest regarded turnkey subwoofers around. Very well built inert cabs, with very robust drivers utilizing the best plate amplifier in the industry(speaker power).
1 Captivator 2400 can put out 110db @ 16hz 2m rms.
1 Rythmik FV15HP can put out 104db @ 16hz 2m rms.
I am guessing the 2400 will maintain atleast a 6-8db advantage across the FR.
The FV15HP is a great sub, but the Captivator, Submersive, PSA Triax and Funk Audio stuff is on another level. I only mention this because you said money was not issue. If I could purchase any sub and budget was no concern I would go with Ported Caps or a Custom creation from Nathan at Funk Audio.
post #24 of 61 Old 03-26-2014, 12:11 AM
bear123's Avatar
Liked: 2513
  If the op decides to step up to the seaton/jtr/funk level of subs, I think the Seaton Submersive should be looked at hard.  It rocks for home theater and, although this is a semi educated guess, I think it might be superior for musical output compared to the single driver ported subs due to the dual drivers.  I know the Epik Empire and XS30 dual driver subs tend to outperform comparable ported subs in the mid and upper bass region, and the submersive is simply the best dual opposed out there.
This sub tends to swipe first place, sometimes second,  for sound quality in just about every blind test it has been in amongst other industry top of the line offerings.
bear123 is offline
post #25 of 61 Old 03-26-2014, 12:18 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5240
I would beg to differ...the CapS2 is the most powerful dual driver sealed sub. Dual 30mm Xmax 18" drivers that weigh over 60lbs each. It will put a spankin on the SubM. The SubM does offer some nicer finish options tho and I agree is a well regarded sub that would probably be satisfying for most.
post #26 of 61 Old 03-26-2014, 12:30 AM
bear123's Avatar
Liked: 2513
I misspoke, should have said dual opposed.  Which to me keeps the form a bit less obtrusive.
bear123 is offline
post #27 of 61 Old 03-26-2014, 12:05 PM
Avgass's Avatar
Liked: 35
You really want two subs to provide a smoother in room response at multiple listening positions, so I would only consider 1 JTR Cap over 2 Rythmik FV15HPs if you would probably get a second one in the future. The JTR is a significant step up in terms of output and probably similiar to 2 Rythmiks in this regard but I think both would be great in terms of SQ without a massive advantage either way within their limits.
Avgass is offline
post #28 of 61 Old 03-27-2014, 09:06 PM
CaptinCrunch's Avatar
Quoted: 29 Post(s)
Liked: 43
I would buy a pair of SVS PB-2000's for $1400
Sony 55W900A
Sony S5100 Blu-ray
Yamaha Aventage A1030
Klipsch RF-82 II
Klipsch RC-62 II
Klipsch RS-52 II
Klipsch RB-51 II (Front Preference)
SVS PB-2000
CaptinCrunch is offline
post #29 of 61 Old 03-27-2014, 11:17 PM - Thread Starter
brutal0101's Avatar
Good idea, does it produce chest thump? How about I keep my Outlaw and add one PB-2000? Or how about two PB12-Plus vs one Captivator? I do think that it might be an overkill though. I do want chest thumping bass though.
post #30 of 61 Old 03-28-2014, 12:25 AM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
Put a good sub near field. And you will have great chest pounding bass. Placement is everything!
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
