What's the best way to share a sub between a 2.1 and a 5.1 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 03-23-2014, 03:57 PM - Thread Starter
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
The title says it all...
...what's the best way to share a sub between a 2.1 and a 5.1?
The 2.0 and 5.0 parts are seven separate speakers.
The 2.0 has an east orientation and the 5.0 has a south orientation.
Only the subwoofer is to be shared.
rick240 is offline
post #2 of 17 Old 03-23-2014, 04:00 PM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
Huh?
If your AVR has "stereo" setting is should only play 2.1. If you have Dolby or DTS music mode then it's 5.1.
Assuming that's what you meant?
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
post #3 of 17 Old 03-23-2014, 04:04 PM - Thread Starter
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
Nope, not what I meant.
Clarifications added to OP.
rick240 is offline
post #4 of 17 Old 03-23-2014, 04:13 PM
Reefdvr27's Avatar
Quoted: 1578 Post(s)
Liked: 1062
I see what your saying now.
Are you using dual zones on your AVR separate AVR's? But as said below a Y splitter would be the best answer. As the sub will receive the signal from a or b.
Reefdvr27 is offline
post #5 of 17 Old 03-23-2014, 04:15 PM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
Hmmm... If you have two different sources/inputs you could probably use a y rca splitter at the sub and run each cable to the source.
The other source would have to be off though so they're not sending signals at the same time.
Not 100% sure that'll work though. It's cheap enough to try though.
UGAd13 is offline
post #6 of 17 Old 03-23-2014, 04:28 PM
trueno92's Avatar
Run the 2.0 via high level inputs and 5.1 as lfe/dedicated sub input.
Get your gain and crossover on the sub as the common denominator and then level the volume out the 2.0 and 5.1 independent of each other?
trueno92 is offline
post #7 of 17 Old 03-23-2014, 05:41 PM
whitey019's Avatar
Quoted: 111 Post(s)
Liked: 71
It is not good practice to use a Y-splitter on an input, that is two outputs to one input, because outputs are low impedance and you could damage the one output while driving with the other. On the other hand using a Y on an output, one output to two inputs, is fine as inputs have a relatively high impedance.
whitey019 is offline
post #8 of 17 Old 03-23-2014, 06:01 PM
ahmedreda's Avatar
Quoted: 327 Post(s)
Liked: 266
You can use a miniDSP 2x4 with the mixer or the advanced 2.1 plugins. That is assuming you have two avrs.
My home theater
Speakers: 3 JTR 212HTR (LCR), 2 Jtr Single 8LP (S), 2 JTR Triple 12LF (SB)) , 4 Volt 10LX (Atmos)
Subwoofers: 10 Sealed UXL-18, 5 Crowson Shadow 8 transducers, 3 Buttkicker LFE
Display: JVC RS400
ahmedreda is online now
post #9 of 17 Old 03-23-2014, 11:58 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
+1 this, you are essentially causing a short by using an y-splitter on an input. Also a miniDSP is overkill for what the OP wants to do. The OP will want to use something like these analogue utility mixers. This twenty buck Behringer mixer will do the job just fine.
shadyJ is offline
post #10 of 17 Old 03-24-2014, 06:14 AM - Thread Starter
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
Yep, I know a Y-connector is a bad idea. Althoough this one seems to make it possible.
Concerned about the potential damage if both are connected at the same time (someone, not me, might have both on at the same time).
It looks as though a switch (either RCA or XLR, depending on ultimate connection used) will be needed. I just haven't found one that works with a remote, all manual.
I was also hoping some sub manufacturer might have an input selector on the sub amp (similar to an AVR's input selector) - but no luck yet.
I was also hoping some AVR might have support for sharing the sub between zones - no luck yet.
rick240 is offline
post #11 of 17 Old 03-24-2014, 08:44 AM - Thread Starter
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
It looks like the XLR3 amp from Rythmik (co-incidentally my favourite sub maker) does exactly what I want.
It has a 'Dual Mode' which allows its two inputs to be connected to different systems cool.gif
rick240 is offline
post #12 of 17 Old 03-24-2014, 05:04 PM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 714
I would say get another sub so each system has one. Not sure of the rational to use one sub which can't be optimally located for two different systems.
derrickdj1 is offline
post #13 of 17 Old 03-24-2014, 07:43 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
qguy is offline
post #14 of 17 Old 03-24-2014, 09:47 PM - Thread Starter
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
There's lots of switches out there. I haven't found one that works with a universal remote yet. It would suck to have to flick a switch every time - but may be necessary.
Still trying to better understand Rythmik's Dual mode.
rick240 is offline
post #15 of 17 Old 03-24-2014, 09:54 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
I would go to RadioShack and pick up a spdt switch and wire the rca cable to that.
Mrkazador is offline
post #16 of 17 Old 03-25-2014, 02:16 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
How are you going to deal with the different volume setting for each system ?
qguy is offline
post #17 of 17 Old 03-25-2014, 02:52 PM - Thread Starter
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
Should be able to deal with in the receiver for each.
rick240 is offline
