sub to complement my bookshelf speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-29-2014, 06:35 AM - Thread Starter
riley08's Avatar
Quoted: 12 Post(s)
i just bought some polk RTIA1 bookshelf speakers for my 2-1 channel music setup and the speakers are fantastic but i need a good moderately priced sub 150-300 to fill in the lows for my music. i like the punchy tight sound to be used on my hardwood floors. any help would be appreciated! thanks
mains-POLK RTI6
center-POLK CSI3
surround-POLK RC65 INWALL
sub-DAYTON 1200
receiver-YAMAHA RX-V475
riley08 is offline
post #2 of 13 Old 03-29-2014, 09:38 AM
cel4145's Avatar
Quoted: 2652 Post(s)
Liked: 2984
Have you checked out the budget subwoofer discussion thread? Generally the discussion there focuses on <$300 subs.
Also, what are you using to power your speakers (make/model)? This could influence your sub choice.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #3 of 13 Old 03-29-2014, 10:09 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
I'd upp your budget a bit, for music worst thing you want is a bloaty boomy sub. What about a second hand SVS SB12NSD?
fatbottom is offline
post #4 of 13 Old 03-29-2014, 11:46 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5203
How are your wood working skills? If you can glue and screw then I can put you on a couple diy options for 300.00 that would kick butt.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #5 of 13 Old 03-29-2014, 01:53 PM - Thread Starter
riley08's Avatar
Quoted: 12 Post(s)
i dont have any wood working skills but a nice second hand sub would be fine. i definately do not want a boomy sounding sub with music. right now i'm using a denon 1513 which does the job for me. i will only be using this for my cd-dvd music concerts in which i have around 150 of them. i enjoy them alot but i'm in need of a good sub to complement them! my living area is about 16X18ft with vaulted ceilings opening into the dining room/kitchen if that info is needed.
mains-POLK RTI6
center-POLK CSI3
sub-DAYTON 1200
riley08 is offline
post #6 of 13 Old 03-29-2014, 02:46 PM
fatbottom's Avatar
Liked: 518
Then save up and buy a good one. I have a spare subwoofer similar to your budget, it sound bloody awful, I rather leave it switched off, then switch it on and ruin the soundstage.
post #7 of 13 Old 03-29-2014, 03:34 PM - Thread Starter
riley08's Avatar
Quoted: 12 Post(s)
i dont want a sub that will overpower my bookshelfs but give me that lower extension io balance the sound nicely!
mains-POLK RTI6
center-POLK CSI3
sub-DAYTON 1200
riley08 is offline
post #8 of 13 Old 03-29-2014, 03:38 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5203
Look up the hsu stf-1 on sale for 278.00 + shipping.
post #9 of 13 Old 03-29-2014, 03:47 PM
fatbottom's Avatar
Liked: 518
A good sub won't do that, you just turn down the volume. I'd recommend the SVS SB1000 as a minimum.
What is the size of your room?
post #10 of 13 Old 03-29-2014, 04:14 PM - Thread Starter
riley08's Avatar
Quoted: 12 Post(s)
about 16X18ft LXW. the 18ft extends into the dining/kitchen area.
mains-POLK RTI6
center-POLK CSI3
sub-DAYTON 1200
riley08 is offline
post #11 of 13 Old 03-29-2014, 04:18 PM
fatbottom's Avatar
Liked: 518
I'd say probably looking at SB2000
post #12 of 13 Old 03-29-2014, 04:34 PM - Thread Starter
riley08's Avatar
Quoted: 12 Post(s)
i will look into some of these and maybe a second hand one or on ebay maybe!
mains-POLK RTI6
center-POLK CSI3
sub-DAYTON 1200
riley08 is offline
post #13 of 13 Old 03-31-2014, 04:01 PM
rpshannonjr's Avatar
I have the RTiA1s as well and like them a lot, However, they need help with midbass as well as low.  I have 2 SVS PB1000s (b-stock$449 each) because I feel I have to cross them over at 100Hz to pick up some of the midbass that the bookshelves lack and I was having localization issues with a single sub set at 100Hz.  Obviously 2 subs is out of your price range but its hard to find a <$300 sub that doesn't sound boomy IME.  Have you looked at Hsu's STF-2? ($359)  Doesn't dig real deep but its a good all around sub (for a small room) that will bolster the performance of your RTiAs.
Sony STR-DA1800ES - Polk Audio RTiA1s & CSiA4 - Bose Cube Satellites - Dual SVS PB-1000s
rpshannonjr is offline
