NEW "BEST UNDER $800 SUB ENTERS THE MIX" - Page 2 - AVS | Home Theater Discussions And Reviews
post #31 of 85 Old 03-30-2014, 09:20 AM
destiny 21's Avatar
Quoted: 12 Post(s)
PSA XV 15
mercury and KidHorn like this.
destiny 21 is offline
post #32 of 85 Old 03-30-2014, 09:37 AM
Tom Vodhanel's Avatar
Quoted: 768 Post(s)
Liked: 2062
Originally Posted by destiny 21 View Post
PSA XV 15
Hi all, just a quick heads-up per the "$800" ceiling. Pricing increases are on the horizon for the entire Power-X product lineup. Jim and I still have to find time to "huddle" on this issue so I can't say exactly how much things will be increasing or when for that matter. But a good guess will be in the next 30 days(ish).
We have been absorbing pricing increases from our vendors for the past 18 months or so. In the past we found ways to avoid raising prices(eliminating the "base" for example) but it seems inevitable at this point.
Tom V.
Power Sound Audio
Tom Vodhanel is offline
post #33 of 85 Old 03-30-2014, 09:44 AM - Thread Starter
markbark's Avatar
Hi Cel and Shady  et al.  I'm thinking hard about the SVS, it's in the top three!  OH BTW CEL, do you know of any EQ that I haven't heard about??Do you use an eq?
markbark is offline
post #34 of 85 Old 03-30-2014, 09:47 AM - Thread Starter
markbark's Avatar
Oh my!  Hi Tom, please sell me and on which one please.
markbark is offline
post #35 of 85 Old 03-30-2014, 09:55 AM - Thread Starter
markbark's Avatar
One last thing Tom...What is your  PSA factor bases on?  ( Gee I'm so tempted to make a medical male type joke here but I'll be good).  Why should I buy yours as opposed to the HSU or the SVS?
markbark is offline
post #36 of 85 Old 03-30-2014, 10:00 AM
cel4145's Avatar
Quoted: 284 Post(s)
Liked: 804
I'm not sure if Mini DSP EQs below 20hz, but worth looking into. Then you get the mic to go with it so you can take readings and adjust it.
HT: Energy RC-50, RC-LCR, Veritas VS Surrounds | Dual CHT SS 18.1s | Denon AVR-888 | modified Dayton SA1000 | Antimode 8033C
Desktop: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | HK 3390
Headphone & Portable HE-400 | K612 Pro | HP150 | DX50 | E12
cel4145 is offline
post #37 of 85 Old 03-30-2014, 10:02 AM
bear123's Avatar
Quoted: 722 Post(s)
Liked: 1192
It does.....I had to cut 5 dB at 12 Hz or so to EQ my sub flat.
bear123 is offline
post #38 of 85 Old 03-30-2014, 11:28 AM
destiny 21's Avatar
Quoted: 12 Post(s)
just buy the xv15 and end it . then start feeling the lfe in movies. I would pay a 1000 dollars for this sub all day. get it you will be really happy
post #39 of 85 Old 03-30-2014, 11:55 AM
bear123's Avatar
Quoted: 722 Post(s)
Liked: 1192
Originally Posted by markbark View Post
 I have a small room 13X11 X8.  I like a tight sound and not  overly concerned with SPL but I am concerned with low bass extension  Ok I'll fess up, I like organ music and don't enjoy Rap or buildings exploding so you can gather I will use it far more for music then movies lol.
Feel free to recommend any option, but read the OP's interests before making suggestions for something he is not chasing.  His situation screams for a sealed sub with a shallow roll off.  Granted, the XV15 has decent output around 16 Hz, but with ported subs you have to consider the possibility of port noise with content around or slightly below port tune.  Not sure how loud you would have to play before this became an issue, but a sealed sub will not have any chuffing or port noise on low frequency content, especially if there is not a lot of other content to mask.
Biggest reason I bring this up is due to a song that was recently sugggest on the song of the day forum called "The Bass Will Destroy You", not classical organ music, but it has a lot of sub 20 Hz content, and most ported sub owners stated they got a lot of port noise and chuffing playing a song like this with so much content in the teens.  A sealed sub will play it clean  up to its output limit.
bear123 is offline
post #40 of 85 Old 03-30-2014, 12:23 PM
Calypte's Avatar
Originally Posted by shadyJ View Post
I'm not sure I would buy a huge sub just to playback that very occasional and uncommon low note unless I were a devoted pipe organ enthusiast. Hsu ships a demo disc with their subs that have a pipe organ recording of Saint-Saëns with a tremendous, sustained 16 Hz fundamental. I ought to check out a spectral graph of that tune sometime.
I would! I have a subwoofer (Kinergetics SW-120, from 1997) that goes down to 25 Hz, with a rapid rolloff from there. It handles explosions and bass drums satisfactorily for my taste. The only reason to get another subwoofer would be to go significantly lower. I'm shopping for one, so I've been following this and similar threads closely, and I've been scouring the AVS archives. I haven't heard the particular recording of Saint-Saens Organ Symphony that's on the BAS disc, but it's worth pointing out that the organ passage in question is marked "pp" in the score (pianissimo -- very quiet). Of the standard recordings of the complete symphony in my collection, Eschenbach's SACD with the Philadelphia Orchestra on Ondine has the best sound generally and best of the organ, at least to the limits of my Kinergetics. I hope to hear the 16 Hz before I die.
Calypte is offline
post #41 of 85 Old 03-30-2014, 12:48 PM
shadyJ's Avatar
Quoted: 842 Post(s)
Liked: 932
His PSA factor is based on averaging out CEA output measurements. It's a bogus metric which is there to mask a poor burst response shape. It's marketing hype designed to fool less technically inclined people, don't fall for it. Here is the real performance measurements for the XV15, undistorted by number juggling.
Bear, just because a sub doesn't have ports doesn't mean it's guaranteed to have clean playback. In fact, it usually means you will have much more distorted playback down low. Remember that for every octave that the sub driver has to playback at an equal loudness, you need four times the excursion. The more excursion a driver is subjected to, the greater the distortion. As an example, compare the PB12 NSD distortion vs the SB12 NSD:
While it's true the SB12 will have less output down low so it's distortion will not as easily be heard, it still is plagued by distortion, and will essentially be useless for >100 dB output below 30 Hz unless you get amazing room gain. There is virtually no sealed sub which could do justice to "Bass Will Destroy You", maybe a JTR Cap S2, maybe. Remember that the PB12 handles deep bass with much less distortion than the XV15, now imagine how a XS15 would fare. It would get murdered by that tune.
shadyJ is online now
post #42 of 85 Old 03-30-2014, 01:29 PM
dsrussell's Avatar
Quoted: 952 Post(s)
Liked: 886
That is the same SACD I have. I think it's wonderful, and I'm thankful that I have it in my classical collection. Along with the fantastic Saint Saen's "Organ Symphony No. 3 in C minor, Op. 78", this SACD also has Samuel Barber's "Toccata Festiva, Op. 36" and Francis Poulenc's "Concerto in G minor". The 2-minute sustained 16 Hz organ pedal was on Francis Poulenc's "Tempo Introduction Largo" (track #8 on Concerto in G minor). Very low volume piece that had me yawning (not from boredom, but from trying to get my ears to unplug from the pressure).
Music area: Magnepan 3.6, McIntosh MC2205 & C48, SVS SB13-Ultra, Oppo BDP 95 and assorted equipment.
Movie area: EMP Tek R5Bi, PSA XS30, Denon X2000, Oppo BDP 83.
dsrussell is online now
post #43 of 85 Old 03-30-2014, 01:37 PM
flickhtguru's Avatar
Liked: 105
I would go for the SVS SB2000.
Shawn
flickhtguru is offline
post #44 of 85 Old 03-30-2014, 01:38 PM
shadyJ's Avatar
Quoted: 842 Post(s)
Liked: 932
You have inspired me to take a spectral analysis of the Organ Symphony recording. I have posted it here. Really beautiful piece of music.
post #45 of 85 Old 03-30-2014, 01:47 PM
Calypte's Avatar
Another reason for me to get a sub that goes lower than my Kinergetics! The Poulenc piece has long been a favorite of mine, but I've never heard the note you mention, even though (based upon your testimony) it's right there on a recording I own. With all due respect to the many knowledgeable low-bass enthusiasts in this forum, I rarely see comparative references to subwoofer performance in music that interests me.
Calypte is offline
post #46 of 85 Old 03-30-2014, 01:52 PM
Calypte's Avatar
Mr. Russell: what subwoofer do you have? I see your city (Corona, CA), which means you are within decent driving distance of Hsu. I live in Anza, CA, and Hsu's location and the possibility of hearing their products in person would be a distinct plus for me.
Calypte is offline
post #47 of 85 Old 03-30-2014, 02:08 PM
dsrussell's Avatar
Quoted: 952 Post(s)
Liked: 886
I own the SVS SB13-Ultra for music and the PSA XS30 for movies. I live a little over 12 miles from Hsu Research and auditioned their ULS-15 at their showroom. I also did a home audition of the ULS-15 shortly thereafter (along with SVS's SB13-Ultra). I then did a home audition of PSA's XS30. Hey, I had to be sure smile.gif. Anyway, all three performed extremely well on this SACD and all caused pressure to my ears on that piece. PM me if you have any questions (I don't want to sideline this thread too much).
post #48 of 85 Old 03-30-2014, 02:26 PM
Calypte's Avatar
I re-listened to the Poulenc, and I hear the sustained pedal, in the respect that I hear a tone, but it's probably a harmonic, not the 16 Hz. Some people might be impressed, but it's not good enough for me. Thank you for your comments.
Calypte is offline
post #49 of 85 Old 03-30-2014, 09:29 PM
RayGuy's Avatar
Quoted: 221 Post(s)
Liked: 173
The difference is between them is mostly extension power. In single port mode, the VTF3 can hit 16 Hz at 108.4 dB in CEA testing, whereas the VTF2 hits 103.7. That is almost, but not quite, double the output. That is mainly due to the VTF3s large ports and enclosure. Above that point there is not such a great difference. If you are after 16 Hz specifically, go for the VTF3. If you don't need massive 16 Hz output, the VTF2 ought to do very well.
This. If you want to reach down to 16, at this price point, the HSU VTF3 is your best choice for extension and for tune-ability, IMO.
RayGuy is online now
post #50 of 85 Old 03-31-2014, 07:31 AM
KidHorn's Avatar
Quoted: 379 Post(s)
Liked: 330
Tom V.
Power Sound Audio
That's not good news. I'm waiting for my epik legend to die and am considering a XV15 as a possible replacement. Hopefully it will die in the next 30 days(ish).
mercury likes this.
KidHorn is offline
post #51 of 85 Old 03-31-2014, 08:24 AM
Quoted: 768 Post(s)
Liked: 2062
Tom V.
Power Sound Audio
post #52 of 85 Old 03-31-2014, 10:05 PM
basshead81's Avatar
Quoted: 74 Post(s)
Liked: 2154
Buy the XV15 now and sell the legend for 300.00 before it dies to recoop some cost. smile.gif
Getting Started with REW: A Step by Step Guide --> http://www.mediafire.com/view/aolmz2..._101_v3.92.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #53 of 85 Old 04-01-2014, 08:47 AM
KidHorn's Avatar
Quoted: 379 Post(s)
Liked: 330
I doubt I could get $300 and I don't want to sell something I know is failure prone. I'll just use it until it fails. Maybe it will last another 5 years.
dsrussell likes this.
KidHorn is offline
post #54 of 85 Old 04-01-2014, 01:12 PM
basshead81's Avatar
Quoted: 74 Post(s)
Liked: 2154
Epik legends are selling all day long for 300.00, but to each is own.
post #55 of 85 Old 04-01-2014, 02:10 PM
morrischestnut60's Avatar
Quoted: 56 Post(s)
Liked: 75
There is a bitter sweet relationship with Empire/Legend owners. Unless you have experienced one for extended listening, you cannot begin to appreciate the sound quality and performance.smile.gif
Politics is like religion. You never know who you serve.
morrischestnut60 is offline
post #56 of 85 Old 04-01-2014, 06:13 PM
basshead81's Avatar
Quoted: 74 Post(s)
Liked: 2154
a fried of mine bought a pair of legends for 600.00. He sold them 3 weeks later...They do sound good not bashing, just not at a XV15 level in terms of output, depth, and sound quality.
He invested that money into a pair of SI 18's stuffed in Marty Cube downfiring enclosures, powered by a Inuke 3000dsp. I have not made it over to hear them yet, but I am sure they are going to impress. smile.gif
post #57 of 85 Old 04-01-2014, 06:49 PM
Quoted: 56 Post(s)
Liked: 75
blah blah blah blah blah. The nerve! I owned an XS15 and it was no Empire in terms of sound quality. As for output, perhaps better low end if that is your cup of tea.
post #58 of 85 Old 04-01-2014, 06:55 PM
lovinthehd's Avatar
Quoted: 1278 Post(s)
Liked: 1670
lovinthehd is online now
post #59 of 85 Old 04-01-2014, 07:39 PM
basshead81's Avatar
Quoted: 74 Post(s)
Liked: 2154
Why are you getting upset? Where did I say Empire? I was talking about the legend, which is what Kidhorn has...don't get your fancy panties is a bunch.
post #60 of 85 Old 04-01-2014, 08:01 PM
Quoted: 56 Post(s)
Liked: 75
Upset? eek.gif. Is it the lack of a smile.gif? Lol. Too wordy for me. And yeah don't mention the Epiks and those lowly Power X subs in the same breadth.
