Sub woofer gives Excessive boomy sounds at high volume - AVS Forum | Home Theater Discussions And Reviews
Old 04-05-2014, 04:26 PM - Thread Starter
Bndck's Avatar
I have Denon Power Amplifier and Pre Amplifier both are stereo. power amplifier has one sub woofer out that i connect to Sony SA-W305G 45 watts subwoofer. my system output 50 + 50 w 6 Ohms impedance. I have decent pair of speakers(20-200W) that sounds good. when i hook up sub it works fine at low level voloume, but when it comes to high volume subwoofer produces dull  excessive boomy bass 'boh' sound that seems cannot handle volume. but when i reduce cut of freq and level control to lovel posotion bass boom eliminates. Is this normal? somthing wrong with subwoofer?..sub is not power enough for my system or what is the ideal set for music?..experts give advices plzzzz
NOTE:
sub has 3 controls Cut of freq(50-200Hz), Level and Phase. Sugges me Ideal cut of freq/Level and phase control. I dont want to go sub control every time i increase/decrease volume..annoying.
Bndck is offline
Old 04-05-2014, 04:36 PM
Bill Fitzmaurice's Avatar
Liked: 4629
You probably have a ground loop. Do a search, this topic comes up at least every other day.
Bill Fitzmaurice is offline
Old 04-05-2014, 04:46 PM - Thread Starter
Bndck's Avatar
ground loop?..what that means?..sory.i have no clue. some links plzzz..it's actually not hum..but when i increase volume sub gives "boh" sound..
Bndck is offline
Old 04-06-2014, 01:02 PM
Stephen Pickard's Avatar
Assuming the crossover is set correctly, you might try putting the subwoofer up on some kind of small plastic feet which might reduce some of the boominess.
Stephen Pickard
Stephen Pickard is offline
Old 04-06-2014, 02:05 PM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2985
Google is wonderful for discovering meaning and links. For example, http://www.audioholics.com/home-theater-connection/ground-loops-eliminating-system-hum-and-buzz
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
